Étude de réseaux complexes et de leurs propriétés pour l’optimisation de modèles de routage - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2014
Study of complex networks properties for the optimization of routing models
This thesis considers routing issues in networks, and particularly the graph of the autonomous systems (AS) of the Internet. Firstly, we aim at better understanding the properties of the Internet that are useful in the design of new routing paradigms. Secondly, we want to evaluate by simulation the performance of these paradigms. The first part of my work concerns the study of the Gromov hyperbolicity, a useful metric property for the design of new routing paradigms. I show how to use a decomposition of the graph by clique-separators as a pre-processing method for the computation of the hyperbolicity. Then, I propose a new algorithm to compute this property. Altogether, these methods allows us for computing the hyperbolicity of graphs up to 58 000 nodes. The second part of my work concerns the development of DRMSim, a new Dynamic Routing Model Simulator. It facilitates the evaluation of the performances of various routing schemes and their comparison to the standard routing scheme of the Internet, the border router protocol BGP. Using DRMSim, we performed simulations of several compact routing schemes on topologies up to O(10k) nodes. I describe its architecture and detail some examples. Then, I present a feasibility study for the design of a parallel/distributed version of DRMSim in order to simulate BGP on larger topologies.
Cette thèse s’intéresse aux problématiques de routage dans les réseaux, notamment dans le graphe des systèmes autonomes (AS) d’Internet. Nous cherchons d’une part à mieux comprendre les propriétés du graphe de l’Internet qui sont utiles dans la conception de nouveaux paradigmes de routage. D’autre part, nous cherchons à évaluer par simulation les performances de ces paradigmes. La première partie de mes travaux porte sur l’étude d’une propriété́ métrique, l’hyperbolicité́ selon Gromov, utilisée dans la conception de nouveaux paradigmes de routage. Je présente dans un premier temps une nouvelle approche pour le calcul de l’hyperbolicité́ d’un graphe utilisant une décomposition du graphe par les cliques-séparatrices et la notion de paires éloignées. Je propose ensuite un nouvel algorithme pour le calcul de l’hyperbolicité́ qui, combiné avec la méthode de décomposition par les cliques-séparatrices, permet son calcul sur des graphes composés de 58 000 sommets en quelques heures. La deuxième partie de mes travaux porte sur le développement de DRMSim, une nouvelle plate-forme de simulation de modèles de routage dynamiques. Celle-ci permet l’évaluation des performances des schémas de routage et leur comparaison au protocole de référence, le protocole de routeur frontière, BGP. DRMSim a permis l’étude par simulation de différents schémas de routage compact sur des topologies à O(10k) nœuds. Je détaille l’architecture de DRMSim et quelques exemples d’utilisation. Puis, je présente une étude réalisée en vue de développer une version parallèle et distribuée de DRMSim dans le cadre de la simulation de BGP
2014NICE4117.pdf (8.9 Mo) Télécharger le fichier
tel-01128347 , version 1 (09-03-2015)
  • HAL Id : tel-01128347 , version 1
Aurélien Lancin. Étude de réseaux complexes et de leurs propriétés pour l’optimisation de modèles de routage. Autre [cs.OH]. Université Nice Sophia Antipolis, 2014. Français. ⟨NNT : 2014NICE4117⟩. ⟨tel-01128347⟩
388 Consultations
635 Téléchargements
