21 1. Measurement-Based Characterization, p.22 ,
30 1. Measurement Infrastructure, 32 2. Computing Distance Vector Changes, p.35 ,
45 1. Control Plane 46 2. Transfer Delay for Multiple Prefixes, p.51 ,
55 1. Definition of Traffic Variations, Changes in Traffic Demands vs. Egress Points, vol.56, issue.2, p.58 ,
76 1. Challenges, Assumptions of the Model, vol.76, issue.2, p.78 ,
91 1. From Regions to Hot Potatoes, Control Plane Sensitivity, vol.91, issue.2, p.93 ,
102 1. Obtaining Inputs for the Model, p.102 ,
118 1. Critique of Today, p.120 ,
Impact of BGP Dynamics on Intra-Domain Traffic, Proc. ACM SIGMETRICS, 2004. ,
Toward Milli- Second IGP Convergence, Expired Internet Draft, 2000. ,
A measurement-based analysis of multi-homing, Proc. ACM SIGCOMM, 2003. ,
MPLS and Traffic Engineering in IP Networks, IEEE Communication Magazine, 1999. ,
Impact of link failures on VoIP performance, Proceedings of the 12th international workshop on Network and operating systems support for digital audio and video , NOSSDAV '02, 2002. ,
DOI : 10.1145/507670.507680
Route Oscillations in I-BGP with Route Reflection, Proc. ACM SIGCOMM, 2002. ,
A hybrid genetic algorithm for the weight setting problem in OSPF/IS-IS routing, Networks, vol.6, issue.1, 2003. ,
DOI : 10.1002/net.20070
Optimal configuration for BGP route selection, IEEE INFOCOM 2003. Twenty-second Annual Joint Conference of the IEEE Computer and Communications Societies (IEEE Cat. No.03CH37428), 2003. ,
DOI : 10.1109/INFCOM.2003.1208929
The Case for More Versatile BGP Route Reflectors. Internet Draft draft-bonaventure-bgp-route- reflectors-00, 2004. ,
Use of OSI IS?IS for Routing in TCP/IP and Dual Environments, 1195. ,
An overview of data warehousing and OLAP technology, ACM SIGMOD Record, vol.26, issue.1, 1997. ,
DOI : 10.1145/248603.248616
Time-varying network tomography, J. American Statistical Association, 2000. ,
BGP Best Path Selection Algorithm ,
Configure Router Calculation Timers ,
Understanding BGP Processes on Cisco ,
The Design Philosophy of the DARPA Internet Protocols, Proc. ACM SIGCOMM, pp.106-114, 1988. ,
Towards localizing root causes of BGP dynamics, 2003. ,
BGP communities attribute, 1996. ,
DOI : 10.17487/rfc1997
A Note on Two Problems in Connexion with Graphs, Numerische Mathematik, vol.1, pp.269-271, 1959. ,
Estimating flow distributions from sampled flow statistics, Proc. ACM SIGCOMM, 2003. ,
MPLS: Technology and Applications, 2000. ,
A genetic algorithm for the weight setting problem in OSPF routing, Journal of Combinatorial Optimization, vol.6, issue.3, pp.299-333, 2002. ,
DOI : 10.1023/A:1014852026591
Aman Shaikh, and Jacobus van der Merwe. The Case for Separating Routing from Routers, ACM SIGCOMM Workshop on Future Directions in Network Architecture, 2004. ,
NetScope: traffic engineering for IP networks, IEEE Network, vol.14, issue.2, pp.11-19, 2000. ,
DOI : 10.1109/65.826367
Deriving Traffic Demands for Operational IP Networks: Methodology and Experience, IEEE/ACM Trans. Networking, vol.9, issue.3, 2001. ,
Locating Internet Routing Instabilities, Proc. ACM SIGCOMM, 2004. ,
Traffic engineering with traditional IP routing protocols, IEEE Communications Magazine, vol.40, issue.10, 2002. ,
DOI : 10.1109/MCOM.2002.1039866
URL : https://hal.archives-ouvertes.fr/hal-01255602
Internet traffic engineering by optimizing OSPF weights, Proceedings IEEE INFOCOM 2000. Conference on Computer Communications. Nineteenth Annual Joint Conference of the IEEE Computer and Communications Societies (Cat. No.00CH37064), 2000. ,
DOI : 10.1109/INFCOM.2000.832225
URL : https://hal.archives-ouvertes.fr/hal-01255612
Optimizing OSPF/IS-IS weights in a changing world, IEEE Journal on Selected Areas in Communications, vol.20, issue.4, pp.756-767, 2002. ,
DOI : 10.1109/JSAC.2002.1003042
URL : https://hal.archives-ouvertes.fr/hal-01255600
Robust optimization of OSPF/IS-IS weights ,
URL : https://hal.archives-ouvertes.fr/hal-01255589
Increasing Internet Capacity Using Local Search, Proc. 19th IEEE Conf. on Computer Communications, pp.13-48, 2000. ,
DOI : 10.1023/B:COAP.0000039487.35027.02
URL : https://hal.archives-ouvertes.fr/hal-01255580
IP Restoration vs. WDM Protection: Is There an Optimal Choice? IEEE Network Magazine, 2000. ,
A Model of BGP Routing for Network Engineering, Proc. ACM SIGMETRICS, 2004. ,
Data cube: a relational aggregation operator generalizing GROUP-BY, CROSS-TAB, and SUB-TOTALS, Proceedings of the Twelfth International Conference on Data Engineering, pp.29-53, 1997. ,
DOI : 10.1109/ICDE.1996.492099
Aggregate query processing in data warehousing environments, VLDB, pp.358-369, 1995. ,
Optimizing cost and performance for multihoming, Proc. ACM SIGCOMM, 2004. ,
An analysis of Internet inter-domain topology and route stability, Proceedings of INFOCOM '97, 1997. ,
DOI : 10.1109/INFCOM.1997.644557
Stable Internet Routing without Global Coordination, IEEE/ACM Trans. Networking, 2001. ,
DOI : 10.1145/345063.339426
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.110.6928
An Analysis of BGP Convergence Properties, Proc. ACM SIGCOMM, 1999. ,
Analysis of the MED oscillation problem in BGP, 10th IEEE International Conference on Network Protocols, 2002. Proceedings., 2002. ,
DOI : 10.1109/ICNP.2002.1181389
On the Correctness of IBGP Configuration, Proc. ACM SIGCOMM, 2002. ,
Internet Routing Architectures, 2001. ,
Detection and analysis of routing loops in packet traces, Proceedings of the second ACM SIGCOMM Workshop on Internet measurment , IMW '02, 2002. ,
DOI : 10.1145/637201.637217
Feasibility of IP restoration in a tier 1 backbone, IEEE Network, vol.18, issue.2, 2004. ,
DOI : 10.1109/MNET.2004.1276606
Ilog Cplex 9.0 User's Manual, 2003. ,
Analysis of link failures in an IP backbone, Proceedings of the second ACM SIGCOMM Workshop on Internet measurment , IMW '02, 2002. ,
DOI : 10.1145/637201.637238
Routing and peering in a competitive Internet, 2004 43rd IEEE Conference on Decision and Control (CDC) (IEEE Cat. No.04CH37601), 2003. ,
DOI : 10.1109/CDC.2004.1430265
TeXCP: Responsive Yet Stable Traffic Engineering, Proc. ACM SIGCOMM, 2005. ,
Traffic Engineering (TE) Extensions to OSPF Version 2, 2003. ,
DOI : 10.17487/rfc3630
Delayed Internet routing convergence, IEEE/ACM Transactions on Networking, vol.9, issue.3, pp.293-306, 2001. ,
DOI : 10.1109/90.929852
URL : http://athos.rutgers.edu/~rmartin/teaching/fall04/cs552/readings/lab01.pdf
Experimental Study of Internet Stability and Wide-Area Network Failures, Proc. International Symposium on Fault-Tolerant Computing, 1999. ,
Characterization of network-wide anomalies in traffic flows, Proceedings of the 4th ACM SIGCOMM conference on Internet measurement , IMC '04, 2004. ,
DOI : 10.1145/1028788.1028813
Internet routing instability, IEEE/ACM Transactions on Networking, vol.6, issue.5, pp.515-558, 1998. ,
DOI : 10.1109/90.731185
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.100.2363
Origins of Pathological Internet Routing Instability, Proc. IEEE INFOCOM, 1999. ,
How good can IP routing be?, DIMACS, 2001. ,
Structural Analysis of Network Traffic Flows, Proc. ACM SIGMETRICS, 2004. ,
Route Flap Damping Exacerbates Internet Routing Convergence, Proc. ACM SIGCOMM, 2002. ,
DOI : 10.1145/633025.633047
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.12.6435
Border gateway protocol (BGP) persistent route oscillation condition, 2002. ,
DOI : 10.17487/rfc3345
OSPF Version 2, RFC, vol.2328, 1998. ,
DOI : 10.17487/rfc1247
Towards an accurate AS-level traceroute tool, Proceedings of the 2003 conference on Applications, technologies, architectures, and protocols for computer communications , SIGCOMM '03, 2003. ,
DOI : 10.1145/863955.863996
A Taxonomy of IP Traffic Matrix Estimation: Existing Techiniques and New Directions, Proc. ACM SIGCOMM, 2002. ,
Towards coordinated interdomain traffic engineering, Proc. SIGCOMM Workshop on Hot Topics in Networking, 2004. ,
IGP link weight assignment for transient link failures, Elsevier ITC18, 2003. ,
DOI : 10.1016/S1388-3437(03)80177-4
Interdomain traffic engineering with BGP, IEEE Communication Magazine, 2003. ,
DOI : 10.1109/MCOM.2003.1200112
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.12.3021
Route Optimization in IP Networks, Handbook of Optimization in Telecommunications, 2005. ,
DOI : 10.1007/978-0-387-30165-5_24
BGP routing stability of popular destinations, Proceedings of the second ACM SIGCOMM Workshop on Internet measurment , IMW '02, 2002. ,
DOI : 10.1145/637201.637232
Characterizing the Internet hierarchy from multiple vantage points, Proceedings.Twenty-First Annual Joint Conference of the IEEE Computer and Communications Societies, 2002. ,
DOI : 10.1109/INFCOM.2002.1019307
OSPF Monitoring: Architecture, Design and Deployment Experience, Proc. USENIX Symposium on Networked Systems Design and Implementation, 2004. ,
Making OSPF/IS-IS routing robust to link failures, Proc. Networking'2005, 2005. ,
DOI : 10.1007/11422778_51
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.649.1418
A case study of OSPF behavior in a large enterprise network, Proceedings of the second ACM SIGCOMM Workshop on Internet measurment , IMW '02, 2002. ,
DOI : 10.1145/637201.637236
Quantifying the Causes of Path Inflation, Proc. ACM SIGCOMM, 2003. ,
On the correlation between route dynamics and routing loops, Proceedings of the 2003 ACM SIGCOMM conference on Internet measurement , IMC '03, 2003. ,
DOI : 10.1145/948205.948243
Intermediate System to Intermediate System (IS-IS) Extensions for Traffic Engineering (TE), RFC, vol.3784, 2004. ,
Dynamics of Hot-Potato Routing in IP Networks, Proc. ACM SIGMET- RICS, 2004. ,
URL : https://hal.archives-ouvertes.fr/hal-01097533
A multiple-objectives evolutionary perspective to interdomain traffic engineering in the internet, Workshop on Nature Inspired Approaches to Networks and Telecommunications (NIANT), 2004. ,
On the Sensitivity of Transit ASes to Internal Failures, Proc. of the IEEE International workshop on IP Operations and Management, 2005. ,
DOI : 10.1007/11567486_15
Traffic engineering between neighboring domains, 2002. ,
Experiences with monitoring ospf on a regional service provider network, 23rd International Conference on Distributed Computing Systems, 2003. Proceedings., pp.204-213, 2003. ,
DOI : 10.1109/ICDCS.2003.1203467
Observation and analysis of BGP behavior under stress, Proceedings of the second ACM SIGCOMM Workshop on Internet measurment , IMW '02, 2002. ,
DOI : 10.1145/637201.637231
An information-theoretic approach to traffic matrix estimation, Proceedings of the 2003 conference on Applications, technologies, architectures, and protocols for computer communications , SIGCOMM '03, 2003. ,
DOI : 10.1145/863955.863990
