Abstract : Making sure that a computer program behaves as expected, especially in critical applications (health, transport, energy, communications, etc.), is more and more important, all the more so since computer programs become more and more ubiquitous and essential to the functioning of modern societies. But how to check that a program behaves as expected, in particular when the range of its inputs is very large or potentially infinite? In this work, we explain the development of a new, faster and formally proved version of Rainbow based on the extraction mechanism of Coq. The previous version of Rainbow verified a CPF le in two steps. First, it used a non-certified OCaml program to translate a CPF file into a Coq script, using the Coq libraries on rewriting theory and termination CoLoR and Coccinelle. Second, it called Coq to check the correctness of the script. This approach is interesting for it provides a way to reuse in Coq termination proofs generated by external tools. This is also the approach followed by CiME3. However, it suffers from a number of deficiencies. First, because in Coq functions are interpreted, computation is much slower than with programs written in a standard programming language and compiled into binary code. Second, because the translation from CPF to Coq is not certified, it may contain errors and either lead to the rejection of valid certificates, or to the acceptance of wrong certificates. To solve the latter problem, one needs to define and formally prove the correctness of a function checking whether a certificate is valid or not. To solve the former problem, one needs to compile this function to binary code. The present work shows how to solve these two problems by using the proof assistant Coq and its extraction mechanism to the programming language OCaml. Indeed, data structures and functions de fined in Coq can be translated to OCaml and then compiled to binary code by using the OCaml compiler. A similar approach was first initiated in CeTA using the Isabelle proof assistant.
Résumé : S'assurer qu'un programme informatique se comporte bien, surtout dans des applications critiques (santé, transport, énergie, communications, etc.) est de plus en plus important car les ordinateurs et programmes informatiques sont de plus en plus omniprésents, voir essentiel au bon fonctionnement de la société. Mais comment vérifier qu'un programme se comporte comme prévu, quand les informations qu'il prend en entrée sont de très grande taille, voire de taille non bornée a priori ? Pour exprimer avec exactitude ce qu'est le comportement d'un programme, il est d'abord nécessaire d'utiliser un langage logique formel. Cependant, comme l'a montré Gödel dans, dans tout système formel suffisamment riche pour faire de l'arithmétique, il y a des formules valides qui ne peuvent pas être prouvées. Donc il n'y a pas de programme qui puisse décider si toute propriété est vraie ou fausse. Cependant, il est possible d'écrire un programme qui puisse vérifier la correction d'une preuve. Ce travail utilisera justement un tel programme, Coq, pour formellement vérifier la correction d'un certain programme. Dans cette thèse, nous expliquons le développement d'une nouvelle version de Rainbow, plus rapide et plus sûre, basée sur le mécanisme d'extraction de Coq. La version précédente de Rainbow vérifiait un certificat en deux étapes. Premièrement, elle utilisait un programme OCaml non certifié pour traduire un fichier CPF en un script Coq, en utilisant la bibliothèque Coq sur la théorie de la réécriture et la terminaison appelée CoLoR. Deuxièmement, elle appelait Coq pour vérifier la correction du script ainsi généré. Cette approche est intéressante car elle fournit un moyen de réutiliser dans Coq des preuves de terminaison générée par des outils extérieurs à Coq. C'est également l'approche suivie par CiME3. Mais cette approche a aussi plusieurs désavantages. Premièrement, comme dans Coq les fonctions sont interprétées, les calculs sont beaucoup plus lents qu'avec un langage où les programmes sont compilés vers du code binaire exécutable. Deuxièmement, la traduction de CPF dans Coq peut être erronée et conduire au rejet de certificats valides ou à l'acceptation de certificats invalides. Pour résoudre ce deuxième problème, il est nécessaire de définir et prouver formellement la correction de la fonction vérifiant si un certificat est valide ou non. Et pour résoudre le premier problème, il est nécessaire de compiler cette fonction vers du code binaire exécutable. Cette thèse montre comment résoudre ces deux problèmes en utilisant l'assistant à la preuve Coq et son mécanisme d'extraction vers le langage de programmation OCaml. En effet, les structures de données et fonctions définies dans Coq peuvent être traduits dans OCaml et compilées en code binaire exécutable par le compilateur OCaml. Une approche similaire est suivie par CeTA en utilisant l'assistant à la preuve Isabelle et le langage Haskell.
