Discrete laplacians on general polygonal meshes, ACM Transactions on Graphics, vol.30102, issue.4, pp.2011-2022 ,
Anisotropic polygonal remeshing, ACM Transactions on Graphics, vol.22, issue.3, pp.485-493, 2003. ,
DOI : 10.1145/882262.882296
URL : https://hal.archives-ouvertes.fr/inria-00099624
Mesh Sizing with Additively Weighted Voronoi Diagrams, Proceedings of the International Meshing Roundtable, pp.335-346, 2007. ,
DOI : 10.1007/978-3-540-75103-8_19
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.565.6175
Lp Lloyd's energy minimization for quadrilateral surface mesh generation, Proceedings of the International Meshing Roundtable, pp.473-487 ,
QUADRILATERAL MESHING BY CIRCLE PACKING, International Journal of Computational Geometry & Applications, vol.10, issue.04, pp.347-360, 2000. ,
DOI : 10.1142/S0218195900000206
Parameterization of triangle meshes over quadrilateral domains, Proceedings of the 2004 Eurographics/ACM SIGGRAPH symposium on Geometry processing , SGP '04, pp.197-208, 2004. ,
DOI : 10.1145/1057432.1057459
Locally uniform anisotropic meshing, Proceedings of the twenty-fourth annual symposium on Computational geometry , SCG '08, pp.270-277, 2008. ,
DOI : 10.1145/1377676.1377724
URL : https://hal.archives-ouvertes.fr/inria-00275430
Géométrie algorithmique. Ediscience international Paris, 1995. ,
Global Structure Optimization of Quadrilateral Meshes, Computer Graphics Forum, vol.29, issue.4, pp.375-384, 2011. ,
DOI : 10.1111/j.1467-8659.2011.01868.x
State of the art in quad meshing, Eurographics STARS, p.2012 ,
URL : https://hal.archives-ouvertes.fr/hal-00804550
Mixed-integer quadrangulation, ACM Transactions on Graphics, vol.28, issue.37, pp.39-57, 2009. ,
Adaptive triangular-quadrilateral mesh generation, International Journal for Numerical Methods in Engineering, vol.5, issue.5, pp.915-934, 1996. ,
DOI : 10.1002/(SICI)1097-0207(19980315)41:5<915::AID-NME318>3.0.CO;2-Y
URL : https://hal.archives-ouvertes.fr/inria-00073738
A pliant method for anisotropic mesh generation, Proceedings of the International Meshing Roundtable, pp.63-74, 1996. ,
A robust procedure to eliminate degenerate faces from triangle meshes, VMV, pp.283-290, 2001. ,
Polygon Mesh Processing, 2010. ,
DOI : 10.1201/b10688
URL : https://hal.archives-ouvertes.fr/inria-00538098
Small Strictly Convex Quadrilateral Meshes of Point Sets, Algorithmica, vol.38, issue.2, pp.317-339, 2003. ,
DOI : 10.1007/s00453-003-1062-1
Dual loops meshing, ACM Transactions on Graphics, vol.31, issue.4, pp.110-2012 ,
DOI : 10.1145/2185520.2185606
Orphan-Free Anisotropic Voronoi Diagrams, Discrete & Computational Geometry, vol.15, issue.3, pp.526-541, 2011. ,
DOI : 10.1007/s00454-011-9372-6
URL : http://arxiv.org/abs/1102.3670
Recursively generated B-spline surfaces on arbitrary topological meshes, Computer-Aided Design, vol.10, issue.6, pp.350-355, 1978. ,
DOI : 10.1016/0010-4485(78)90110-0
Estimating differential quantities using polynomial fitting of osculating jets, Computer Aided Geometric Design, vol.22, issue.2, pp.121-146, 2005. ,
DOI : 10.1016/j.cagd.2004.09.004
URL : https://hal.archives-ouvertes.fr/hal-00103047
Variational shape approximation, ACM Transactions on Graphics, vol.23, issue.3, pp.905-914, 2004. ,
DOI : 10.1145/1015706.1015817
URL : https://hal.archives-ouvertes.fr/inria-00070632
Restricted delaunay triangulations and normal cycle, Proceedings of the nineteenth conference on Computational geometry , SCG '03, pp.312-321, 2003. ,
DOI : 10.1145/777792.777839
Trivial Connections on Discrete Surfaces, Computer Graphics Forum, vol.25, issue.4, pp.1525-1533, 2010. ,
DOI : 10.1111/j.1467-8659.2010.01761.x
Are bilinear quadrilaterals better than linear triangles ?, SIAM Journal on Scientific Computing, vol.22, issue.1, pp.198-217, 2000. ,
DOI : 10.2172/10179134
Implicit fairing of irregular meshes using diffusion and curvature clow, SIGGRAPH, pp.317-324, 1999. ,
Spectral surface quadrangulation, ACM Transactions on Graphics, vol.25, issue.3, pp.1057-1066, 2006. ,
DOI : 10.1145/1141911.1141993
Centroidal Voronoi Tessellations: Applications and Algorithms, SIAM Review, vol.41, issue.4, pp.637-676, 1999. ,
DOI : 10.1137/S0036144599352836
Anisotropic Centroidal Voronoi Tessellations and Their Applications, SIAM Journal on Scientific Computing, vol.26, issue.3, pp.737-761, 2005. ,
DOI : 10.1137/S1064827503428527
Convergence of the Lloyd Algorithm for Computing Centroidal Voronoi Tessellations, SIAM Journal on Numerical Analysis, vol.44, issue.1, pp.102-119, 2006. ,
DOI : 10.1137/040617364
Nondegeneracy and Weak Global Convergence of the Lloyd Algorithm in $\mathbb{R}^d$, SIAM Journal on Numerical Analysis, vol.46, issue.3, pp.1423-1441, 2008. ,
DOI : 10.1137/070691334
Mean value coordinates, Computer Aided Geometric Design, vol.20, issue.1, pp.19-27, 2003. ,
DOI : 10.1016/S0167-8396(03)00002-5
Surface simplification using quadric error metrics, Proceedings of the 24th annual conference on Computer graphics and interactive techniques , SIGGRAPH '97, pp.209-216, 1997. ,
DOI : 10.1145/258734.258849
Simplifying surfaces with color and texture using quadric error metrics, Proceedings Visualization '98 (Cat. No.98CB36276), pp.263-269, 1998. ,
DOI : 10.1109/VISUAL.1998.745312
Hierarchical face clustering on polygonal surfaces, Proceedings of the 2001 symposium on Interactive 3D graphics , SI3D '01, pp.49-58, 2001. ,
DOI : 10.1145/364338.364345
The minimum description length principle, 2007. ,
SQuad: Compact Representation for Triangle Meshes, Computer Graphics Forum, vol.24, issue.3, pp.355-364 ,
DOI : 10.1111/j.1467-8659.2011.01866.x
Spectral quadrangulation with orientation and alignment control, ACM SIGGRAPH Asia 2008 papers, SIGGRAPH Asia '08, pp.1-147, 2008. ,
Localized Quadrilateral Coarsening, Computer Graphics Forum, vol.2, issue.2, pp.1437-1444, 2009. ,
DOI : 10.1111/j.1467-8659.2009.01520.x
Semi-regular Quadrilateral-only Remeshing from Simplified Base Domains, Computer Graphics Forum, vol.25, issue.3, pp.1427-1435, 2009. ,
DOI : 10.1111/j.1467-8659.2009.01519.x
Quadrilateral mesh simplification, ACM Transactions on Graphics, vol.27, issue.5, p.148, 2008. ,
Non-iterative, feature-preserving mesh smoothing, ACM Transactions on Graphics, vol.22, issue.3, pp.943-949, 2003. ,
DOI : 10.1145/882262.882367
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.13.73
QuadCover - Surface Parameterization using Branched Coverings, Computer Graphics Forum, vol.26, issue.3, pp.375-384, 2007. ,
DOI : 10.1145/1183287.1183297
Reducibility among combinatorial problems, In Complexity of Computer Computations, pp.85-103, 1972. ,
Anisotropic quadrangulation, Symposium on Solid and Physical Modeling, pp.137-146, 2010. ,
Anisotropic voronoi diagrams and guaranteed-quality anisotropic mesh generation, Proceedings of the nineteenth conference on Computational geometry , SCG '03, pp.191-200, 2003. ,
DOI : 10.1145/777792.777822
An incremental approach to feature aligned quad dominant remeshing, Proceedings of the 2008 ACM symposium on Solid and physical modeling , SPM '08, pp.137-145, 2008. ,
DOI : 10.1145/1364901.1364921
L p centroidal Voronoi tessellation and its applications, 2010. (Cité en pages 9, pp.68-69 ,
Least squares quantization in PCM, IEEE Transactions on Information Theory, vol.28, issue.2, pp.129-136, 1982. ,
DOI : 10.1109/TIT.1982.1056489
Direct anisotropic quad-dominant remeshing, 12th Pacific Conference on Computer Graphics and Applications, 2004. PG 2004. Proceedings., pp.207-216, 2004. ,
DOI : 10.1109/PCCGA.2004.1348351
Approximation adaptative et anisotrope par éléments finis : théorie et algorithmes, pp.2010-66 ,
Feature-aligned t-meshes, ACM Transactions on Graphics, vol.29, issue.68, pp.15-69, 2010. ,
DOI : 10.1145/1778765.1778854
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.169.9117
Q-Morph: an indirect approach to advancing front quad meshing, International Journal for Numerical Methods in Engineering, vol.25, issue.9, pp.1317-1340, 1999. ,
DOI : 10.1002/(SICI)1097-0207(19990330)44:9<1317::AID-NME532>3.0.CO;2-N
Connectivity editing for quadrilateral meshes, ACM Transactions on Graphics, vol.30, issue.6, pp.141-2011 ,
Almost Isometric Mesh Parameterization through Abstract Domains, IEEE Transactions on Visualization and Computer Graphics, vol.16, issue.4, pp.621-635, 2010. ,
DOI : 10.1109/TVCG.2009.96
LayTracks: a new approach to automated geometry adaptive quadrilateral mesh generation using medial axis transform, Proceedings of the International Meshing Roundtable, pp.239-250, 2000. ,
DOI : 10.1002/nme.1063
Periodic global parameterization, ACM Transactions on Graphics, vol.25, issue.4, pp.1460-1485, 2006. ,
URL : https://hal.archives-ouvertes.fr/inria-00104853
Geometry-aware direction field processing, ACM Transactions on Graphics, vol.29, issue.1, 2009. ,
DOI : 10.1145/1640443.1640444
URL : https://hal.archives-ouvertes.fr/inria-00547716
N-symmetry direction field design, ACM Transactions on Graphics, vol.27, issue.2, 2008. ,
DOI : 10.1145/1356682.1356683
URL : https://hal.archives-ouvertes.fr/inria-00331900
A generic software design for Delaunay refinement meshing, Computational Geometry, vol.38, issue.1-2, pp.100-110, 2007. ,
DOI : 10.1016/j.comgeo.2006.11.008
URL : https://hal.archives-ouvertes.fr/inria-00097697
Adaptive mesh coarsening for quadrilateral and hexahedral meshes. Finite Elements in Analysis and Design, pp.17-32, 2010. ,
Delaunay refinement algorithms for triangular mesh generation, Computational Geometry, vol.22, issue.1-3, pp.21-74, 2002. ,
DOI : 10.1016/S0925-7721(01)00047-5
Quadrilateral meshing with directionality control through the packing of square cells, Proceedings of the International Meshing Roundtable, pp.61-75, 1998. ,
Anisotropic mesh transformations and optimal error control, Applied Numerical Mathematics, vol.14, issue.1-3, pp.183-198, 1992. ,
DOI : 10.1016/0168-9274(94)90025-6
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.31.5583
Practical quad mesh simplification, Computer Graphics Forum, vol.46, issue.1-2, pp.407-418, 2010. ,
DOI : 10.1111/j.1467-8659.2009.01610.x
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.230.8787
Simple quad domains for field aligned mesh parametrization, ACM Transactions on Graphics, vol.30, issue.6, p.2011 ,
CGAL User and Reference Manual. CGAL Editorial Board, 4.0 edition, 2012. (Non cité.) :eb-12 :eb-12, pp.12-12 ,
Interactive Quadrangulation with Reeb Atlases and Connectivity Textures, IEEE Transactions on Visualization and Computer Graphics, vol.18, issue.10, pp.1650-1663 ,
DOI : 10.1109/TVCG.2011.270
URL : https://hal.archives-ouvertes.fr/hal-01211169
Inspired quadrangulation, Computer-Aided Design, vol.43, issue.11, pp.1516-1526 ,
DOI : 10.1016/j.cad.2011.08.020
URL : https://hal.archives-ouvertes.fr/hal-01211129
Designing quadrangulations with discrete harmonic forms, Symposium on Geometry Processing, pp.201-210, 2006. ,
Approximated Centroidal Voronoi Diagrams for Uniform Polygonal Mesh Coarsening, Computer Graphics Forum, vol.26, issue.2, pp.381-390, 2004. ,
DOI : 10.1109/TVCG.2004.1260763
URL : https://hal.archives-ouvertes.fr/hal-00534535
Generic Remeshing of 3D Triangular Meshes with Metric-Dependent Discrete Voronoi Diagrams, IEEE Transactions on Visualization and Computer Graphics, vol.14, issue.2, pp.369-381, 2008. ,
DOI : 10.1109/TVCG.2007.70430
URL : https://hal.archives-ouvertes.fr/hal-00537025
Quadrilateral meshing with anisotropy and directionality control via close packing of rectangular cells, Proceedings of the International Meshing Roundtable, pp.227-238, 2000. ,
A global minimization-based, automatic quadrilateral meshing algorithm, Proceedings of the International Meshing Roundtable, pp.87-103, 1998. ,
A wave-based anisotropic quadrangulation method, ACM Transactions on Graphics, vol.291188, issue.4, pp.1-118, 2010. ,
DOI : 10.1145/1778765.1778855
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.676.3193
