Acoustic Model Structuring for Improving Automatic Speech Recognition Performance - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2014
Structuration du modèle acoustique pour améliorer les performances de la reconnaissance automatique de la parole
Arseniy Gorin
  • Fonction : Auteur
  • PersonId : 767294
  • IdRef : 182505596
This thesis focuses on acoustic model structuring for improving HMM-based automatic speech recognition. The structuring relies on unsupervised clustering of speech utterances of the training data in order to handle speaker and channel variability. The idea is to split the data into acoustically similar classes. In conventional multi-modeling (or class-based) approach, separate class-dependent models are built via adaptation of a speaker-independent model. When the number of classes increases, less data becomes available for the estimation of the class-based models, and the parameters are less reliable. One way to handle such problem is to modify the classification criterion applied on the training data, allowing a given utterance to belong to more than one class. This is obtained by relaxing the classification decision through a soft margin. This is investigated in the first part of the thesis. In the main part of the thesis, a novel approach is proposed that uses the clustered data more efficiently in a class-structured GMM. Instead of adapting all HMM-GMM parameters separately for each class of data, the class information is explicitly introduced into the GMM structure by associating a given density component with a given class. To efficiently exploit such structured HMM-GMM, two different approaches are proposed. The first approach combines class-structured GMM with class-dependent mixture weights. In this model the Gaussian components are shared across speaker classes, but they are class-structured, and the mixture weights are class-dependent. For decoding an utterance, the set of mixture weights is selected according to the estimated class. In the second approach, the mixture weights are replaced by density component transition probabilities. The approaches proposed in the thesis are analyzed and evaluated on various speech data, which cover different types of variability sources (age, gender, accent and noise).
Cette thèse se concentre sur la structuration du modèle acoustique pour améliorer la reconnaissance de la parole par modèle de Markov. La structuration repose sur l’utilisation d’une classification non supervisée des phrases du corpus d’apprentissage pour tenir compte des variabilités dues aux locuteurs et aux canaux de transmission. L’idée est de regrouper automatiquement les phrases prononcées en classes correspondant à des données acoustiquement similaires. Pour la modélisation multiple, un modèle acoustique indépendant du locuteur est adapté aux données de chaque classe. Quand le nombre de classes augmente, la quantité de données disponibles pour l’apprentissage du modèle de chaque classe diminue, et cela peut rendre la modélisation moins fiable. Une façon de pallier ce problème est de modifier le critère de classification appliqué sur les données d’apprentissage pour permettre à une phrase d’être associée à plusieurs classes. Ceci est obtenu par l’introduction d’une marge de tolérance lors de la classification ; et cette approche est étudiée dans la première partie de la these. L’essentiel de la thèse est consacré à une nouvelle approche qui utilise la classification automatique des données d’apprentissage pour structurer le modèle acoustique. Ainsi, au lieu d’adapter tous les paramètres du modèle HMM-GMM pour chaque classe de données, les informations de classe sont explicitement introduites dans la structure des GMM en associant chaque composante des densités multigaussiennes avec une classe. Pour exploiter efficacement cette structuration des composantes, deux types de modélisations sont proposés. Dans la première approche on propose de compléter cette structuration des densités par des pondérations des composantes gaussiennes dépendantes des classes de locuteurs. Pour cette modélisation, les composantes gaussiennes des mélanges GMM sont structurées en fonction des classes et partagées entre toutes les classes, tandis que les pondérations des composantes des densités sont dépendantes de la classe. Lors du décodage, le jeu de pondérations des gaussiennes est sélectionné en fonction de la classe estimée. Dans une deuxième approche, les pondérations des gaussiennes sont remplacées par des matrices de transition entre les composantes gaussiennes des densités. Les approches proposées dans cette thèse sont analysées et évaluées sur différents corpus de parole qui couvrent différents sources de variabilité (âge, sexe, accent et bruit).
thesis_agorin_ASR_noblank.pdf (1.7 Mo) Télécharger le fichier
thesis_agorin_ASR.pdf (1.44 Mo) Télécharger le fichier
tel-01751053 , version 2 (12-01-2015)
tel-01751053 , version 1 (29-03-2018)
  • HAL Id : tel-01751053 , version 2
Arseniy Gorin. Acoustic Model Structuring for Improving Automatic Speech Recognition Performance. Sound [cs.SD]. Université de Lorraine, 2014. English. ⟨NNT : 2014LORR0161⟩. ⟨tel-01751053v2⟩
383 Consultations
834 Téléchargements
