Abstract : In this thesis, we propose two different techniques for verifying security protocols that manipulate lists of
unbounded length.
In the first part of the thesis, we present a simple technique for proving secrecy properties for protocols that
manipulate list elements in a uniform way, for an unbounded number of sessions. More specifically, this
technique relies on the Horn clause approach used in the automatic verifier ProVerif: we show that if a protocol
is proven secure by our technique with lists of length one, then it is secure for lists of unbounded length.
Interestingly, this theorem relies on approximations made by our verification technique: in general, secrecy for
lists of length one does not imply secrecy for lists of unbounded length.
The second technique presented in this thesis automatically proves secrecy and authentication properties for
security protocols that manipulate different list elements in different ways. This result is achieved by extending
the Horn clause approach of the automatic protocol verifier ProVerif. We extend the Horn clauses to be able to
represent lists of unbounded length. We adapt the resolution algorithm to handle the new class of Horn clauses,
and prove the soundness of this new algorithm. We have implemented our algorithm and successfully tested
it on several protocol examples, including XML protocols coming from web services. Finally, we present an
extension of the input language of ProVerif, a variant of the applied pi calculus, to model protocols with lists of
unbounded length, give its formal semantics, and translate it automatically to Horn clauses.
Résumé : Dans cette thèse, nous proposons deux techniques différentes pour la vérification de protocoles de sécurité qui
utilisent des listes de taille arbitraire.
Dans la première partie de la thèse, nous présentons une technique simple pour vérifier le secret pour des
protocoles qui traitent tous les éléments des listes de façon uniforme, pour un nombre non borné de sessions.
Plus précisément, cette technique est fondée sur l’approche à base de clauses de Horn utilisée par le vérificateur
automatique ProVerif. Nous montrons que si un protocole est prouvé sûr par notre technique avec des listes de
longueur un, alors il est sûr pour des listes de longueur arbitraire. Curieusement, ce théorème repose sur des
approximations faites par notre technique de vérification : en général, le secret pour des listes de longueur un
n’implique pas le secret pour des listes de taille arbitraire.
La deuxième technique présentée dans cette thèse permet de prouver automatiquement des propriétés de secret
et d’authentification pour des protocoles qui traitent des éléments différents de façon différente. Ce résultat est
obtenu en étendant l’approche par clauses de Horn utilisée par ProVerif. Nous étendons la syntaxe des clauses
de Horn pour représenter des listes de taille arbitraire. Nous adaptons l’algorithme de résolution pour qu’il traite
la nouvelle classe de clauses de Horn et nous prouvons la correction de cet algorithme. Nous avons implémenté
notre algorithme et nous l’avons testé avec succès sur plusieurs protocoles, en particulier sur des protocoles
pour les services web. Finalement, nous présentons une extension du langage d’entrée de ProVerif, une variante
du pi calcul appliqué, pour modéliser les protocoles avec des listes de longueur non bornée, nous en donnons
la sémantique et une traduction automatique en clauses de Horn.
