57 2.6.1 Preliminaries and main result, p.60 ,
67 2.7.1 The non-linear coupled problem, p.68 ,
69 2.8.1 Convergence study in a two-dimensional test-case 70 2.8.2 Pressure wave propagation in a straight tube, 72 2.8.3 Blood ow in an abdominal aortic, p.78 ,
103 3.5.1 The non-linear coupled problem, p.104 ,
105 3.6.1 Numerical study in a two-dimensional test-case 105 3.6.2 Pressure wave propagation in a straight tube, p.115 ,
Convergence analysis of the generalized Robin-Neuman explicit coupling schemes The results presented in this chapter lead to the manuscript Convergence analysis for a class of explicit coupling schemes in incompressible uid-structure interaction ,
Robin based semi-implicit coupling in uid-structure interaction: Stability analysis and numerics ,
Fluid???structure interaction and multi-body contact: Application to aortic valves, Computer Methods in Applied Mechanics and Engineering, vol.198, issue.45-46, pp.45-4636033612, 2009. ,
DOI : 10.1016/j.cma.2008.09.012
URL : https://hal.archives-ouvertes.fr/inria-00542238
Fluid???structure partitioned procedures based on Robin transmission conditions, Journal of Computational Physics, vol.227, issue.14, p.70277051, 2008. ,
DOI : 10.1016/j.jcp.2008.04.006
Modular vs. non-modular preconditioners for uid-structure systems with large added-mass eect, Comput. Methods Appl. Mech. Engrg, vol.197, pp.49-5042164232, 2008. ,
Splitting Methods Based on Algebraic Factorization for Fluid-Structure Interaction, SIAM Journal on Scientific Computing, vol.30, issue.4, pp.1778-1805, 2008. ,
DOI : 10.1137/070680497
A convergence study of a new partitioned uidstructure interaction algorithm based on ctitious mass and damping, J. Comput. Phys, vol.231, issue.2, p.629652, 2012. ,
Isogeometric uidstructure interaction: theory, algorithms, and computations, Comput. Mech, vol.43, issue.1, p.337, 2008. ,
A nite element pressure gradient stabilization for the Stokes equations based on local projections, Calcolo, vol.38, issue.4, p.173199, 2001. ,
Sequential parameter estimation for uidstructure problems: application to hemodynamics, Int. J. Numer. Methods Biomed. Eng, vol.28, issue.4, p.434455, 2012. ,
Models and Finite Elements for Thin-Walled Structures, chapter 3, 2004. ,
Numerical stability of the nite element immersed boundary method, Math. Models Methods Appl. Sci, vol.17, issue.10, pp.1479-1505, 2007. ,
The mathematical theory of nite element methods, Texts in Applied Mathematics, vol.15, 2008. ,
On the stabilization of nite element approximations of the Stokes equations, Notes Numer. Fluid Mech, vol.10, p.1119, 1984. ,
A modular, operatorsplitting scheme for uid-structure interaction problems with thick structures ,
Fluid-structure interaction in blood ow capturing non-zero longitudinal structure displacement ,
Stabilized explicit coupling for uid-structure interaction using Nitsche's method, C. R. Math. Acad. Sci. Paris, issue.8, pp.345467-472, 2007. ,
Galerkin nite element methods with symmetric pressure stabilization for the transient Stokes equations: stability and convergence analysis, SIAM J. Numer. Anal, vol.47, issue.1, p.409439, 2008. ,
Stabilization of explicit coupling in uidstructure interaction involving uid incompressibility, Comput. Methods Appl. Mech. Engrg, vol.198, pp.5-8766784, 2009. ,
An untted Nitsche method for incompressible uid-structure interaction using overlapping meshes, Comput. Methods Appl. Mech. Engrg, 2014. ,
Explicit strategies for incompressible uidstructure interaction problems: Nitsche type mortaring versus Robin-Robin coupling, Internat. J. Numer. Methods Engrg, vol.97, issue.10, p.739758, 2014. ,
DOI : 10.1002/nme.4607
URL : https://hal.inria.fr/hal-00819948/file/RR-8296.pdf
Explicit strategies for incompressible uidstructure interaction problems: Nitsche type mortaring versus RobinRobin coupling, Int. J. Num. Meth. Engrg, vol.97, issue.10, p.739758, 2014. ,
Continuous interior penalty nite element method for Oseen's equations, SIAM J. Numer. Anal, vol.44, issue.3, p.12481274, 2006. ,
Edge stabilization for the generalized Stokes problem: A continuous interior penalty method, Computer Methods in Applied Mechanics and Engineering, vol.195, issue.19-22, pp.19-2223932410, 2006. ,
DOI : 10.1016/j.cma.2005.05.009
Modeling viscoelastic behavior of arterial walls and their interaction with pulsatile blood ow, SIAM J. Appl. Math, vol.67, issue.1, p.164193, 2006. ,
Added-mass eect in the design of partitioned algorithms for uid-structure problems, Comput. Methods Appl. Mech. Engrg, vol.194, issue.4244, p.45064527, 2005. ,
The Finite Element Analysis of Shells -Fundamentals, 2011. ,
URL : https://hal.archives-ouvertes.fr/hal-00839738
MODELING OF THE INCLUSION OF A REINFORCING SHEET WITHIN A 3D MEDIUM, Mathematical Models and Methods in Applied Sciences, vol.13, issue.04, p.573595, 2003. ,
DOI : 10.1142/S0218202503002635
URL : https://hal.archives-ouvertes.fr/hal-00839241
A nite element formulation for the Stokes problem allowing equal velocity-pressure interpolation, Comput. Methods Appl. Mech. Engrg, vol.143, pp.3-4373391, 1997. ,
Eulerian formulation and level set models for incompressible uid-structure interaction, M2AN Math. Model. Numer. Anal, vol.42, issue.3, p.471492, 2008. ,
Parallel algorithms for uid-structure interaction problems in haemodynamics, SIAM J. Sci. Comput, vol.33, issue.4, p.15981622, 2011. ,
On the similarity between Dirichlet-Neumann with interface articial compressibility and Robin-Neumann schemes for the solution of uidstructure interaction problems, J. Comput. Phys, vol.230, issue.17, p.63996403, 2011. ,
Performance of partitioned procedures in uid-structure interaction, Comp. & Struct, vol.88, issue.78, p.446457, 2010. ,
Simulation of uid-structure interaction with the interface articial compressibility method ,
Stability of a coupling technique for partitioned solvers in FSI applications, Computers & Structures, vol.86, issue.23-24, pp.23-2422242234, 2008. ,
DOI : 10.1016/j.compstruc.2008.05.005
Fluid???structure algorithms based on Steklov???Poincar?? operators, Computer Methods in Applied Mechanics and Engineering, vol.195, issue.41-43, pp.41-4357975812, 2006. ,
DOI : 10.1016/j.cma.2005.09.029
A computational framework for uid-rigid body interaction: nite element formulation and applications, Comput. Methods Appl. Mech. Engrg, vol.195, pp.13-1616331666, 2006. ,
Stability of discrete liftings, Comptes Rendus Mathematique, vol.337, issue.12, p.337805808, 2003. ,
DOI : 10.1016/j.crma.2003.10.025
Analysis of a linear uidstructure interaction problem, Discrete Contin. Dyn. Syst, vol.9, issue.3, p.633650, 2003. ,
Theory and practice of nite elements, 2004. ,
Eect of baes on a partially lled cubic tank: Numerical simulation and experimental validation, Computers & Structures, vol.87, issue.34, 2009. ,
Provably second-order timeaccurate loosely-coupled solution algorithms for transient nonlinear aeroelasticity, Comput. Methods Appl. Mech. Engrg, p.195, 1718. ,
Coupling schemes for incompressible uid-structure interaction: implicit, semi-implicit and explicit, S eMA J, issue.55, p.59108, 2011. ,
Incremental displacement-correction schemes for the explicit coupling of a thin structure with an incompressible uid, C. R. Math. Acad. Sci. Paris, vol.349, issue.78, p.473477, 2011. ,
Incremental displacement-correction schemes for incompressible uid-structure interaction: stability and convergence analysis, Numer. Math, vol.123, issue.1, p.2165, 2013. ,
Algorithms for uid-structure interaction problems, Cardiovascular mathematics, p.307346, 2009. ,
A projection algorithm for uid-structure interaction problems with strong added-mass eect, C. R. Math. Acad. Sci. Paris, vol.342, issue.4, p.279284, 2006. ,
A projection semi-implicit scheme for the coupling of an elastic structure with an incompressible uid, Int. J. Num. Meth. Engrg, vol.69, issue.4, p.794821, 2007. ,
A fully decoupled scheme for the interaction of a thin-walled structure with an incompressible uid, C. R. Math. Acad. Sci. Paris, vol.351, pp.3-4161164, 2013. ,
Fully decoupled time-marching schemes for incompressible uid/thin-walled structure interaction ,
Second-order time-accurate explicit schemes for the interaction of a thin-walled structure with an incompressible uid, WCCM XI, 2014. ,
Splitting schemes for uid/thin-walled structure interaction with untted meshes, C. R. Math. Acad. Sci. Paris, 2014. ,
A Newton method using exact Jacobians for solving uid-structure coupling, Comp. & Struct, vol.83, p.127142, 2005. ,
Displacement-velocity correction schemes for incompressible uid-structure interaction, C. R. Math. Acad. Sci. Paris, vol.349, pp.17-1810111015, 2011. ,
Convergence analysis for a class of splitting schemes in incompressible uid-structure interaction, 2015. ,
Préconditionnement d'algorithmes d'interaction uide-structure, 10e colloque national en calcul des structures, 2011. ,
Explicit Robin-Neumann schemes for the coupling of incompressible uids with thin-walled structures ,
Generalized Robin-Neumann explicit coupling schemes for incompressible uid-structure interaction: stability analysis and numerics, Internat. J. Numer. Methods Engrg, vol.101, issue.3, 2015. ,
A coupled momentum method for modeling blood ow in threedimensional deformable arteries, Comput. Methods Appl. Mech. Engrg, vol.195, pp.41-4356855706, 2006. ,
On the coupling of 3D and 1D Navier-Stokes equations for ow problems in compliant vessels ,
of Modeling, Simulation and Applications, Cardiovascular Mathematics . Modeling and simulation of the circulatory system, 2009. ,
Articial added mass instabilities in sequential staggered coupling of nonlinear structures and incompressible viscous ows, Comput. Methods Appl. Mech. Engrg, vol.196, issue.7, p.12781293, 2007. ,
Parallel multilevel solution of nonlinear shell structures, Computer Methods in Applied Mechanics and Engineering, vol.194, issue.21-24, pp.21-2425132533, 2005. ,
DOI : 10.1016/j.cma.2004.07.043
Truly monolithic algebraic multigrid for uid-structure interaction, Int. J. Numer. Meth. Engng, vol.85, issue.8, p.9871016, 2011. ,
A quasi-Newton algorithm based on a reduced model for uid-structure interactions problems in blood ows, Math. Model ,
Finite element methods for Navier-Stokes equations, 1986. ,
DOI : 10.1007/978-3-642-61623-5
An overview of projection methods for incompressible ows, Comput. Methods Appl. Mech. Engrg, vol.195, pp.44-476011, 2006. ,
Stable loosely-coupledtype algorithm for uid-structure interaction in blood ow, J. Comp. Phys, vol.228, issue.18, p.69166937, 2009. ,
Treating inhomogeneous essential boundary conditions in nite element methods and the calculation of boundary stresses ,
Nitsche's method for interface problems in computational mechanics, GAMM-Mitt, vol.28, issue.2, p.183206, 2005. ,
New development in freefem++, Journal of Numerical Mathematics, vol.20, issue.3-4, p.251265, 2012. ,
DOI : 10.1515/jnum-2012-0013
Fluid-structure interaction in internal physiological ows, Annu. Rev. Fluid Mech, vol.43, p.141162, 2011. ,
Finite-Element Approximation of the Nonstationary Navier???Stokes Problem. Part IV: Error Analysis for Second-Order Time Discretization, SIAM Journal on Numerical Analysis, vol.27, issue.2, p.353384, 1990. ,
DOI : 10.1137/0727022
Numerical methods for uid-structure interactiona review, Commun. Comput. Phys, vol.12, issue.2, p.337377, 2012. ,
The nite element method A method for partitioned uid-structure interaction computation of ow in arteries, Medical Engineering & Physics, issue.7, p.30917923, 1987. ,
Variational Methods for Time-Dependent Wave Propagation Problems, Topics in Computational Wave Propagation, p.201264, 2003. ,
DOI : 10.1007/978-3-642-55483-4_6
Mechanical Models of Artery Walls, Archives of Computational Methods in Engineering, vol.287, issue.3, p.136, 2008. ,
DOI : 10.1007/s11831-007-9015-5
A solution for the incompressibility dilemma in partitioned uid-structure interaction with pure Dirichlet uid domains, Comput. Mech, vol.38, p.417429, 2006. ,
Fixed-point uid-structure interaction solvers with dynamic relaxation, Comp. Mech, vol.43, issue.1, p.6172, 2008. ,
Three-dimensional computational uid dynamics modeling of alterations in coronary wall shear stress produced by stent implantation, Ann. Biomed. Eng, vol.31, p.972980, 2003. ,
Coupling schemes and untted mesh methods for uid-structure interaction ,
Numerical methods for nonlinear three-dimensional elasticity, Handbook of numerical analysis, p.465622, 1994. ,
DOI : 10.1016/S1570-8659(05)80018-3
Fluid structure interaction with large structural displacements, Comput. Meth. Appl. Mech. Engrg, vol.190, p.30393067, 2001. ,
Three-dimensional incompressible viscoelasticity in large strains: formulation and numerical approximation, Comput. Methods Appl. Mech. Engrg, vol.109, pp.3-4233258, 1993. ,
Numerical Simulation of Sailing Boats: Dynamics, FSI, and Shape Optimization, Variational Analysis and Aerospace Engineering: Mathematical Challenges for Aerospace Design, p.339377, 2012. ,
DOI : 10.1007/978-1-4614-2435-2_15
Kinematic splitting algorithm for uidstructure interaction in hemodynamics, Comput. Methods Appl. Mech. Engrg, vol.265, issue.1, p.83106, 2013. ,
Analysis of coupled models for uid-structure interaction of internal ows, Cardiovascular mathematics, p.279306, 2009. ,
External tissue support and uid-structure simulation in blood ows, Biomech. Model. Mechanobiol, vol.11, p.118, 2012. ,
Interactions uide structure en grands déplacements. Résolution numérique et application aux composants hydrauliques automobiles, 1996. ,
An ecient preconditioner for monolithically-coupled large-displacement uid-structure interaction problems with pseudo-solid mesh updates, J. Comput. Phys, issue.21, p.23173157334, 2012. ,
Existence of a weak solution to a nonlinear uidstructure interaction problem modeling the ow of an incompressible, viscous uid in a cylinder with deformable walls, Arch. Rational Mech. Anal, vol.207, p.919968, 2013. ,
A fast method for solving uid-structure interaction problems numerically, Internat. J. Numer. Methods Fluids, issue.10, p.6011491172, 2009. ,
Über ein Variationsprinzip zur Lösung von Dirichlet-Problemen bei Verwendung von Teilräumen ,
DOI : 10.1007/bf02995904
Numerical approximation of uid-structure interaction problems with application to haemodynamics, 2001. ,
An eective uid-structure interaction formulation for vascular dynamics by generalized Robin conditions, SIAM J. Sci. Comput, vol.30, issue.2, p.731763, 2008. ,
Partitioned Algorithms for Fluid-Structure Interaction Problems in Haemodynamics, Milan Journal of Mathematics, vol.4, issue.4, p.443467, 2012. ,
DOI : 10.1007/s00032-012-0194-7
Fluid-structure interactions: crossow-induced instabilities, 2011. ,
DOI : 10.1017/CBO9780511760792
Stabilization of staggered solution procedures for uid-structure interaction analysis ,
Computational Methods for Fluid-Structure Interaction Problems, American Society of Mechanical Engineers, vol.26, p.95124, 1977. ,
A variational approach for estimating the compliance of the cardiovascular tissue. An inverse uid-structure interaction problem, SIAM J. Sci. Comput, vol.33, issue.3, p.11811211, 2011. ,
The immersed boundary method, Acta Numer, vol.11, p.479517, 2002. ,
Explicit/implicit uid/structure staggered procedures with a structural predictor and uid subcycling for 2D inviscid aeroelastic simulations, Internat . J. Numer. Methods Fluids, issue.10, p.2512071226, 1997. ,
A semi-implicit approach for uid-structure interaction based on an algebraic fractional step method, Math. Models Methods Appl. Sci, vol.17, issue.6, p.957983, 2007. ,
Evolution of the wall shear stresses during the progressive enlargement of symmetric abdominal aortic aneurysms, Journal of Fluid Mechanics, vol.560, 1951. ,
DOI : 10.1017/S002211200600036X
URL : https://hal.archives-ouvertes.fr/hal-01023355
The defect correction principle and discretization methods, Numerische Mathematik, vol.11, issue.4, p.425443, 1978. ,
DOI : 10.1007/BF01432879
Finite-Element Modeling of the Hemodynamics of Stented Aneurysms, Journal of Biomechanical Engineering, vol.126, issue.3, p.382387, 2004. ,
DOI : 10.1115/1.1762900
A nonconforming nite element method for uidstructure interaction problems, Comput. Methods Appl. Mech. Engrg, vol.195109, pp.17-1820882099, 2006. ,
Computational modeling of blood ow in the aortainsights into eccentric dilatation of the ascending aorta after surgery for coarctation ,
Computational methods for parachute uidstructure interactions, Arch. Comput. Methods Eng, vol.19, p.125169, 2012. ,
Finite element methods for uid dynamics with moving boundaries and interfaces, Arch. Comput. Methods Engrg, vol.8, p.83130, 2001. ,
Galerkin nite element methods for parabolic problems, 2006. ,
Stability and instability in the computation of ows with moving immersed boundaries: a comparison of three methods ,
Proposal for numerical benchmarking of uid-structure interaction between an elastic ob ject and laminar incompressible ow, Fluidstructure interaction, p.371385, 2006. ,
Viscoelastic models for passive arterial wall dynamics, Adv. Appl. Math. Mech, vol.1, issue.2, p.151165, 2009. ,
