Theses
Inégalités d’oracle et mélanges
Lucie Montuelle 1, 2
2 SELECT - Model selection in statistical learning
Inria Saclay - Ile de France, LMO - Laboratoire de Mathématiques d'Orsay
Abstract : This manuscript focuses on two functional estimation problems. A non asymptotic guarantee of the proposed estimator’s performances is provided for each problem through an oracle inequality. In the conditional density estimation setting, mixtures of Gaussian regressions with exponential weights depending on the covariate are used. Model selection principle through penalized maximum likelihood estimation is applied and a condition on the penalty is derived. If the chosen penalty is proportional to the model dimension, then the condition is satisfied. This procedure is accompanied by an algorithm mixing EM and Newton algorithm, tested on synthetic and real data sets. In the regression with sub-Gaussian noise framework, aggregating linear estimators using exponential weights allows to obtain an oracle inequality in deviation, thanks to PAC-bayesian technics. The main advantage of the proposed estimator is to be easily calculable. Furthermore, taking the infinity norm of the regression function into account allows to establish a continuum between sharp and weak oracle inequalities.
Document type :
Theses
Complete list of metadata
Cited literature [138 references]  Display  Hide  Download
https://hal.inria.fr/tel-01109103
Contributor : Lucie Montuelle Connect in order to contact the contributor
Submitted on : Saturday, January 24, 2015 - 3:51:46 PM
Last modification on : Sunday, June 26, 2022 - 12:02:48 PM
Long-term archiving on: : Friday, September 11, 2015 - 9:06:11 AM
Identifiers
  • HAL Id : tel-01109103, version 1
Citation
Lucie Montuelle. Inégalités d’oracle et mélanges. Statistiques [math.ST]. Université Paris-Sud, 2014. Français. ⟨tel-01109103⟩
Share
Metrics
Record views
192
Files downloads
307
