Optimización Discreta y Grafos: Teoría, Algoritmos y Aplicaciones, Sistemas Complejos de Ingeniería Departamento de Ingeniería Industrial ,
Special Session Speaker (Optimization problems in real-life settings) ,
When trees collide, Proceedings of the twenty-third annual ACM symposium on Theory of computing , STOC '91, pp.440-456, 1995. ,
DOI : 10.1145/103418.103437
Parallelism and evolutionary algorithms, IEEE Transactions on Evolutionary Computation, vol.6, issue.5, pp.443-462, 2002. ,
DOI : 10.1109/TEVC.2002.800880
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.64.430
Efficient parallel LAN/WAN algorithms for optimization. The mallba project, Parallel Computing, vol.32, issue.5-6, pp.5-6, 2006. ,
DOI : 10.1016/j.parco.2006.06.007
Parallel metaheuristics: recent advances and new trends, International Transactions in Operational Research, vol.39, issue.3, pp.1-48, 2013. ,
DOI : 10.1111/j.1475-3995.2012.00862.x
Handbook of evolutionary computation, p.49, 1997. ,
A Dual-Based Algorithm for Multi-Level Network Design, Management Science, vol.40, issue.5, pp.567-581, 1930. ,
DOI : 10.1287/mnsc.40.5.567
Modeling and Heuristic Worst-Case Performance Analysis of the Two-Level Network Design Problem, Management Science, vol.40, issue.7, pp.846-867, 1994. ,
DOI : 10.1287/mnsc.40.7.846
Designing Hierarchical Survivable Networks, Operations Research, vol.46, issue.1, pp.116-136, 1998. ,
DOI : 10.1287/opre.46.1.116
URL : http://dspace.mit.edu/bitstream/1721.1/5115/1/OR-291-94.pdf
-Connected Spanning Networks, SIAM Journal on Discrete Mathematics, vol.3, issue.3, pp.320-329, 1921. ,
DOI : 10.1137/0403027
URL : https://hal.archives-ouvertes.fr/in2p3-01321555
Designing Backbone Networks using the Generalized Steiner Problem, IEEE Computer Society Proceedings of 7th IEEE International Workshop on the Design of Reliable Communication Networks, p.23, 2009. ,
Multi-overlay network planning by applying a variable neighbourhood search approach. Master's thesis, Engineering Faculty, p.130, 2010. ,
A Branch-and- Bound Algorithm to Solve a Multi-level Network Optimization Problem, Journal of Mathematical Modelling and Algorithms, vol.2, issue.1, pp.37-56, 2003. ,
DOI : 10.1023/A:1023670814370
Handbook of genetic algorithms. van Nostrand Reinhold, p.49, 1991. ,
Hybrid local search for the Steiner problem in graphs, Extended Abstracts of the 4th Metaheuristics International Conference, pp.429-433, 2001. ,
Augmentation Problems, Society for Industrial and Applied Mathematics (SIAM), vol.5, issue.4, pp.653-665, 1976. ,
A probabilistic heuristic for a computationally difficult set covering problem, Operations Research Letters, vol.8, issue.2, pp.67-71, 1989. ,
DOI : 10.1016/0167-6377(89)90002-3
Greedy Randomized Adaptive Search Procedures, Journal of Global Optimization, vol.68, issue.2, pp.109-133, 1995. ,
DOI : 10.1007/BF01096763
Grasp: An Annotated Bibliography, p.51, 2004. ,
DOI : 10.1007/978-1-4615-1507-4_15
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.194.4301
Computers and intractability: A guide to the theory of np-completeness, p.129, 1979. ,
Tabu search and adaptive memory programing ? Advances , applications and challenges, Interfaces in Computer Science and Operations Research, pp.1-75, 1996. ,
DOI : 10.1007/978-1-4615-4102-8_1
Optimal design of a distributed network with two-level hierarchical structure, European Journal of Operational Research, vol.62, issue.1, pp.105-115, 1992. ,
Lightpath routing and capacity assignment for survivable IP-over-WDM networks. Design of Reliable Communication Networks, pp.37-44, 2009. ,
Single-Layer Cuts for Multi-Layer Network Design Problems, Selected proceedings of the 9th INFORMS Telecommunications Conference, pp.1-23, 2008. ,
DOI : 10.1007/978-0-387-77780-1_1
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.86.6325
Two design problems for the IP/MPLS over WDM networks, IEEE Xplore, vol.27, p.28, 2005. ,
A parallel GRASP for the Steiner tree problem in graphs using a hybrid local search strategy, Journal of Global Optimization, vol.17, issue.1/4, pp.267-283, 2000. ,
DOI : 10.1023/A:1026546708757
A GRASP for the biquadratic assignment problem, European Journal of Operational Research, vol.105, issue.3, pp.613-621, 1998. ,
DOI : 10.1016/S0377-2217(97)00083-0
Minimum-weight two-connected spanning networks, Mathematical Programming, pp.153-171, 1990. ,
Multicommodity flows in planar graphs, Journal of Combinatorial Theory, Series B, vol.31, issue.1, pp.75-81, 1981. ,
DOI : 10.1016/S0095-8956(81)80012-3
Two- Layer Network Design by Branch-and-Cut featuring MIP-based Heuristics, p.25, 2006. ,
A Greedy Randomized Adaptive Search Procedure for the feedback vertex set problem, Journal of Combinatorial Optimization, vol.2, issue.4, pp.399-412, 1999. ,
DOI : 10.1023/A:1009736921890
Integer optimization applied to the design of robust minimum cost multi-layer networks. Master's thesis, Engineering Faculty, p.108, 2011. ,
Computing approximate solutions of the maximum covering problem using GRASP, Journal of Heuristics, vol.4, issue.2, pp.161-171, 1998. ,
DOI : 10.1023/A:1009677613792
A GRASP for graph planarization, Journal of Heuristics, vol.4, issue.2, pp.161-171, 1998. ,
Greedy Randomized Adaptive Search Procedures, pp.51-130, 2003. ,
DOI : 10.1007/0-306-48332-7_188
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.106.2098
A Hybrid GRASP with Perturbations for the Steiner Problem in Graphs, INFORMS Journal on Computing, vol.14, issue.3, pp.228-246, 2002. ,
DOI : 10.1287/ijoc.14.3.228.116
A Parallel Evolutionary Algorithm for Multilayered Robust Network Design, 2012 Seventh International Conference on P2P, Parallel, Grid, Cloud and Internet Computing, pp.291-296, 2012. ,
DOI : 10.1109/3PGCIC.2012.4
Using metaheuristics for planning resilient and cost-effective multilayer networks, 2013 5th International Congress on Ultra Modern Telecommunications and Control Systems and Workshops (ICUMT), pp.90-96, 2013. ,
DOI : 10.1109/ICUMT.2013.6798427
Using GRASP for designing a layered network: a real IP/MPLS over DWDM application case, International Journal of Metaheuristics, vol.2, issue.4, pp.392-414, 2013. ,
DOI : 10.1504/IJMHEUR.2013.058474
Optimal Design of a Multi-Layer Network. An IP/MPLS Over DWDM Application Case. Current Developments in Optical Fiber Technology, pp.3-20, 2013. ,
Optimal design of an IP/MPLS over DWDM network. Pesquisa Operacional -Special Issue from CLAIO, p.32, 2012. ,
Survivable IP/MPLS-Over-WSON Multilayer Network Optimization, Journal of Optical Communications and Networking, vol.3, issue.8, pp.629-640, 1928. ,
DOI : 10.1364/JOCN.3.000629
URL : http://hdl.handle.net/2117/13086
Introduction to graph theory, p.44, 1995. ,
Steiner problem in networks: A survey, Networks, vol.19, issue.2, pp.129-167, 1923. ,
DOI : 10.1002/net.3230170203
