Identification des risques de perte de biodiversité face aux pressions anthropiques et au changement climatique à l’horizon 2100 : Application de la conservation dynamique au territoire des Alpes-Maritimes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2014
Identification of Biodiversity loss Risk at the end of XXIst Century due to anthropic pressures and climatic change : French Riviera territory application of dynamical conservation
The work aims at understanding how the land transformation and climatic change synergy could affect the Alpes-Maritimes biodiversity. This thesis contains four chapters. In the first chapter, the purpose is to provide the conceptual basis and the framework that support the scientific foundations of this thesis and the main conceptual definitions of the studied problematic. In the second chapter, the purpose is to study the artificialization process in the French Riviera area, its probable potential dispersion, the conditions and the factors involved in the phenomenon in order to give an intuitively understanding of the landscape transformation and their principal trend. The landscape transformation of the last 40 years has been studied with the aim of identifying the spatial transition rules that have been introduced in the cellular automata model. We present a synthesis of landscape transformation in the French Riviera up to 2050 and 2100. The resulting scenarios provide information about future urban expansion according to historic behavior and the evolutionary patterns. The results of this part show that urban surfaces could double by 2050 and triplicated by 2100 compared with 2011. In the third chapter we assess the biodiversity loss according to land use dynamic and climate change. We first defined the ecosystem diversity by the landscape units. The landscape units are composed by the different ecological factors that have had an influence on ecosystems repartition like geomorphology, soil, climate, and vegetation. Then, we studied how landscape transformation could affect the biodiversity in the future by the spatial superposition of the first and second chapter results. Next, we realized a bioclimatic calibration for the landscape units with the aim of understanding the limits of ecological tolerance to the climatic conditions and the different ecological conditions like geomorphology, soil, and aspect. The bioclimatic calibration of the landscape units has allowed the definition of climatic change impact on ecosystem biodiversity for 2050 and 2100.The synergy between climatic change impact and landscape transformation shows that almost 30% (68 ecosystem expressions) of Alpes-Maritimes biodiversity could be affected at the end of the XXIst century, and at least five ecosystems expressions could disappear for 2100 due to both forces or some of these driving forces.In the fourth chapter we propose a method that allows the integration of climatic change impacts and landscape transformation on conservation process and politic assessment. Moreover, this chapter proposes the possibility to integrate both phenomena into the ecological networks structuration, especially into “Trame verte et bleue” in France.
L'objectif est de comprendre comment la synergie entre la transformation du territoire et le changement climatique pourra affecter la biodiversité des Alpes-Maritimes à l'horizon 2100. Cette thèse comprend quatre chapitres. Dans le premier chapitre sont présentées les notions, les bases théoriques et conceptuelles ainsi que la problématique générale de recherche. Le deuxième chapitre est consacré à l'étude des processus d'artificialisation et de transformation territoriale. Dans cette partie sont évalués le processus de dispersion ainsi que les facteurs qui interviennent dans les phénomènes d'artificialisation du territoire et les tendances futures de changement sur les Alpes-Maritimes. Les règles de transition spatiale ont été extraites à partir de l'étude de la transformation territoriale des 40 dernières années pour comprendre les trajectoires de changement, mais aussi dans le but d'avoir une base de connaissances solide permettant de faire la simulation par automate cellulaire. A partir de ces connaissances et de l'interprétation des règles de transition sont élaborés les scénarios de transformation future du paysage aux horizons 2050 et 2100. Les résultats montrent la possible expansion de l'artificialisation selon le comportement et les tendances historiques observés sur le territoire. Les résultats de ce chapitre montrent que les surfaces artificielles pourraient doubler pour 2050, et tripler pour 2100 par rapport à leur occupation actuelle. Le troisième chapitre concerne l'évaluation de la perte de biodiversité selon les pressions anthropiques et climatiques. La première partie du chapitre trois est dédiée à la définition de la diversité écosystémique à partir des unités du paysage. Pour cette définition ont été considérés les différents facteurs écologiques qui ont une influence sur la répartition des écosystèmes tels que la géomorphologie, le sol, le climat et la végétation. Avec les informations obtenues dans la partie précédente, est étudié l'impact potentiel de la transformation territoriale sur la biodiversité. La deuxième partie de ce chapitre consiste en la réalisation d'un étalonnage bioclimatique des unités du paysage, afin de comprendre les limites écologiques de tolérance des expressions écosystémique aux conditions climatiques et géomorphologiques. Au total sont définies 236 unités du paysage sur lesquelles sont estimés les impacts synergiques de la transformation territoriale et du changement climatique afin d'évaluer les risques de perte de biodiversité vers la fin du siècle. Les résultats montrent que 68 unités du paysage (soit presque 30% de la diversité́ des Alpes-Maritimes) seront affectées par ces deux phénomènes d'ici la fin du XXIème siècle et 5 d'entre elles devraient disparaître, que ce soit en raison du changement climatique ou de la dynamique de l'artificialisation du sol. Le dernier chapitre propose une méthode permettant l'intégration des impacts du changement climatique et des impacts de la transformation territoriale dans les processus de conception et définition de politiques de conservation dynamique de la biodiversité. De plus, ce chapitre propose la possibilité d'intégrer les deux phénomènes dans la conception de réseaux écologiques de conservation, notamment dans le cadre de la Trame verte et bleue.
2014ENMP0026.pdf (41.47 Mo) Télécharger le fichier
tel-01123766 , version 1 (05-03-2015)
tel-01123766 , version 2 (14-02-2016)
  • HAL Id : tel-01123766 , version 2
Guillermo Hinojos Mendoza. Identification des risques de perte de biodiversité face aux pressions anthropiques et au changement climatique à l’horizon 2100 : Application de la conservation dynamique au territoire des Alpes-Maritimes. Architecture, aménagement de l'espace. Ecole Nationale Supérieure des Mines de Paris, 2014. Français. ⟨NNT : 2014ENMP0026⟩. ⟨tel-01123766v2⟩
954 Consultations
1962 Téléchargements
