113 4.2.1 Pilot Plant Description 114 4.2.2 Recorded Data, Temperature Influence, p.119 ,
Q in = 1.1, S in = 6, ? = 0.4, ? = 0.6, K S = 10, Y = 0.67 and µ S,max = 4. The nullcline orange is the substrate and the violet is the biomass, p.79 ,
The set-point (m * ) value in black, p.145 ,
Simultaneous nitrification denetrification in an aerobic MBR treating high strength pet food wastwater, Water Environment Foundation, 2006. ,
Benchmark simulation model no, IWA Taskgroup on Benchmarking of Control Strategies for WWTPs, 2008. ,
URL : https://hal.archives-ouvertes.fr/hal-00276072
Nonlinear model predictive control: from theory to application, Journal of the Chinese Institute of Chemical Engineers, vol.35, pp.299-315, 2004. ,
Membrane systems for wastewater treatment, 2006. ,
Research studies predict strong growth for MBR markets, Membrane Technology, vol.2006, issue.2, pp.8-10, 2006. ,
DOI : 10.1016/S0958-2118(06)70635-8
Modeling of the Soluble Microbial Products (SMP) in Anaerobic Membrane BioReactors (AMBR): Equilibria and stability of the AM2b model, Proceedings of the 18th IFAC World Congress, 2011. ,
DOI : 10.3182/20110828-6-IT-1002.01195
URL : https://hal.archives-ouvertes.fr/hal-00858578
Nonlinear observers for a class of biological systems: application to validation of a phytoplanktonic growth model, IEEE Transactions on Automatic Control, vol.43, issue.8, pp.1056-1065, 1998. ,
DOI : 10.1109/9.704977
Aeration and hydrodynamics in submerged membrane bioreactors, Journal of Membrane Science, vol.379, issue.1-2, pp.1-18, 2011. ,
DOI : 10.1016/j.memsci.2011.06.004
Modeling of pore blocking and cake layer formation in membrane filtration for wastewater treatment, Desalination, vol.189, issue.1-3, pp.97-109, 2006. ,
DOI : 10.1016/j.desal.2005.06.018
Run-to-run control of membrane filtration processes, AIChE Journal, vol.29, issue.9, pp.2316-2328, 2007. ,
DOI : 10.1002/aic.11221
Modeling submerged hollow-fiber membrane filtration for wastewater treatment, Journal of Membrane Science, vol.288, issue.1-2, pp.94-111, 2007. ,
DOI : 10.1016/j.memsci.2006.11.008
Analysis of fouling mechanisms in anaerobic membrane bioreactors, Water Research, vol.46, issue.8, pp.2637-2650, 2012. ,
DOI : 10.1016/j.watres.2012.02.021
URL : https://hal.archives-ouvertes.fr/hal-00859550
Artificial neural network model for transient crossflow microfiltration of polydispersed suspensions, Journal of Membrane Science, vol.258, issue.1-2, pp.35-42, 2005. ,
DOI : 10.1016/j.memsci.2004.11.038
Sensitivity and uncertainty analyses of an extended ASM3-SMP model describing membrane bioreactor operation, Journal of Membrane Science, vol.389, pp.99-109, 2012. ,
DOI : 10.1016/j.memsci.2011.10.020
Investigation of the filtration characteristics of pilot-scale hollow fiber submerged MF system using cake formation model and artificial neural networks model, Desalination, vol.297, pp.20-29, 2012. ,
DOI : 10.1016/j.desal.2012.04.013
A review of membrane bioreactors and their potential application in the treatment of agriculture wastewater, Canadian Biosystems Engineering, vol.45, pp.6-37, 2003. ,
Nitrogen removal techniques in aquaculture for a sustainable production, Aquaculture, vol.270, issue.1-4, pp.1-14, 2007. ,
DOI : 10.1016/j.aquaculture.2007.05.006
Development of a decision tree for the integrated operation of nutrient removal MBRs based on simulation studies and expert knowledge, Chemical Engineering Journal, vol.217, pp.174-184, 2013. ,
DOI : 10.1016/j.cej.2012.11.060
Modélisation dynamique et commande des procédés d'´ epuration biologique des auex uséesusées`uséesà boues activées, 2008. ,
An integrated model for physical-biological wastewater organic removal in a submerged membrane bioreactor: Model development and parameter estimation, Journal of Membrane Science, vol.322, issue.1, pp.1-12, 2008. ,
DOI : 10.1016/j.memsci.2008.05.036
Dynamical Modelling & Estimation in Wastewater Treatment Processes, Water Intelligence Online, vol.4, issue.0, 2001. ,
DOI : 10.2166/9781780403045
Design and operation of nitrifying trickling filters in recirculating aquaculture: A review, Aquacultural Engineering, vol.34, issue.3, pp.234-260, 2006. ,
DOI : 10.1016/j.aquaeng.2005.09.007
Summer school on modelling MBR processes: MBR modelling -hands-on, 2008. ,
Activated sludge model (ASM) based modelling of membrane bioreactor (MBR) processes: A critical review with special regard to MBR specificities, Water Research, vol.44, issue.15, pp.4272-4294, 2010. ,
DOI : 10.1016/j.watres.2010.06.007
Experimental and analytical modeling of the filtration mechanisms of a paper stack candle filter, Chemical Engineering Research and Design, vol.89, issue.12, pp.2776-2784, 2011. ,
DOI : 10.1016/j.cherd.2011.04.020
Development of a control algorithm for air-scour reduction in membrane bioreactors for wastewater treatment, Journal of Chemical Technology & Biotechnology, vol.15, issue.3, pp.784-789, 2011. ,
DOI : 10.1002/jctb.2587
Robust Nonlinear Control Design Aerobic MBRs for domestic wastewater treatment: a review with cost consideration, Separation Purification Technology, vol.18, pp.119-130, 1997. ,
Membrane fouling control in ultrafiltration technology for drinking water production: A review, Desalination, vol.272, issue.1-3, pp.1-8, 2011. ,
DOI : 10.1016/j.desal.2011.01.051
Dynamic modeling of an ultrafiltration module for use in a membrane bioreactor, Journal of Membrane Science, vol.248, issue.1-2, pp.63-71, 2005. ,
DOI : 10.1016/j.memsci.2004.09.026
Modelling approaches for filtration processes with novel submerged capillary modules in membrane bioreactors for wastewater treatment, Desalination, vol.178, issue.1-3, pp.125-134, 2005. ,
DOI : 10.1016/j.desal.2004.11.032
Tests for the application of membrane technology in a new method for intensive aquaculture, Desalination, vol.224, issue.1-3, pp.57-63, 2008. ,
DOI : 10.1016/j.desal.2007.04.080
The peculiarities of nitrogen excretion in sturgeons (Acipenser ruthenus) (Pisces, Acipenseridae)???I. the influence of ration size, Comparative Biochemistry and Physiology Part A: Physiology, vol.103, issue.3, pp.609-612, 1992. ,
DOI : 10.1016/0300-9629(92)90297-4
Nonlinaer Model Predictive Control: Theory and Algorithms, 2011. ,
Feedback linearizing control, in Nonlinear process control, 1997. ,
A general model for single-sludge wastewater treatment systems, Water Research, vol.21, issue.5, pp.505-515, 1987. ,
DOI : 10.1016/0043-1354(87)90058-3
Activated Sludge Models ASM1, ASM2, ASM2d and ASM3, Water Intelligence Online, vol.5, issue.0, 2000. ,
DOI : 10.2166/9781780402369
Biological wastewater treatment -Principles, Modeling and Design A combined pore blockage and cake filtration model for protein fouling during microfiltration, Journal of Colloid and Interface Science, vol.232, pp.389-399, 2000. ,
Future of membranes and membrane reactors in green technologies and for water reuse, Desalination, vol.162, pp.1-11, 2004. ,
DOI : 10.1016/S0011-9164(04)00021-9
Recirculating Aquaculture Systems: Minimum Standards for Design, Construction and Management. Inland Aquaculture Association of South Australia, 2004. ,
Filtration model for hollow fiber membranes with compressible cake formation, Desalination, vol.240, issue.1-3, pp.99-107, 2009. ,
DOI : 10.1016/j.desal.2007.11.068
Steady-state modeling of bio-fouling potentials with respect to the biological kinetics in the submerged membrane bioreactor (SMBR), Journal of Membrane Science, vol.284, issue.1-2, pp.352-360, 2006. ,
DOI : 10.1016/j.memsci.2006.08.001
Differential equations and mathematical biology, 2003. ,
DOI : 10.1007/978-94-011-5970-8
Modeling approach to determine cake buildup and compression in a high-shear membrane bioreactor, Journal of Membrane Science, vol.409, issue.410, pp.409-410335, 2012. ,
DOI : 10.1016/j.memsci.2012.04.002
The mbr site, 2014. ,
The MBR book, principles and applications of membrane bioreactors in water and wastewater treatment, 2011. ,
Nonlinear System, 2002. ,
Prediction of membrane fouling in MBR systems using empirically estimated specific cake resistance, Bioresource Technology, vol.100, issue.23, pp.6133-6136, 2009. ,
DOI : 10.1016/j.biortech.2009.06.037
Mathematical modelling: Classroom notes in applied mathematics, 1995. ,
DOI : 10.1137/1.9781611971767
Singular pertubation methods in control: analysis and design, 1986. ,
Nonlinear predictive control: Theory and Practice, IEE Control Series, p.61, 2001. ,
Modeling of fouling reduction by secondary membranes, Journal of Membrane Science, vol.168, issue.1-2, pp.243-258, 2000. ,
DOI : 10.1016/S0376-7388(99)00324-5
Tratamento dé agua residuárias através de membranas, Tech. rep, 1998. ,
Fouling in membrane bioreactors used in wastewater treatment, Journal of Membrane Science, vol.284, issue.1-2, pp.17-53, 2006. ,
DOI : 10.1016/j.memsci.2006.08.019
Modeling of submerged membrane bioreactor process for wastewater treatment, Desalination, vol.146, issue.1-3, pp.451-457, 2002. ,
DOI : 10.1016/S0011-9164(02)00543-X
Modelling of membrane fouling in a submerged membrane bioreactor, Journal of Membrane Science, vol.278, issue.1-2, pp.151-161, 2006. ,
DOI : 10.1016/j.memsci.2005.10.051
A model for membrane bioreactor process based on the concept of formation and degradation of soluble microbial products, Water Research, vol.35, issue.8, pp.2038-2048, 2001. ,
DOI : 10.1016/S0043-1354(00)00461-9
BSM-MBR: A benchmark simulation model to compare control and operational strategies for membrane bioreactors, Water Research, vol.45, issue.6, pp.2181-2190, 2011. ,
DOI : 10.1016/j.watres.2011.01.006
Analysis of nonlinear software sensor applied to bioprocesses, Presentation Benelux, 2010. ,
A model library for membrane reactors implemented in the process modelling tool ProMoT, Computers & Chemical Engineering, vol.28, issue.3, pp.319-332, 2004. ,
DOI : 10.1016/S0098-1354(03)00189-3
An integrated model for biological and physical process simulation in membrane bioreactors (MBRs), Journal of Membrane Science, vol.376, issue.1-2, pp.56-69, 2011. ,
DOI : 10.1016/j.memsci.2011.04.003
A general approach to modelling membrane modules, Chemical Engineering Science, vol.58, issue.22, pp.4975-4990, 2003. ,
DOI : 10.1016/j.ces.2003.07.005
A comparison of three methods for selecting values of input variables in the analysis of output from a computer code, Technometrics, vol.221, pp.239-245, 1979. ,
APPLICATION OF MEMBRANE BIOREACTOR (MBR) TECHNOLOGY FOR WATER RECLAMATION, Proceedings of the Water Environment Federation, 2000. ,
DOI : 10.2175/193864700784607721
Mathematical Biology -I: an introduction. Springer-Verlag Naessens W, Maere T, Nopens I (2012a) Critical review of membrane bioreactor models -Part 1: Biokinetic and filtration models, Bioresource Technology, vol.122, pp.95-106, 2002. ,
Critical review of membrane bioreactor models ??? Part 2: Hydrodynamic and integrated models, Bioresource Technology, vol.122, pp.107-118 ,
DOI : 10.1016/j.biortech.2012.05.071
A mini-review of modeling studies on membrane bioreactor (MBR) treatment for municipal wastewaters, Desalination, vol.212, issue.1-3, pp.261-281, 2007. ,
DOI : 10.1016/j.desal.2006.10.013
Empirical model of the pH dependence of the maximum specific nitrification rate, Process Biochemistry, vol.42, issue.12, pp.1671-1676, 2007. ,
DOI : 10.1016/j.procbio.2007.09.010
Optimization of membrane filtration process for drinking water treatment using fluorescentebase measurement, Proceedings of the 9th International Symposium on Dynamics and Control of Process System, 2010. ,
Differential equations and dynamic systems Reducing the potential environmental impact of tank aquaculture effluents through intensification and recirculation, Aquaculture, vol.226, pp.35-44, 1991. ,
Validation of a Simple Fouling Model for a Submerged Membrane Bioreactor, IFAC-PapersOnLine, vol.48, issue.1, 2015. ,
DOI : 10.1016/j.ifacol.2015.05.031
URL : https://hal.archives-ouvertes.fr/hal-01132139
Design, analysis and validation of a simple dynamic model of a submerged membrane bioreactor, Water Research, vol.70, pp.97-108, 2015. ,
DOI : 10.1016/j.watres.2014.11.043
URL : https://hal.archives-ouvertes.fr/hal-01087630
Deadend outside-in hollow fiber membrane filter: Mathematical model, Journal of Membrane Science, vol.279, issue.1-2, pp.615-624, 2006. ,
DOI : 10.1016/j.memsci.2005.12.056
Application of submerged membrane bioreactor for aquaculture effluent reuse, Desalination, vol.221, issue.1-3, pp.534-542, 2008. ,
DOI : 10.1016/j.desal.2007.01.114
DYNAMIC MODELLING OF A BIOFILTER USED FOR NITRIFICATION OF DRINKING WATER AT LOW INFLUENT AMMONIA CONCENTRATIONS, International Symposium on Advanced Control of Chemical Processes, 2006. ,
DOI : 10.3182/20060402-4-BR-2902.00541
A filtration model applied to submerged anaerobic MBRs (SAnMBRs), Journal of Membrane Science, vol.444, pp.139-147, 2013. ,
DOI : 10.1016/j.memsci.2013.05.021
Mathematical modelling of filtration in submerged anaerobic MBRs (SAnMBRs): Long-term validation, Journal of Membrane Science, vol.446, pp.303-309, 2013. ,
DOI : 10.1016/j.memsci.2013.07.001
Performance of bench-scale membrane bioreactor under real work conditions using pure oxygen: viscosity and oxygen transfer analysis, Bioprocess and Biosystems Engineering, vol.4, issue.11, pp.885-892, 2010. ,
DOI : 10.1007/s00449-010-0411-0
Singular perturbations and time-scale methods in control theory: Survey 1976???1983, Automatica, vol.20, issue.3, pp.273-293, 1984. ,
DOI : 10.1016/0005-1098(84)90044-X
Nonlinear model predictive control of fed-batch cultures of micro-organisms exhibiting overflow metabolism: Assessment and robustness, Computers & Chemical Engineering, vol.39, pp.143-151, 2012. ,
DOI : 10.1016/j.compchemeng.2011.12.010
ContôleCont?Contôle non linéaire et application. ´ Editeurs des sciences et des arts -Hermman, 2005. ,
Model evaluation of simultaneous nitrification and denitrification in a membrane bioreactor operated without an anoxic reactor, Journal of Membrane Science, vol.337, issue.1-2, pp.17-27, 2009. ,
DOI : 10.1016/j.memsci.2009.03.015
Dynamic in-series resistance modeling and analysis of a submerged membrane bioreactor using a novel filtration mode, Desalination, vol.285, pp.285-294, 2012. ,
DOI : 10.1016/j.desal.2011.10.015
Lead market for membrane bio-reactor (MBR) technology -china s second-mover strategy for the development and exploitation of its lead market potential, Fraunhofer Institute for Systems and Innovation Research ISI, 2013. ,
Inorganic fouling of pressure-driven membrane processes ??? A critical review, Desalination, vol.250, issue.1, pp.236-248, 2010. ,
DOI : 10.1016/j.desal.2009.02.056
Nonlinear black-box modeling in system identification: a unified overview, Automatica, vol.31, issue.12, pp.1691-1724, 1995. ,
DOI : 10.1016/0005-1098(95)00120-8
Applied nonlinear control The theory of the chemostat, 1991. ,
Mathematical control theory Modelling an aerobic submerged membrane bioreactor with asm models on a large range of sludge retention time, Desalination, vol.231, pp.82-90, 1998. ,
Ideas:a parameter identification toolbox with symbolic analysis of uncertainty and its application to biological modelling Wastewater engineering treatment and reuse, 15th Symposium on System Identification Tchobanoglous G, 2003. ,
Apparent ammonia-nitrogen production rates of white sturgeon (acipenser transmontanus) in commercial aquaculture systems, Aquacultural Engineering, vol.17, issue.1, pp.45-55, 1998. ,
DOI : 10.1016/S0144-8609(97)01014-5
Revisiting the laws of filtration: An assessment of their use in identifying particle retention mechanisms in filtration, Journal of Membrane Science, vol.383, issue.1-2, pp.17-25, 2011. ,
DOI : 10.1016/j.memsci.2011.07.019
Advanced instrumentation , data interpretation, and control of biotechnological processes, 1998. ,
DOI : 10.1007/978-94-015-9111-9
Membrane filtration for removal of fine solid from aquaculture process water, Aquacultural Engineering, vol.26, pp.151-169, 2002. ,
Effluent and production impacts of flow-through aquaculture operations in west virginia, Aquacultural Engineering, vol.33, pp.258-270, 2005. ,
Modelling of a membrane bioreactor system for municipal wastewater treatment, Journal of Membrane Science, vol.216, issue.1-2, pp.55-65, 2003. ,
DOI : 10.1016/S0376-7388(03)00046-2
Modeling membrane fouling in a submerged membrane bioreactor by considering the role of solid, colloidal and soluble components, Journal of Membrane Science, vol.397, issue.398, pp.397-398102, 2012. ,
DOI : 10.1016/j.memsci.2012.01.026
State-of-the-art of membrane bioreactors: Worldwide research and commercial applications in North America, Journal of Membrane Science, vol.270, issue.1-2, pp.201-211, 2006. ,
DOI : 10.1016/j.memsci.2005.07.010
Modelling of submerged membrane bioreactor: Conceptual study about link between activated slugde biokinetics, aeration and fouling process, Journal of Membrane Science, vol.325, issue.2, pp.612-624, 2008. ,
DOI : 10.1016/j.memsci.2008.08.037
Modelling bioprocesses and membrane fouling in membrane bioreactor (MBR): A review towards finding an integrated model framework, Bioresource Technology, vol.122, pp.119-129, 2012. ,
DOI : 10.1016/j.biortech.2012.04.090
