Contributions à la modélisation mathématique et à l'algorithmique parallèle pour l'optimisation d'un propagateur d'ondes élastiques en milieu anisotrope - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2014
Contributions to the mathematical modeling and to the parallel algorithmic for the optimization of an elastic wave propagator in anisotropic media
The most common method of Seismic Imaging is the RTM (Reverse Time Migration) which depends on wave propagation simulations in the subsurface. We focused on a 3D elastic wave propagator in anisotropic media, more precisely TTI (Tilted Transverse Isotropic). We directly worked in the Total code DIVA (Depth Imaging Velocity Analysis) which is based on a discretization by the Discontinuous Galerkin method and the Leap-Frog scheme, and developed for intensive parallel computing – HPC (High Performance Computing). We choose to especially target two contributions. Although they required very different skills, they share the same goal: to reduce the computational cost of the simulation. On one hand, classical boundary conditions like PML (Perfectly Matched Layers) are unstable in TTI media. We have proposed a formulation of a stable ABC (Absorbing Boundary Condition) in anisotropic media. The technique is based on slowness curve properties, giving to our approach an original side. On the other hand, the initial parallelism, which is based on a domain decomposition and communications by message passing through the MPI library, leads to load-imbalance and so poor parallel efficiency. We have fixed this issue by replacing the paradigm for parallelism by the use of task-based programming through runtime system. This PhD thesis have been done in the framework of the research action DIP (Depth Imaging Partnership) between the Total oil company and Inria.
La méthode d’imagerie la plus répandue dans l’industrie pétrolière est la RTM (Reverse Time Migration) qui repose sur la simulation de la propagation des ondes dans le sous-sol. Nous nous sommes concentrés sur un propagateur d'ondes élastiques 3D en milieu anisotrope de type TTI (Tilted Transverse Isotropic). Nous avons directement travaillé dans le code de recherche de Total DIVA (Depth Imaging Velocity Analysis), basé sur une discrétisation par la méthode de Galerkin Discontinue et le schéma Leap-Frog, et développé pour le calcul parallèle intensif – HPC (High Performance Computing). Nous avons ciblé plus particulièrement deux contributions possibles qui, si elles supposent des compétences très différentes, ont la même finalité : réduire les coûts de calculs requis pour la simulation. D'une part, les conditions aux limites classiques de type PML (Perfectly Matched Layers) ne sont pas stables dans des milieux TTI. Nous avons proposé de formuler une CLA (Conditions aux Limites Absorbantes) stable dans des milieux anisotropes. La méthode de construction repose sur les propriétés des courbes de lenteur, ce qui donne à notre approche un caractère original. D'autre part, le parallélisme initial, basé sur une décomposition de domaine et des communications par passage de messages à l'aide de la bibliothèque MPI, conduit à un déséquilibrage de charge qui détériore son efficacité parallèle. Nous avons corrigé cela en remplaçant le paradigme parallélisme par l'utilisation de la programmation à base de tâches sur support d'exécution. Cette thèse a été réalisée dans le cadre de l'action de recherche DIP (Depth Imaging Partnership) qui lie la compagnie pétrolière Total et Inria.
BOILLOT_PhD.pdf (34.19 Mo) Télécharger le fichier
tel-01133713 , version 1 (20-03-2015)
tel-01133713 , version 2 (12-05-2015)
  • HAL Id : tel-01133713 , version 1
Lionel Boillot. Contributions à la modélisation mathématique et à l'algorithmique parallèle pour l'optimisation d'un propagateur d'ondes élastiques en milieu anisotrope. Modélisation et simulation. Université de Pau et des Pays de l'Adour, 2014. Français. ⟨NNT : ⟩. ⟨tel-01133713v1⟩
399 Consultations
200 Téléchargements
