Abstract : The e-learning documents design and use are the subject of some many research regarding e-learning into Information Science and Communication (SIC) discipline. Almost nearly all of this work is interested on the documents structure, standardization, mutualization, customizing ... In contrast, few or very few are those who ask the question about the end user needs and expectations. We ask if thinking in this direction should be continued, because it seems us that such modeling content undoubtedly facilitate their understanding and reuse. Based on the previous work, and to make a new contribution to the teaching engineering field, we stand at the border formed by the cognitive and educational use with the sequences teaching design, mediation and the empathetic relationship need with the learner and the teacher, which makes the originality of this research. This problem led us to hypothesize that from an analysis of the learner needs and expectations, we can identify factors which can contribute to the e -learning document development answering to his satisfaction. To achieve our goal, a protocol for data collecting has been set up for the purpose is to identify criteria quality e-learning document according to the “Learner”, the “Designer” and the “Maker” views. We rely on the interviews results with the CNS My Rachid-IRFC teachers and makers. Thus, we discuss the methodology adopted by applying the EBAHIE method. In the experiment, the protocol - called A.Co.D - reveals a robust method to cross several information sources creating synergies several approaches and tools to achieve the comprehensive results on the asked problem: 1- In a first time, the “Learner” approach allows us to understand their perception to propose recommendations to designers. document. 2- In a second time, a “Designer” approach is subject to exchange experiences designers how learners perceived and used the document . 3- The third approach involves crossing the established criteria in the “Learner” process with those released during the “Designer” process. 4- In a fourth time, the “Maker” approach allows finally identifying needs help in decision making.Thus, we arrive at the formalization of our e-learning document design model in Sport field, by providing designers all parameters to develop a quality document.
Résumé : La conception et l’usage des documents e-learning font l’objet de nombreux travaux de recherche en matière d’e-learning en Sciences de l’Information et de la Communication (SIC). Presque la quasi-totalité de ces travaux s’intéresse à la structuration de documents, la normalisation, la mutualisation, la personnalisation... En revanche, peu nombreux, voire très peu nombreux sont ceux qui se posent la question sur les besoins et les attentes de l’utilisateur final. La thématique de la conception du document e-learning de qualité, apparaît en filigrane, mais ne constitue presque jamais l’objet central des réflexions. Nous nous demandons si la pensée dans cette voie mérite d’être poursuivie, car il nous semble qu’une telle modélisation de contenus faciliterait incontestablement leurs compréhensions et leurs réutilisations. Partant des travaux antérieurs, et afin d’apporter une nouvelle contribution au domaine de l’ingénierie pédagogique, nous nous situons à la frontière que forme l’utilisation cognitive et pédagogique avec la conception des séquences pédagogiques, de la médiation et de la nécessité d’une relation empathique avec l’apprenant et l’enseignant, ce qui fait l’originalité de cette recherche. Une telle problématique nous conduit à formuler l’hypothèse qu’à partir d’une analyse des besoins et attentes de l’apprenant, nous pouvons dégager des critères qui peuvent contribuer à l’élaboration d’un document e-learning répondant à sa satisfaction. Pour atteindre notre objectif, un protocole de collecte de données sur terrain a été mis en place dans le but est de dégager les critères de qualité du document e-learning selon les points de vue de l’« Apprenant », du « Concepteur » et du « Décideur ». Nous nous appuyons sur les résultats des entretiens réalisés auprès des pédagogues et des décideurs du CNS My Rachid-IRFC. Ainsi, nous abordons la méthodologie adoptée en appliquant la méthode EBAHIE. A l’expérience, le protocole -baptisé A.Co.D- se révèle une méthode robuste qui permet de croiser plusieurs sources d’information en mettant en synergie plusieurs démarches et outils pour parvenir à des résultats pertinents et exhaustifs sur la problématique posée : 1- dans un 1èr temps, la démarche « Apprenant » nous permet de comprendre leur perception pour proposer des recommandations aux concepteurs de document. 2- dans un second temps, une démarche « Concepteur » fait l’objet d’un retour d’expériences des concepteurs sur la façon dont les apprenants ont perçu et utilisé le document. 3- la troisième démarche consiste à croiser des critères dégagés dans la démarche« Apprenant » avec ceux dégagés lors de la démarche « Concepteur ». 4- dans un 4éme temps, la démarche « Décideur » permet d’identifier finalement les besoins d’aide dans les prises de décision.Nous aboutissons ainsi, à la formalisation de notre modèle de conception du document e-learning en Sport, mettant à la disposition des concepteurs pédagogiques tous les paramètres pour élaborer un document de qualité.
