Collaboration des équipements du réseau domestique pour une meilleure efficacité énergétique globale - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2014
Smart devices collaboration for energy saving in home networks
Han Yan
  • Fonction : Auteur
  • PersonId : 772489
  • IdRef : 184949912
In recent years, Information and Communications Technology (ICT) has totally changed the people daily life in the Digital Home. Meanwhile, not only the amount of CO2 emission of ICT, so called ''footprint'', is increasing without cease, but also the price of electricity is constantly rising. Thus, it is quite important to reduce energy consumption in the home network and home devices for the environmental and economic reasons. In order to cope with this context, the thesis concerns the design, the evaluation, and the implementation of a novel set of mechanisms with the purpose of responding to home network energy consumption problems. We proposed firstly an Overlay Energy Control Network which is formed by the overlay energy control nodes. Each node is connected to one device which forms an overlay control network to coordinate the power states of the device. Then, a testbed for HOme Power Efficiency system (HOPE) is implemented to demonstrate the technical solution for energy control in a real home network environment with several frequently used scenarios. After analyzing user's way of use of their home network equipment, we propose a power management which controls the devices based on the analysis of the collaborative services. These frequently used collaborative services require different functional blocks in different devices. This model provides the possibility to turn on the right requested functional blocks in the right device at the right moment. Finally, based on the former contribution, the collaborative overlay power management offers several possible tradeoffs between the power consumption and the waiting delay in the home network.
Au cours des dernières années, la révolution numérique a continué sa progression. Les technologies de l'information et des communications (TIC) ont totalement changé la vie quotidienne des gens à leur domicile (concept de « maison numérique »). Pendant ce temps, non seulement le volume des émissions de CO2 produit par les TIC, ce qu'on appelle l'empreinte carbone, est sans cesse en croissance mais elle s'accompagne également d'une hausse du prix de l'électricité, augmentant fortement la part des équipements numériques dans la budget global des ménages. Ainsi, pour des raisons environnementale et économique, réduire la consommation d'énergie dans les nombreux équipements du réseau domestique est devenu un enjeu majeur. Dans ce contexte, la thèse porte sur la conception, l'évaluation et la mise en œuvre d'un ensemble de mécanismes dans le but de répondre aux problèmes de consommation d'énergie sur les réseaux locaux rassemblant les équipements numériques domestiques. Nous proposons un réseau de contrôle qui est formé par des noeuds de contrôle de l'énergie placés au-dessus du réseau traditionnel. Chaque nœud de contrôle est relié à un dispositif en vue de coordonner les états d'alimentation de l'équipement domestique associé.. Un démonstrateur pour un système Home Power Efficiency (HOPE) a également été mis en œuvre. Il démontre la faisabilité de la solution technique que nous proposons pour le contrôle de l'énergie dans un réseau domestique réel avec des scénarios réels qui sont souvent utilisées par utilisateur. Après avoir analysé le mode d'utilisation des équipements du réseau domestique, nous proposons un système de gestion d'énergie qui contrôle ces équipements minimisant ainsi que leur consommation. Le système est basé sur l'analyse des services collaboratifs, chaque service est découpé en blocs fonctionnels atomiques, distribués dans les différents équipements. Cela permet de gérer avec plus de précision les besoins énergétiques de chaque équipement de manière à n'alimenter que les composants nécessaires au service demandé. Pour conclure ces travaux, nous avons également cherché à minimiser les impacts de l'économie d'énergie sur la qualité d'expérience perçue par l'utilisateur (notamment le délai d'activation des services). Nous proposons un système de gestion d'énergie pour des services collaboratifs offrant plusieurs compromis possibles entre la consommation d'énergie et le délai d'activation des services dans un réseau domestique. Il est complété par un algorithme d'apprentissage du comportement des utilisateurs domestiques.
YAN_Han.pdf (4.85 Mo) Télécharger le fichier
tel-01147623 , version 1 (30-04-2015)
  • HAL Id : tel-01147623 , version 1
Han Yan. Collaboration des équipements du réseau domestique pour une meilleure efficacité énergétique globale. Autre [cs.OH]. Université de Rennes, 2014. Français. ⟨NNT : 2014REN1S122⟩. ⟨tel-01147623⟩
316 Consultations
322 Téléchargements
