Peter, the Language that does not Exist... - Archive ouverte HAL Access content directly
Habilitation À Diriger Des Recherches Year : 2007
Peter, le langage qui n’existe pas...
It is my privilege and pleasure to introduce Peter, the language that does not exist...
The Peter language contains almost the linguistic features I have introduced and investigated in the field of functional and object-oriented programming, plus some new features not published yet. In Peter’s Habilitation, I will try to limit as much as possible the mathematical overhead and the technicalities (e.g. full set of rules, full proofs of theorems, etc.). In my opinion, the habilitation thesis should not be a mere translation of the candidate’s most successful papers (3), nor a commented curriculum vitæ, nor a survey of all the related works in his scientific area (4), just to mention a few “classic Habilitation styles”. It is my opinion that it should be short in length since it is experienced that a very few Habilitation thesis are really downloaded, cited and read. Oftenly, habilitation thesis are not even made accessible on the Web.
Peter’s Habilitation will be based on the following three points:
• (Modularity) I will present a (Turing complete) kernel of Peter, called Baby Peter, and I will continue in the rest of the Habilitation to extend it in a modular fashion until the final extension, called Wise Peter. Baby Peter is a functional language with object-oriented features equipped with a sound type system. Peter bears some similarities to Atsushi, Benjamin and Phil’s Featherweight Java [IPW01] and Alonso Church’s typed lambda calculus [Chu41]. The main difference lies in an ad hoc exception-handling mechanism allowing the programmer to choose the type system according to her/his necessities and goals. Even more, it allows the programmer to write her/his own type system (see item (Type-programmable)). Some chapters will focus on operational semantics, some others on type systems, some others on both. All topics will be treated in a “lightweight fashion”. Examples of extensions are for instance mixing class-based and pure object-based features, but also improving proof languages à la LF with pattern matching facilities and including those metalanguages to Peter in order to mix algorithms and their correctness proofs.
• (Verbatim-like) Instead of annoying the reader with a plain French translation of some of my most relevant papers (6), I will show, for each extension, only some key rules of the operational semantics or of the type system (every system has at least a key rule...) and some motivating examples. I do not plan to prove type soundness for each extension of Peter: the whole soundness of Wise Peter is left as a challenge for the “next” user friendly proof assistant.
• (Type-programmable) Type systems for programming languages and proof languages are fixed a priori by language designers; type systems are not first class citizens. To my little knowledge, no language allows the programmer to build, choose, or mix type systems. The idea of modifying the type discipline at compile time is not completely new; a quite inspiring work has been done by the “visionary-6-pages” paper by Gilad in 2004 [Bra04] called Pluggable Type Systems. The possibility to mixing type systems and using it as a first class citizens is an interesting research strand that will constitute an original contribution in Peter’s Habilitation.
With the intention of disseminating science in a simple, clear and pedagogical way, and inspired by the works of Kim [Bru99, TKB01, BDKT03, RBC+ 05, Bru02] and Gilles [Dow03, Dow07], I wish you a very nice reading of the Peter’s Habilitation.
3 Although certain parts are taken of my articles.
4 The typographic convention is that references to my papers are in “numeric” style while references to other papers are in “alphanumeric” style.
6 We provide a CD and a Web site with all my papers.
C’est mon privilege et plaisir d’introduire Peter, le langage qui n’existe pas...
Le langage Peter contient quasiment tous les aspects linguistiques que j’ai introduits et étudiés dans le domaine de la programmation fonctionnelle et objets, ainsi que quelques idées qui n’ont pas encore été publiées. Dans l’habilitation de Peter, la démarche que je suivrai consiste à essayer de limiter les détails concernant les aspects théoriques et techniques (c-à-d. les ensembles complets des règles de typage, suites de théorèmes abscons, etc.). Mon mémoire d’habilitation ne sera pas une traduction brutale des différents articles publiés (1), ni un curriculum vitæ commenté, ni un panorama de tous les articles dans un domaine scientifique (2), pour ne citer que quelques styles classiques de thèses d’habilitation. Tout d’abord elle sera courte car l’expérience enseigne que très peu de thèses d’habilitation sont réellement téléchargées, citées et lues. Très souvent, les thèses d’habilitation ne sont même pas accessibles sur le Web.
L’Habilitation de Peter sera fondée sur les trois « dogmes » suivants:
• (Modularité) Je commencerai par le plus petit fragment complet (au sens de Turing) de Peter, appelée Baby Peter et je continuerai de façon modulaire, d’extension en extension, jusqu’à l’extension finale appelée Sage Peter. Baby Peter est un langage fonctionnel avec des constructions linguistiques orientées objet et un système de types correct. Peter partage quelques similitudes avec Featherweight Java de Atsushi, Benjamin et Phil [IPW01] et le lambda calcul typé de Alonso (Church) [Chu41]. La différence principale entre Featherweight Java et Peter, est un mécanisme d’exceptions ad hoc, qui permet au programmeur de décider quel système de types sera le plus adapté à l’egard de ses nécessités et objectifs. En plus, ce mécanisme permet au programmeur d'écrire son système de types (voir point Type-programmable). Certains chapitres seront focalisés sur un nouveau système de types, tandis que, dans d’autres chapitres, l’extension sera associée à une extension de la syntaxe et du système de types. Tous les arguments seront traités d’une façon accessible au plus grand nombre de lecteurs. Comme exemples d’extensions, je citerai une forme nouvelle d'héritage multiple, une extension de Peter qui permettra à un objet de « s'échapper de sa classe », une extension de Peter avec filtrage évolué et enfin une extension de Peter qui permettra de mélanger algorithmes et preuves de correction d’algorithmes.
• (Verbatim-like) Plutôt que d'asséner à mes lecteurs une traduction française mot-à-mot de mes articles scientifiques (5), j’ai privilegié une présentation simple de chaque extension, utilisant uniquement quelques règles clés de la sémantique opérationnelle ou du système de types (il y a toujours une règle clé...), en ajoutant immédiatement des exemples pour motiver et comprendre son utilisation correcte. Je ne prouverai pas la propriété de complétude de chaque système de types qui étend Peter : la complétude de Sage Peter est proposée en défi au prochain assistant à la preuve convivial.
• (Type-programmable) Les systèmes de types pour les langages de programmation et pour la preuve sont fixés a priori par leurs concepteurs et ne sont pas des objets de première classe pouvant être modifiés ou simplement utilisés par le programmeur qui en subit les qualités et les faiblesses. À ma connaissance, aucun langage ne permet au programmeur de « programmer » sa discipline de types personnelle. L’idée de modifier la discipline de typage à la compilation n’est pas très nouvelle ; un article « visionnaire » de 6 pages, qui m'a eclairé, a été Pluggable Type System de Gilad [Bra04] sorti en 2004. La possibilité de permettre au programmeur d'écrire sa propre discipline de typage et de l’utiliser à la volée est par elle-même une contribution originale dans l’habilitation de Peter.
Avec l’envie de diffuser la connaissance scientifique de façon simple, claire et pédagogique, inspiré par les ouvrages de Kim [Bru99,TKB01, BDKT03, RBC+ 05, Bru02] et Gilles [Dow03, Dow07], il ne me reste plus qu'à vous souhaiter une bonne lecture de l’habilitation de Peter.
1. Bien que certaines parties soient tirées de mes articles.
2. La convention typographique est que les référence à mes articles soit en style « numérique » tandis que les références à d’autres articles soit en « alphanumérique ».
5 Un CD et un site web contiendront tous mes articles.
2007-hdr-liquori-07.pdf (1.64 Mo) Télécharger le fichier
Dates and versions
tel-01148503 , version 1 (04-05-2015)
Identifiers
  • HAL Id : tel-01148503 , version 1
Cite
Luigi Liquori. Peter, the Language that does not Exist.... Computation and Language [cs.CL]. INPL - INP de LORRAINE, 2007. ⟨tel-01148503⟩
220 View
70 Download
Share
