Identification of strainrate dependent hardening sensitivity of metallic sheets under in-plane biaxial loading - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2015
Identification de la sensibilité à la vitesse de déformation de l'écrouissage de tôles métallique minces sous sollicitations planes biaxiales
Sheet metal forming processes are widely adopted to produce panels, tubes, profiled parts in manufacturing industry. The numerical simulation of the forming processes requires accurate constitutive models of material. In many sheet metal working operations such as stamping, hydroforming, …, large strains and intermediate strain rates can be reached under biaxial strain or stress states. The objective of this work is to show the potential of the biaxial in-plane tensile test to characterize the hardening behaviour of metal sheets up to large strain levels. By numerical investigation, an optimal cruciform shape is designed to obtain large equivalent plastic strain, up to 30%, at the central zone under equi-biaxial strain path. As expected, the initial cracks of tested specimens are always observed at the central zone. Then, quasi-static and dynamic biaxial tensile tests on in-plane cross specimens have been performed on a dedicated servo-hydraulic machine. These biaxial tensile tests have been carried out on aluminium alloy AA5086 to validate the identification methodology of hardening behaviour under biaxial loading. This alloy has been chosen since its hardening behaviour is not dependent on the strain rate. Digital Image Correlation (DIC) technique is used for strain measurement. The parameters of isotropic hardening models are identified by inverse analysis based on the finite element model of the biaxial tensile test. Three yield criteria of Mises, Hill48 and Bron and Besson are compared for the parameter identification of different hardening laws. It is shown that the hardening law identified by biaxial test is precise only if an appropriate yield function is preliminarily determined. The biaxial flow stress curve identified with Bron and Besson yield function have been found in good agreement with the experimental flow stress curve obtained from uniaxial tensile tests. For biaxial tests at intermediate strain rates, damping layers are adopted to reduce oscillations on force versus time curves. The comparison of flow stress curves, identified from quasi-static and dynamic biaxial in-plane tensile tests on the non strain rate-dependent material AA5086, validates the identification methodology of strain-rate dependent hardening models. Finally, the proposed methodology is applied to the hardening characterization of a strain-rate dependent Dual Phase steel DP600 at room temperature. Identified biaxial flow stress curves have been compared with uniaxial ones for different strain rates ( . = 10-3s-1, 10-1s-1 and 101s-1). DP600 steel exhibits the same positive strain rate sensitivity for uniaxial and biaxial strain states. The biaxial flow stress curves identified on the basis of Ludwick and Voce hardening models are close, up to equivalent plastic strains of 30%. The benefits of the proposed methodology, based on a biaxial in-plane tensile test carried out on cross specimen, are clearly shown since the hardening behaviour identified in this case for large strains (up to 30%) is very different from the one identified from uniaxial tensile test on a smaller strain range.
Les procédés de mise en forme des tôles métalliques sont largement utilisés dans l’industrie mécanique. La simulation numérique des opérations de mise en forme nécessite une caractérisation précise des modèles de comportement rhéologique des matériaux. Dans de nombreuses opérations de mise en forme des tôles métalliques telle que l’emboutissage, l’hydroformage, …, de grandes déformations et des vitesses de déformations dites intermédiaires peuvent être atteintes sous des états biaxiaux de déformation ou de contrainte. L’objectif de ce travail est de montrer le potentiel de l’essai de traction bi-axiale pour caractériser l’écrouissage des tôles métalliques pour de grandes déformations et dans une gamme de vitesse de déformation dite intermédiaire. A partir de simulations numériques, une forme optimale d’éprouvette en croix, permettant d’atteindre 30% de déformation plastique équivalente dans la zone centrale de l’éprouvette sous un chargement équibiaxial, a été proposée. Par la suite, des essais quasi-statiques et dynamiques de traction bi-axiale ont été réalisés sur la forme d’éprouvette proposée à partir d’une machine dédiée d’essais servo-hydraulique à quatre vérins. Dans un premier temps, le matériau choisi est un alliage d’aluminium AA5086 ne présentant pas de dépendance à la vitesse de déformation. Les déformations expérimentales sont déterminées à partir de la technique de corrélation d’images. L’écrouissage isotrope de différents modèles est identifié à partir d’une procédure inverse basée sur une modélisation éléments finis de l’essai de traction biaxiale. Trois critères de plasticité (Mises, Hill 48 et Bron et Besson) ont été successivement utilisés pour l’identification des paramètres des lois d’écrouissage. Les résultats obtenus montrent d’une part que la modélisation est très sensible au critère de plasticité choisi, et d’autre part que le critère de Bron et Besson permet d’obtenir une très bonne corrélation entre les courbes d’écrouissage identifiées à partir de l’essai bi-axial et de l’essai uni-axial. Pour les tests dynamiques bi-axiaux, les phénomènes de résonance du dispositif mécanique, générés à l’impact initial de début d’essai et matérialisés par de fortes oscillations du signal d’effort, sont atténués par l’interposition d’un élément en élastomère dans le système d’ancrage de chaque bras de l’éprouvette. Pour finir, la méthodologie d’identification proposée est appliquée à la caractérisation du comportement viscoplastique d’un acier dual phase DP600. Les courbes d’écrouissage identifiées à partir des essais bi-axiaux ont été comparées à celles obtenues par des essais uni-axiaux pour une gamme de vitesse de déformation allant de 10- 3s-1 à 101s-1. Le DP600 présente une même sensibilité à la vitesse de déformation quelque soit la sollicitation, uni-axiale ou bi-axiale. Les lois d’écrouissage de Ludwick et de Voce, identifiées jusqu’à 30% de déformation plastique équivalente sur la base de données expérimentales constituées des essais bi-axiaux, sont relativement proches. Les différences observées entre ces courbes d’écrouissage et celles identifiées à partir des essais de traction uni-axiaux montrent tout l’intérêt de l’essai de traction bi-axiale sur éprouvette en croix.
These_LIU_Wei.pdf (7.52 Mo) Télécharger le fichier
tel-01149144 , version 1 (06-05-2015)
  • HAL Id : tel-01149144 , version 1
Wei Liu. Identification of strainrate dependent hardening sensitivity of metallic sheets under in-plane biaxial loading. Mechanical engineering [physics.class-ph]. INSA de Rennes, 2015. English. ⟨NNT : 2015ISAR0005⟩. ⟨tel-01149144⟩
257 Consultations
712 Téléchargements
