Etude du dégazage des résines pour les lithographies électronique et extrême ultraviolet - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2015
Study of resist outgassing for e-beam and EUV lithographies
The development of multiple e-beam lithography equipment is foreseen as an alternative to the 193i nm immersion photolithography for the advanced technological node (less than 14 nm). This next generation lithography is a potential challenger to the EUV (13.5 nm) lithography which is also under development. However, this technology faces important challenges in controlling the contamination of the electron optics due to the adsorption of molecules outgassed from resist under exposure and the subsequent formation of a carbonaceous film on optics surface. This contamination layer can lead to the transmission loss of the optics and, consequently, degrade the tool lithographic performances (throughput, CD uniformity, Line Width Roughness, etc.). It is thus important to understand the resist outgassing and induced contamination mechanisms in order to predict their effect on the process drifts. That was the driver axis of these thesis works. Firstly, we performed the state of the art related to the works already published in the EUV lithography case. Secondly, we designed and built-up an experimental setup and developed, in parallel, the methods allowing to study the mechanisms of resist outgassing and induced contamination on electron optics simulators, called “mimic”. Thirdly, we assessed the outgassing of several resist formulations in the same operating conditions as in the Matrix platform developed by MAPPER Lithography. We also measured the induced contamination layer on the mimics for each resist formulation using the developed experimental setup. And finally, we proposed an analytical model that allows to predict the contamination film growth inside mimic holes during exposure.
La lithographie électronique multifaisceaux (ou multi e-beam) en cours de développement est pressentie comme une alternative à la photolithographie 193 nm à immersion (193i nm) pour la production des circuits intégrés des noeuds technologiques avancés (14 nm et au-delà). Elle se présente également comme un concurrent potentiel à la photolithographie sous rayonnement EUV (13,5 nm) qui, elle aussi, est en cours de développement. Cependant, le développement de cette technologie doit faire face à plusieurs obstacles. Parmi eux, on a la contamination des optiques électroniques induite par le redépôt des molécules dégazées de la résine au cours de l’exposition. Ces dépôts conduisent à la croissance d’une couche carbonée en surface et à l’intérieur des trous de ces optiques. Cette couche de contamination a tendance à diminuer la transmission des optiques et, par conséquent, diminuer les performances lithographiques de l’outil (débit, uniformité des CD, rugosité, etc.). Il est donc indispensable de comprendre les mécanismes qui gouvernent le dégazage et la croissance de la couche de contamination afin d’être en mesure de prédire son rôle sur les dérives des procédés et de l’équipement. Tel a été l’axe conducteur de ces travaux de thèse. Dans un premier temps, nous avons réalisé l’état de l’art des travaux déjà effectués dans le cas de la technique de lithographie EUV. Ensuite, nous avons conçu et fabriqué un banc de tests et développé, en parallèle, les méthodologies permettant de réaliser les études de dégazage des résines et de contamination induite sur des dispositifs simulateurs d’optiques électroniques, appelés « mimics ». Puis, dans les conditions opératoires similaires à la plateforme Matrix développée par MAPPER Lithography, nous avons évalué le dégazage des résines de différentes formulations et mesuré la contamination induite par chacune de ces formulations sur les mimics à l’aide du banc de tests développé. Enfin, nous avons proposé un modèle analytique permettant de prédire la croissance du film de contamination à l’intérieur des trous du mimic en fonction des paramètres d’exposition.
44292_MEBIENE-ENGOHANG_2015_archivage.pdf (8.04 Mo) Télécharger le fichier
tel-01158145 , version 1 (29-05-2015)
tel-01158145 , version 2 (25-09-2015)
Copyright (Tous droits réservés)
  • HAL Id : tel-01158145 , version 1
Armel-Petit Mebiene Engohang. Etude du dégazage des résines pour les lithographies électronique et extrême ultraviolet. Micro et nanotechnologies/Microélectronique. Université de Grenoble, 2015. Français. ⟨NNT : ⟩. ⟨tel-01158145v1⟩
439 Consultations
1160 Téléchargements
