56 3.2.1. Environnement de calcul, p.57 ,
59 3.3.2, p.62 ,
Du Walkman à l'iPod, 30 ans de balade, 2009. ,
du-walkman-a-lipod-30-ans-de-balade, 2014. ,
Les conséquences que le temps fou passé devant des écrans a sur le cerveau, 2014. ,
Performance and Complexity Co-evaluation of the Advanced Video Coding Standard for Cost-Efective Multimedia Communications, EURASIP J. Adv. Signal Process, vol.2004, issue.2, p.2144371, 2004. ,
Comparison of the Coding Efficiency of Video Coding Standards—Including High Efficiency Video Coding (HEVC), IEEE Transactions on Circuits and Systems for Video Technology, vol.22, issue.12, pp.1669-1684, 2012. ,
DOI : 10.1109/TCSVT.2012.2221192
MPEG Reconfgurable Video CodingE From specifcation to a reconfgurable implementation Signal Process, Image Commun, vol.28, issue.10, pp.1224-1238, 2013. ,
Emerging Wireless Multimedia: Services and Technologies, 2005. ,
DOI : 10.1002/0470021519
264 and MPEG-4 video compression: video coding for next generation multimedia, Chichesterf Hoboken, 2003. ,
DOI : 10.1002/0470869615
Te Intra Prediction in H, Novel Algorithms and Techniques In Telecommunications, Automation and Industrial Electronics ,
A new motion compensation design for H.264/AVC decoder, IEEE International Symposium on Circuits and Systems, pp.4558-4561, 2005. ,
CONTRIBUTING EDITORS-Te Embedded Angle-Te Embedded Mindset-Innovation in skinning the Heap Cat, CC Users J, pp.39-45, 2003. ,
Computer Architecture, Fifh Edition: A Qantitative Approach, 5 edition, 2011. ,
A compiler infrastructure for embedded heterogeneous MPSoCs, Parallel Computing, vol.40, issue.2, pp.51-68, 2014. ,
DOI : 10.1016/j.parco.2013.11.007
Linkers and Loaders, 1999. ,
How to write shared libraries, 2006. ,
Hybrid Datafow/von-Neumann Architectures, IEEE Trans. Parallel Distrib. Syst, vol.25, issue.6, p.pp ,
DOI : 10.1109/tpds.2013.125
A tightly-coupled multi-core cluster with shared-memory HW accelerators, 2012 International Conference on Embedded Computer Systems (SAMOS), pp.96-103 ,
DOI : 10.1109/SAMOS.2012.6404162
A General-Purpose Many-Accelerator Architecture Based on Dataflow Graph Clustering of Applications, Journal of Computer Science and Technology, vol.26, issue.1, pp.239-246, 2014. ,
DOI : 10.1007/s11390-014-1426-9
TartanE Evaluating Spatial Computation for Whole Program Execution, Proceedings of the 12th International Conference on Architectural Support for Programming Languages and Operating Systems, pp.163-174, 2006. ,
DySER: Unifying Functionality and Parallelism Specialization for Energy-Efficient Computing, IEEE Micro, vol.32, issue.5, pp.38-51, 2012. ,
DOI : 10.1109/MM.2012.51
First version of a data fow procedure language, Programming Symposium, pp.362-376, 1974. ,
Consistency in dataflow graphs, IEEE Transactions on Parallel and Distributed Systems, vol.2, issue.2, pp.223-235, 1991. ,
DOI : 10.1109/71.89067
Bounded scheduling of process networks, 1995. ,
Actor-oriented metaprogramming, 2005. ,
Parameterized dataflow modeling for DSP systems, IEEE Transactions on Signal Processing, vol.49, issue.10, pp.2408-2421, 2001. ,
DOI : 10.1109/78.950795
SPDFE A schedulable parametric data-fow MoC, Design, Automation & Test in Europe Conference & Exhibition (DATE), pp.769-774, 2012. ,
BPDFE A statically analyzable datafow model with integer and boolean parameters, 2013 Proceedings of the International Conference on Embedded Sofware (EMSOFT), pp.1-10, 2013. ,
Scheduling dynamic datafow graphs with bounded memory using the token fow model, Acoustics, Speech, and Signal Processing IEEE International Conference on, pp.429-432, 1993. ,
Static scheduling and code generation from dynamic datafow graphs with integer-valued control streams, 1994 Conference Record of the Twenty-Eighth Asilomar Conference on Signals, Systems and Computers, pp.508-513, 1994. ,
DOI : 10.1109/acssc.1994.471505
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.229.2846
Te Semantics of a Simple Language for Parallel Programming, Information Processing '74: Proceedings of the IFIP Congress, pp.471-475, 1974. ,
Synchronous data fow, Proc. IEEE, pp.1235-1245, 1987. ,
Cycle-static dataflow, IEEE Transactions on Signal Processing, vol.44, issue.2, pp.397-408, 1996. ,
DOI : 10.1109/78.485935
Predictable mapping of streaming applications on multiprocessors, 2007. ,
Requirements on the Execution of Kahn Process Networks, Programming languages and systems, pp.319-334, 2003. ,
DOI : 10.1007/3-540-36575-3_22
A Distributed Deadlock Detection and Resolution Algorithm for Process Networks, 2007 IEEE International Conference on Acoustics, Speech and Signal Processing, ICASSP '07, pp.33-36, 2007. ,
DOI : 10.1109/ICASSP.2007.366165
Hierarchical run time deadlock detection in process networks, 2008 IEEE Workshop on Signal Processing Systems, pp.239-244, 2008. ,
DOI : 10.1109/SIPS.2008.4671769
Deadlock Detection For Distributed Process Networks, Proceedings. (ICASSP '05). IEEE International Conference on Acoustics, Speech, and Signal Processing, 2005., p.73, 2005. ,
DOI : 10.1109/ICASSP.2005.1416243
Chapter 9 Sequencing and scheduling: Algorithms and complexity, Handb. Oper. Res. Manag. Sci, vol.4, pp.445-522, 1993. ,
DOI : 10.1016/S0927-0507(05)80189-6
Scheduling strategies for multiprocessor real-time DSP, IEEE Global Telecommunications Conference, 1989, and Exhibition. 'Communications Technology for the 1990s and Beyond, pp.1279-1283, 1989. ,
DOI : 10.1109/GLOCOM.1989.64160
Performance-effective and low-complexity task scheduling for heterogeneous computing, IEEE Transactions on Parallel and Distributed Systems, vol.13, issue.3, pp.260-274, 2002. ,
DOI : 10.1109/71.993206
A comparison of list schedules for parallel processing systems, Communications of the ACM, vol.17, issue.12, pp.685-690, 1974. ,
DOI : 10.1145/361604.361619
Compile-time scheduling of datafow program graphs with dynamic constructs, 1992. ,
Comparative Evaluation Of The Robustness Of DAG Scheduling Heuristics, Grid Computing, pp.73-84, 2008. ,
DOI : 10.1007/978-0-387-09457-1_7
URL : https://hal.archives-ouvertes.fr/inria-00333903
Scheduling workflow applications on processors with different capabilities, Future Generation Computer Systems, vol.22, issue.6, pp.665-675, 2006. ,
DOI : 10.1016/j.future.2005.11.002
List Scheduling Algorithm for Heterogeneous Systems by an Optimistic Cost Table, IEEE Transactions on Parallel and Distributed Systems, vol.25, issue.3, pp.682-694, 2014. ,
DOI : 10.1109/TPDS.2013.57
A compile-time scheduling heuristic for interconnection-constrained heterogeneous processor architectures, IEEE Transactions on Parallel and Distributed Systems, vol.4, issue.2, pp.175-187, 1993. ,
DOI : 10.1109/71.207593
Complete Register Allocation Problems, SIAM Journal on Computing, vol.4, issue.3, pp.226-248, 1975. ,
DOI : 10.1137/0204020
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.221.7491
Register allocation via graph coloring, Rice University, 1992. ,
Register allocation and spilling via graph coloring, ACM SIGPLAN Notices, vol.39, issue.4, pp.66-74, 2004. ,
DOI : 10.1145/989393.989403
Gang scheduling with memory considerations, Proceedings 14th International Parallel and Distributed Processing Symposium. IPDPS 2000, pp.109-114, 2000. ,
DOI : 10.1109/IPDPS.2000.845971
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.161.1946
On the storage requirement in the out-of-core multifrontal method for sparse factorization, ACM Transactions on Mathematical Software, vol.12, issue.3, pp.249-264, 1986. ,
DOI : 10.1145/7921.11325
Scheduling Tree-Shaped Task Graphs to Minimize Memory and Makespan, 2013 IEEE 27th International Symposium on Parallel and Distributed Processing, pp.839-850, 2013. ,
DOI : 10.1109/IPDPS.2013.55
URL : https://hal.archives-ouvertes.fr/hal-00740105
Memory-Aware List Scheduling for Hybrid Platforms, 2014 IEEE International Parallel & Distributed Processing Symposium Workshops, 2014. ,
DOI : 10.1109/IPDPSW.2014.80
URL : https://hal.archives-ouvertes.fr/hal-00944336
Stack-based scheduling of realtime processes, Real-Time Systems, vol.1, issue.3, pp.67-99, 1991. ,
DOI : 10.1007/BF00365393
The Pebbling Problem is Complete in Polynomial Space, SIAM Journal on Computing, vol.9, issue.3, pp.513-524, 1980. ,
DOI : 10.1137/0209038
Platform-based design from parallel C specifications, IEEE Transactions on Computer-Aided Design of Integrated Circuits and Systems, vol.24, issue.12, pp.1811-1826, 2005. ,
DOI : 10.1109/TCAD.2005.852431
URL : https://hal.archives-ouvertes.fr/hal-00017411
OrccE Multimedia Development Made Easy, Proceedings of the 21st ACM International Conference on Multimedia, pp.863-866, 2013. ,
Software Code Generation for the RVC-CAL Language, Journal of Signal Processing Systems, vol.29, issue.12, pp.203-213, 2009. ,
DOI : 10.1007/s11265-009-0390-z
URL : https://hal.archives-ouvertes.fr/hal-00407950
MAPS: Mapping Concurrent Dataflow Applications to Heterogeneous MPSoCs, IEEE Transactions on Industrial Informatics, vol.9, issue.1, pp.527-545, 2013. ,
DOI : 10.1109/TII.2011.2173941
Vérifcation de propriétés logico-temporelles de spécifcations SystemC TLM, 2011. ,
Parallel simulation of systemC TLM 2.0 compliant MPSoC on SMP workstations, 2010 Design, Automation & Test in Europe Conference & Exhibition (DATE 2010), pp.606-609, 2010. ,
DOI : 10.1109/DATE.2010.5457136
URL : https://hal.archives-ouvertes.fr/hal-00748083
Monotonicity and run-time scheduling, Proceedings of the seventh ACM international conference on Embedded software, EMSOFT '09, pp.177-186, 2009. ,
DOI : 10.1145/1629335.1629359
URL : http://eprints.eemcs.utwente.nl/19113/01/poster_bears2010.pdf
Dynamic scheduling of stream programs on embedded multi-core processors, Proceedings of the eighth IEEE/ACM/IFIP international conference on Hardware/software codesign and system synthesis, CODES+ISSS '12, pp.93-102, 2012. ,
DOI : 10.1145/2380445.2380465
A Discussion in Favor of Dynamic Scheduling for Regular Applications in Many-core Architectures, 2012 IEEE 26th International Parallel and Distributed Processing Symposium Workshops & PhD Forum, pp.1591-1600, 2012. ,
DOI : 10.1109/IPDPSW.2012.200
Scheduling of parallelized synchronous datafow actors, 2013 International Symposium on System on Chip (SoC), pp.1-10, 2013. ,
Static Scheduling of Synchronous Data Flow onto Multiprocessors for Embedded DSP Systems, 2011 Third International Conference on Measuring Technology and Mechatronics Automation, pp.338-341, 2011. ,
DOI : 10.1109/ICMTMA.2011.655
A generalized static data fow clustering algorithm for mpsoc scheduling of multimedia applications, Proceedings of the 8th ACM international conference on Embedded sofware, pp.189-198, 2008. ,
Mapping a Data-fow Programming Model Onto Heterogeneous Platforms, Proceedings of the 13th ACM SIGPLAN/SIGBED International Conference on Languages, Compilers, Tools and Teory for Embedded Systems, pp.61-70 ,
A Model-Based Schedule Representation for Heterogeneous Mapping of Datafow Graphs, pp.70-81, 2011. ,
Multiprocessor Scheduling of Datafow Programs within the Reconfgurable Video Coding Framework, Algorithm-Architecture Matching for Signal and Image Processing, pp.237-251, 2011. ,
Efcient multicore scheduling of datafow process networks, Signal Processing Systems (SiPS), pp.198-203, 2011. ,
Towards run-time actor mapping of dynamic datafow programs onto multi-core platforms, 2013 8th International Symposium on Image and Signal Processing and Analysis (ISPA), pp.732-737, 2013. ,
Efcient sofware synthesis of dynamic datafow programs, 2014 IEEE International Conference on Acoustics, Speech and Signal Processing, pp.2014-4988 ,
Specifying Concurrent Program Modules, ACM Transactions on Programming Languages and Systems, vol.5, issue.2, pp.190-222, 1983. ,
DOI : 10.1145/69624.357207
Applying the adaptive Hybrid Flow-Shop scheduling method to schedule a 3GPP LTE physical layer algorithm onto many-core digital signal processors, 2013 NASA/ESA Conference on Adaptive Hardware and Systems (AHS-2013), pp.123-129, 2013. ,
DOI : 10.1109/AHS.2013.6604235
URL : https://hal.archives-ouvertes.fr/hal-00877643
FPGA-based design and implementation of the 3GPP-LTE physical layer using parameterized synchronous datafow techniques, IEEE International Conference on Acoustics, Speech and Signal Processing -Proceedings, pp.1510-1513, 2010. ,
Te Yale Book of Qotations, 2006. ,
Infrastructure de compilation pour des programmes fux de données, INSA de Rennes, 2010. ,
The Reconfigurable Video Coding Standard [Standards in a Nutshell, IEEE Signal Processing Magazine, vol.27, issue.3, pp.159-167, 2010. ,
DOI : 10.1109/MSP.2010.936032
White Paper: An Overview of H. 264 Advanced Video Coding. Vcodex, 2007. ,
