Nouvelle génération de dispositif à microscope de grande ouverture pour le piégeage d’atomes individuels - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2014
New generation of diffraction limited large numerical aperture optics for single atom manipulation
This thesis presents the early work done on a new setup that we have developped for trapping single atoms in an optical tweezer using only one diffraction limited large numerical aperture aspheric lens. Together with an experimental optical measurement of a 1µm laser beam waist created by such an aspheric lens, we showed that the diffraction limited transverse field of the lens is about plus or minus 25 µm. The ability of this new setup to trap single atoms is demonstrated and some crucial parameters are then determined : survival time in the dark, heating rate, fluorescence light polarisation, oscillation frequencies. During this PhD, we did focus our attention especially on determining the energy distribution of the single trapped atoms. A release and recapture technique along with the spectroscopic study of the energy levels occupation helped us show a termal behavior of a succession of single atoms in an optical twezer. By using common laser cooling techniques associated with adiabatic down ramping cooling, we showed that a reduction by a factor 100 of the mean energy corresponding to a mean vibrationnal energy level of about 4 and a minimum temperature of 1,75 µK. Spatial manipulation of single atoms and qubits was also studied. Using a tip-tilt platform, a second trap is set on the experiment and the transfer from one trap to the other, as well as the displacement of one trap with help of the platform, are experimentally studied. Both the temperature of the atoms and the qubit lifetime are showed to be insensitive to these manipulations.
Cette thèse présente les premiers travaux réalisés autour d’un nouveau dispositif expérimental de piégeage d’atomes individuels utilisant une unique lentille asphérique de grande ouverture numérique. Au cours de cette thèse, nous avons testé les propriétés optiques de la lentille et démontré la formation d’un col laser de 1 µm ainsi qu’un champ transverse sur lequel la lentille est limitée par diffraction de plus ou moins 25 µm. Après avoir démontré la capacité de ce système à piéger des atomes uniques, les caractérisations usuelles des conditions de piégeage ont été conduites: durée de vie, taux de chauffage, polarisation de la lumière de fluorescence, fréquences d’oscillations. Cette thèse s’est intéressée spécifiquement à la distribution d’énergie des atomes uniques piégés. La technique de lâcher et recapture combinée à une étude spectroscopique de l’occupation du piège par les atomes a conduit à la vérification du caractère thermique de la distribution d’énergie des atomes. Par un refroidissement laser combiné à un refroidissement adiabatique, une température minimale de 1,75 µK sans pertes d’atomes est obtenue avec un niveau vibrationnel moyen occupé égal à 4. Ces résultats sont très encourageants dans le contexte de l’information quantique où la température est souvent la principale limite physique à la durée de vie des cohérences d’un bit quantique. La dernière partie de cette thèse revient sur la problématique de la manipulation spatiale d’atomes uniques. Envisagé dans le cadre de la réalisation d’un calculateur quantique, le transfert d’un bit quantique et son déplacement dans l’espace sur une échelle compatible avec les caractéristiques d’un calculateur sont successivement étudiés. Ces travaux ont montré que ni l’état externe des atomes (au travers de leur température) ni leur état interne (à travers la durée de vie des cohérences d’un bit quantique) sont affectés par ce type de manipulations.
VA2_TUCHENDLER_CHARLES_14112014.pdf (5.52 Mo) Télécharger le fichier
tel-01182454 , version 1 (31-07-2015)
  • HAL Id : tel-01182454 , version 1
Charles Tuchendler. Nouvelle génération de dispositif à microscope de grande ouverture pour le piégeage d’atomes individuels. Optique [physics.optics]. Institut d’Optique Graduate School, 2014. Français. ⟨NNT : 2014IOTA0012⟩. ⟨tel-01182454⟩
680 Consultations
557 Téléchargements
