Impact des extraits organiques de particules diesel (DEPe) sur la physiologie de macrophages humains polarisés in vitro - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2015
Impact of diesel exhaust particle extract (DEPe) on the physiology of in vitro polarized human macrophages
Macrophages (MΦ), well-known to play a key role in immune response, also respond to environmental toxic chemicals such as diesel exhaust particles (DEP), an air pollutant recently classified as carcinogenic to humans. MΦ are heterogeneous and plastic cells which activate according to their microenvironment into either an M1 subtype (so called classically activated or pro-inflammatory) under IFNγ and LPS stimulation or an M2 subtype (so called alternatively activated or anti-inflammatory) under IL-4 and/or IL-13 stimulation. However, potential effects of DEPs on M1/M2 MΦ polarization remain poorly documented. First, we characterized the expression marker of in vitro M-CSF-differentiated MΦ from human monocytes and activated into the M1 or M2 subtypes. Our main results show that M-CSF-generated MΦ considered as anti-inflammatory are actually able to switch to an M1 phenotype after IFNγ/LPS stimulation. Furthermore, the markers identified in this study were used to assess the impact of organic extracts of DEP (DEPe) on MΦ polarization and more generally on their physiology. DEPe alter some M1 and M2 markers expressed by polarized MΦ, without causing the overall inhibition of the M1 and M2 polarization process or the switch to a different phenotype. This phenotype alteration is associated with a decrease in the LPS-dependent inflammatory response in M1 MΦ and the chemotactic capacities in M2 MΦ. DEPe decrease the secretion of some cytokines and chemokines such as IL-6, IL-12p40 and CCL18 via AhR and/or Nrf2 activation. At the same time, we show that M1 and M2 MΦ in response to DEPe are able to secrete a sufficient level of a pro-fibrotic growth factor, the platelet derived growth factor B (PDGF-B) via AhR activation, leading to stimulation of lung fibroblast proliferation. Finally, these works show that DEPe have immunotoxic properties with regards to the physiology of human in vitro polarized MΦ. This immunotoxicity may then contribute to the deleterious effects of these urban environmental contaminants on human health.
Les macrophages (MΦ), des cellules clefs de la réponse immunitaire peuvent répondre à des contaminants environnementaux comme les particules diesel (DEP), des polluants atmosphériques récemment classés cancérigènes pour l'Homme. Les MΦ sont des cellules hétérogènes et plastiques qui s'activent en fonction de leur microenvironnement soit en MΦ M1 (dits classiquement activés ou pro-inflammatoires) sous l'effet de l'INFγ et du LPS soit en MΦ M2 (dits alternativement activés ou réparateurs) sous l'effet de l'IL-4 et/ou de l'IL-13. Les effets des DEP sur la polarisation M1/M2 des MΦ restent peu documentés. Nous avons dans un premier temps caractérisé l'expression des marqueurs des MΦ différenciés in vitro en présence de M-CSF à partir de monocytes humains et polarisés en sous-type M1 ou M2. Nos principaux résultats montrent que les MΦ différenciés au M-CSF considérés comme des MΦ anti-inflammatoires, sont en réalité capables de s'activer vers un phénotype M1 après une stimulation au LPS/IFNγ. De plus, les marqueurs mis en évidence au cours de ce travail ont permis d'évaluer l'impact d'extraits organiques de DEP (DEPe) sur la polarisation des MΦ et plus généralement sur leur physiologie. Les DEPe altèrent l'expression de certains marqueurs M1 et M2 des MΦ, sans toutefois provoquer d'inhibition globale des processus de polarisation M1 et M2 ou de transition d'un phénotype vers un autre. Cette altération du phénotype est associée à une diminution de la réponse inflammatoire LPS-dépendante dans les MΦ M1 et des capacités chimiotactiques des MΦ M2. Les DEPe diminuent la sécrétion de certaines cytokines et chimiokines comme l'IL-6, l'IL-12p40 et le CCL18 via l'activation d'AhR et/ou de Nrf2. Parallèlement, nous montrons que les MΦ M1 et M2 exposés aux DEPe sécrètent le platelet deried growth factor B (PDGF-B), un facteur de croissance profibrosant, via l'activation d'AhR en quantité suffisante pour stimuler la prolifération de fibroblastes pulmonaires. Au total, ces travaux démontrent que les DEP possèdent des propriétés immunotoxiques vis-à-vis de la physiologie des macrophages humains polarisés in vitro. Cette immunotoxicité pourrait participer aux effets délétères de ces contaminants environnementaux urbains sur la santé humaine.
JAGUIN_Marie.pdf (8.04 Mo) Télécharger le fichier
tel-01188679 , version 1 (31-08-2015)
  • HAL Id : tel-01188679 , version 1
Marie Jaguin. Impact des extraits organiques de particules diesel (DEPe) sur la physiologie de macrophages humains polarisés in vitro. Santé publique et épidémiologie. Université de Rennes, 2015. Français. ⟨NNT : 2015REN1S011⟩. ⟨tel-01188679⟩
256 Consultations
502 Téléchargements
