Maintien à court terme de l'information chez l'enfant de 2 à 6 ans : oubli temporel et aide au maintien du but - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2014
Maintaining information in Short-Term Memory between 2 and 6 years old of age : temporal forgetting and helping in maintaining the goal
Working memory is an essential component of thought that is highly involved in learning and academic achievement. However, it is rarely studied in preschoolers, mainly because of a lack of suitable paradigms. Therefore, this thesis investigated the functioning of working memory in children between 2 and 6 years. For this purpose, two original paradigms were used. They were designed to be close to game situations which should help young children to focus their attention on the task. Firstly it was shown that the recall performance decreased over time, even in the absence of an interfering task. Children of this age therefore use a passive maintenance, i.e. without spontaneously implementing any strategy of maintenance. Furthermore, the decline of the information was similar through age. For the first time, it has been demonstrated that the rate of information forgetting did not vary between 2 and 6. Finally, none of these two factors, i.e. implementation of a strategy of maintenance and change in the speed of forgetting can explain the increase in memory capacity between 2 and 6 years of age. Secondly, it has been shown that the intrinsic characteristics of the task could lead to improved recall performance, perhaps by inducing a strategy of maintenance. Particularly, the implementation of a motor activity, i.e. walking during the retention period, has enabled these young children to counteract to some extent the temporal decay of information. Then, the implementation of a motor activity, by directing the attention of young children to a visual cue related to the goal of the task, help them to maintain in memory the purpose of the task. Attentional resources could be harnessed to improve performance of recall, perhaps by implementing a retention strategy.
La mémoire de travail est un composant essentiel de la pensée qui est fortement impliquée dans les apprentissages et la réussite scolaires. Pourtant, elle est rarement étudiée chez l’enfant d’âge préscolaire, du fait notamment d’un manque de paradigmes adaptés. Cette thèse visait donc à étudier le fonctionnement de la mémoire de travail chez cette population, soit entre 2 et 6 ans. Pour cela, deux paradigmes originaux ont été utilisés. Ils ont été conçus pour être proches de situations de jeux, propices à aider le jeune enfant à focaliser son attention sur la tâche. Ainsi, il a tout d’abord été montré que les performances de rappel diminuaient au fil du temps, et ce, même en l’absence de tâche interférente. Les enfants de cette tranche d’âge opèrent donc un maintien passif de l’information, i.e. sans mise en œuvre spontanée de stratégie de maintien de l’information. De plus, le déclin de l’information était similaire au travers de l’âge. Pour la première fois, il a donc été mis en évidence que la vitesse d’oubli de l’information ne variait pas entre 2 et 6 ans. Finalement, aucun de ces deux facteurs, i.e. mise en œuvre de stratégie de maintien de l’information et modification de la vitesse d’oubli de l’information, ne peut être avancé pour expliquer l’augmentation des capacités mémorielles entre 2 et 6 ans. Ensuite, il a été montré que les caractéristiques intrinsèques de la tâche pouvaient conduire à une amélioration des performances de rappel, peut-être par la mise en œuvre d’une stratégie de maintien. Notamment, la réalisation d’une activité motrice, i.e. marche durant le délai de rétention, a permis à ces jeunes enfants de contrecarrer dans une certaine mesure l’oubli temporel de l’information. La mise en œuvre d’une activité motrice, en dirigeant l’attention du jeune enfant vers un indice visuel du but à atteindre, aiderait celui-ci à maintenir le but de la tâche en mémoire. Les ressources attentionnelles ainsi dégagées pourraient être mises au service d’une amélioration des performances de rappel, peut-être par la mise en œuvre d’une stratégie de maintien.
these_A_BERTRAND_Raphaelle_2014.pdf (2.97 Mo) Télécharger le fichier
tel-01191698 , version 1 (02-09-2015)
  • HAL Id : tel-01191698 , version 1
Raphaëlle Bertrand. Maintien à court terme de l'information chez l'enfant de 2 à 6 ans : oubli temporel et aide au maintien du but. Psychologie. Université de Bourgogne, 2014. Français. ⟨NNT : 2014DIJOL023⟩. ⟨tel-01191698⟩
290 Consultations
2286 Téléchargements
