On the discrete-time integral sliding-mode control, Automatic Control, IEEE Transactions on, vol.52, pp.709-715, 2007. ,
An introduction to SSSSSSS, Rapport Technique RT-0340 ,
Numerical Methods for Nonsmooth Dynamical Systems: Applications in Mechanics and Electronics, of Lecture Notes in Applied and Computational Mechanics, 2008. ,
Implicit Euler numerical scheme and chatteringfree implementation of sliding mode systems, Systems & Control Letters, vol.59, issue.159, pp.284-293, 2010. ,
Chattering-free digital sliding-mode control with state observer and disturbance rejection, Automatic Control, IEEE Transactions on, vol.57, issue.159, pp.1087-1101, 2012. ,
Sliding mode control design based on Ackermann's formula, Automatic Control, IEEE Transactions on, vol.43, pp.234-237, 1998. ,
On certain switching speciics in nonlinear automatic control systems with a piecewise-smooth characteristics of nonlinear element, pp.1017-1028, 1957. ,
Fundamentals of the theory of discontinuous systems. I, Avtomatika i Telemekhanika, pp.33-47, 1974. ,
Fundamentals of the theory of discontinuous systems. II, Avtomatika i Telemekhanika, pp.39-61, 1974. ,
P, Functions of Bounded Variation and Free Discontinuity Problems, p.178, 2000. ,
Über stückweise lineare Diierentialgleichungen, die bei Regelungsproblemen auftreten I, Archiv der Mathematik, vol.7, pp.148-156, 1956. ,
Über stückweise lineare Diierentialgleichungen, die bei Regelungsproblemen auftreten II, Archiv der Mathematik, vol.7, pp.157-164, 1956. ,
Numerical precision for diierential inclusions with uniqueness, Mathematical Modelling and Numerical Analysis, pp.427-460, 2002. ,
HEM5 user's guide, technical report, 1994. ,
Nonsmooth Mechanics: Models, Dynamics and Control, Communications and Control Engineering, 1999. ,
Absolute stability and the lagrange-dirichlet theorem with monotone multivalued mappings, Systems & control letters, vol.51, pp.343-353, 2004. ,
Dissipative Systems Analysis and Control: Theory and Applications, Communications and Control Engineering, 2007. ,
Complementarity Methods in the Analysis of Piecewise Linear Dynamical Systems, 2001. ,
Consistency of a timestepping method for a class of piecewise-linear networks, Circuits and Systems I: Fundamental Theory and Applications, IEEE Transactions on, vol.49, pp.349-357, 2002. ,
On linear passive complementarity systems, European Journal of Control, vol.8, pp.220-237, 2002. ,
Piecewise Linear Homotopies and AAne Variational Inequalities, 1994. ,
A pivotal method for aane variational inequalities, Mathematics of Operations Research, vol.21, pp.44-64, 1996. ,
A eld guide to the matrix classes found in the literature of the linear complementarity problem, Journal of Global Optimization, vol.46, pp.571-580, 2010. ,
The Linear Complementarity Problem, no, Classics in Applied Mathematics, pp.52-98, 2009. ,
Diierence methods for diierential inclusions: a survey, SIAM Review, pp.263-294, 1992. ,
On discrete-time sliding modes, Proc. of IFAC Nonlinear Control System Design Conf, pp.273-278, 1989. ,
The invariance conditions in variable structure systems, Automatica, vol.5, pp.287-295, 1969. ,
A short course in solving equations with pl homotopies, pp.73-143, 1976. ,
Sliding Mode Control, of Systems and Control Book Series, p.72, 1998. ,
Higher-order sliding modes in binary control systems, Soviet Physics Doklady, p.291, 1986. ,
Diierential equations with discontinuous right-hand side, Matematicheskii Sbornik, pp.99-128, 1960. ,
Discontinuous Automatic Control, 1953. ,
Generation of nite diierence formulas on arbitrarily spaced grids, Mathematics of Computation, vol.51, pp.699-706, 1988. ,
An averaging approach to chattering, Automatic Control, IEEE Transactions on, vol.46, pp.1260-1265, 2001. ,
Sliding mode control of a discrete system, Systems & Control Letters, vol.14, issue.38, pp.145-152, 1990. ,
Discrete-time variable structure control systems, Industrial Electronics, IEEE Transactions on, vol.42, pp.117-122, 1995. ,
Robust discrete-time chattering free sliding mode control, Systems & Control Letters, pp.41-60, 2000. ,
Solving Ordinary Diierential Equations I: Nonstii Problems, of Springer Series in Computational Mathematics, p.14, 1993. ,
On sliding mode observers via equivalent control approach, International Journal of Control, vol.71, pp.1051-1067, 1998. ,
Robust sampled?data control of switched aane systems , Automatic Control, IEEE Transactions on, vol.58, pp.2922-2928, 2013. ,
Variable structure control with generalized relays: A simple convex optimization approach, Automatic Control, IEEE Transactions on, vol.60, pp.497-502, 2015. ,
ODEPACK, a systematized collection of ODE solvers, pp.55-64, 1983. ,
Mathematical Systems Theory I, of Texts in Applied Mathematics, 2005. ,
Fundamentals of Convex Analysis, Grundlehren Text Editions, 2001. ,
Topics in Matrix Analysis, 1991. ,
Linear matrix equations from an inverse problem of vibration theory, Linear Algebra and its Applications, vol.246, pp.31-47, 1996. ,
On discrete-time variable structure sliding mode control, Systems & Control Letters, vol.38, pp.283-288, 1999. ,
Matplotlib: a 2D graphics environment, Computing in Science & Engineering, pp.90-95, 2007. ,
Control Systems of Variable Structure, 1976. ,
Dynamics in the presence of unilateral contacts and dry friction: A numerical approach, in Unilateral Problems in Structural Analysis, International Centre for Mechanical Sciences, pp.151-196, 1987. ,
SciPy: Open source scientiic tools for Python ,
Implicit Runge-Kutta methods for diierential inclusions, Numerical Functional Analysis and Optimization, pp.11-937, 1990. ,
The implicit midpoint rule applied to discontinuous differential equations, Computing, pp.49-94, 1992. ,
Hermitian and nonnegative deenite solutions of linear matrix equations, SIAM Journal on Applied Mathematics, pp.31-579, 1976. ,
Sliding mode control of discrete-time systems, Journal of Dynamic Systems, Measurement, and Control, vol.122, p.793, 2000. ,
On the stability od discrete-time sliding mode control systems, Automatic Control IEEE Transactions on, vol.34, pp.1021-1022, 1989. ,
On output tracking using dynamic output feedback discrete-time sliding-mode controllers, Automatic Control, IEEE Transactions on, vol.52, pp.1975-1981, 2007. ,
Euler's method revisited, Proc. Steklov Inst, pp.473-494, 1995. ,
Sliding order and sliding accuracy in sliding mode control, International Journal of Control, vol.58, pp.1247-1263, 1993. ,
Robust exact diierentiation via sliding mode technique, Automatica, vol.34, pp.379-384, 1998. ,
Higher-order sliding modes, diierentiation and output-feedback control, International Journal of Control, vol.76, pp.924-941, 2003. ,
Chattering analysis, Automatic Control, IEEE Transactions, vol.55, pp.1380-1389, 2010. ,
Large-Scale Computing for Complementarity and Variational Inequalities, 2010. ,
A total chattering-free sliding mode control for sampleddata systems, American Control Conference, Proceedings of the 2004, pp.1940-1945, 2004. ,
Disturbance compensation in digital sliding mode, EUROCON-International Conference on Computer as a Tool (EUROCON), pp.1-4, 2011. ,
Uniqueness of solutions of linear relay systems, Automatica, pp.35-467, 1999. ,
A decomposition property for a class of square matrices, Applied Mathematics Letters, vol.4, pp.67-69, 1991. ,
Sliding mode-based minimum variance and generalized minimum variance controls with (T ) and (T ) accuracy, Electrical Engineering (Archiv fur Elektrotechnik), pp.229-237, 2004. ,
Nineteen dubious ways to compute the exponential of a matrix, twenty--ve years later, SIAM Review, vol.45, pp.3-49, 2003. ,
Unilateral contact and dry friction in nite freedom dynamics, Nonsmooth Mechanics and Applications of International Centre for Mechanical Sciences, pp.1-82, 1988. ,
Finite time stability and robust control synthesis of uncertain switched systems, SIAM Journal on Control and Optimization, vol.43, pp.1253-1271, 2005. ,
Multibody Dynamics with Unilateral Contacts, Wiley Series in Nonlinear Science, 1996. ,
Lectures on Maximal Monotone Operators, arXiv:math/9302209 [math.FA] On solution concepts and wellposedness of linear relay systems, Automatica, pp.39-2139, 1993. ,
Dynamical behaviors of an Euler discretized sliding mode control systems, Automatic Control, IEEE Transactions on, vol.59, pp.2525-2529, 2014. ,
Convex Analysis, 1997. ,
Error analysis for implicit approximations to solutions to Cauchy problems, SIAM Journal on Numerical Analysis, vol.33, issue.39, pp.68-87, 1996. ,
On the stability of discretetime sliding mode control systems, Automatic Control IEEE Transactions on, vol.32, pp.930-932, 1987. ,
Static characteristics of a three way electropneumatic servovalve, Proceedings of the 12th Conference on Fluid Power Technology, pp.643-645, 1996. ,
Sliding Mode Control and Observation, Control Engineering ,
A novel adaptive-gain supertwisting sliding mode controller: Methodology and application, Automatica, pp.48-759, 2012. ,
Non-linear discrete variable structure systems in quasi-sliding mode, International Journal of control, vol.54, pp.1171-1187, 1991. ,
Mathematical Control Theory: Deterministic Finite Dimensional Systems, of Textbooks in Applied Mathematics, 1998. ,
Implementation of variable structure control for sampled-data systems, Robust Control via Variable Structure and Lyapunov Techniques, pp.87-106, 1996. ,
An O(T ) boundary layer in sliding mode for sampled-data systems, Automatic Control, IEEE Transactions on, vol.45, pp.482-485, 2000. ,
Variable structure systems with sliding modes, Automatic Control, IEEE Transactions on, vol.22, pp.212-222, 1977. ,
Sliding Modes in Control and Optimization, Communications and Control Engineering, p.38, 1992. ,
Sliding mode control in discrete-time and diierence systems, Variable Structure and Lyapunov Control, pp.87-107, 1994. ,
The chattering analysis, in Power Electronics and Motion Control Conference, EPE-PEMC 12th International, IEEE, pp.2014-2019, 2006. ,
Observation of dynamical systems in the presence of bounded nonlinearities/uncertainties, in Decision and Control, 25th IEEE Conference on, pp.961-966, 1986. ,
Experimental comparisons between implicit and explicit implementations of discrete-time sliding mode controllers: Towards chattering suppression in output and input signals, Variable Structure Systems (VSS), 2014 13th International Workshop on, pp.1-6, 2014. ,
Comparisons between implicit and explicit discrete-time implementations of equivalentcontrol-based sliding mode controllers: input and output chattering suppression via the implicit method, Control Systems Technology, IEEE Transactions on, p.p. in press, 2015. ,
ZOH discretization eeect on higher-order sliding-mode control systems, Industrial Electronics, IEEE Transactions on, vol.55, pp.4055-4064, 2008. ,
Discretization eeect on equivalent control-based multi-input sliding-mode control systems, Automatic Control, IEEE Transactions on, vol.53, pp.1563-1569, 2008. ,
