22 2.1 Filter banks and transforms ? an introduction 22 2.1.2 General structure of filter banks, Maximally decimated filter banks ,
62 3 ,
80 3.2.1 Block switching for 80 3.2.2 Look ahead and time delay for transform, Temporal Noise Shaping, p.85 ,
88 4.1 Low Delay Block Switching for 88 4.1.1 Low delay transition, Compensation algorithm, p.95 ,
108 4.3.1 Relaxed Perfect Reconstruction equations, p.112 ,
Proposed Core Experiment for Enhanced Low Delay AAC, 2007. ,
Updated description for AAC ELD instantaneous block switching CE, 2007. ,
Additional information for AAC ELD instantaneous block switching CE, 2007. ,
Listening test results on block Switching Core Experiment for ELD-AAC, 2007. ,
Proposed draft for new Recommendation G.VBR-EV " Frame error robust narrowband and wideband embedded variable bit-rate coding of speech and audio from 8-32 kbit, pp.16-481, 2008. ,
Adaptive time-frequency resolution in modulated transform at reduced delay, 2008 IEEE International Conference on Acoustics, Speech and Signal Processing ,
DOI : 10.1109/ICASSP.2008.4518476
Adaptive time-frequency resolution in modulated transform at reduced delay " , 124 th AES Convention , preprint 7333, 2008. ,
ITU-T EV-VBR: A Robust 8-32 kbit/s Scalable Coder for Error Prone Telecommunications Channels, p.16, 2008. ,
Low-delay transform coding using weighting windows, pp.81144-81146, 2007. ,
Transform-based coding/decoding, with adaptive windows, 2007. ,
MPEG-4 Low Delay Audio Coding Based on the AAC Codec, 106th AES Convention, 1999. ,
A comparison of some algabraic structures for CELP coding of speech, Proc. IEEE International Conference on Acoustics, Speech and Signal Processing (ICASSP), pp.1953-1956, 1987. ,
Digital filtering by polyphase network:Application to sample-rate alteration and filter banks, IEEE Transactions on Acoustics, Speech, and Signal Processing, vol.24, issue.2, pp.109-114, 1976. ,
DOI : 10.1109/TASSP.1976.1162788
MP3 and AAC explained, Proc. AES 17th International Conference: High-Quality Audio Coding, 1999. ,
Highquality parametric spatial audio coding at low bit rates, Proc. 116th AES Conv, 2004. ,
Parametric Coding of Stereo Audio, EURASIP Journal on Advances in Signal Processing, vol.2005, issue.9, pp.1305-1322, 2005. ,
DOI : 10.1155/ASP.2005.1305
Parametric representation of Multichannel Audio based on Principal Component Analysis, Proc. 120th AES Conv, 2006. ,
URL : https://hal.archives-ouvertes.fr/hal-00381051
Parametric Coding of Stereo Audio based on Principal Component Analysis, 9th Int. Conf. on Digital Audio Effects DAFx'06, 2006. ,
URL : https://hal.archives-ouvertes.fr/hal-00380787
Incorporation of Biorthogonality into Lapped Transforms for Audio Compression, Proc. IEEE International Conference on Acoustics, Speech and Signal Processing (ICASSP), pp.3079-3082, 1995. ,
Finalization of CE on PVC for SBR, 2011. ,
Sphere packings, lattices, and groups, 1993. ,
Spectral Band Replication , a novel approach in audio coding, Proc. 112th AES Conv, 2002. ,
A Fast Algorithm For The Implementation of Filter Banks Based on Time Domain Aliasing ancellation, Int. Conf. on Acoust., Speech, Signal Proc, pp.2209-2212, 1991. ,
Codierung von Audiosignalen mit übberlappender Transformation und adaptiven Fensterfunktionen, 1989. ,
Aliasing reduction using complex-exponential modulated filterbanks, 2001. ,
Binaural cue coding: a novel and efficient representation of spatial audio, IEEE International Conference on Acoustics Speech and Signal Processing, pp.1841-1844, 2002. ,
DOI : 10.1109/ICASSP.2002.1006124
AC-2 and AC-3: Low Complexity Transform-Based Audio Coding, pp.54-72 ,
Auditory Patterns, Reviews of Modern Physics, vol.12, issue.1, 1940. ,
DOI : 10.1103/RevModPhys.12.47
Vector Quantization and Signal Compression, 1992. ,
DOI : 10.1007/978-1-4615-3626-0
Intensity stereo coding, 96th AES Conv, 1994. ,
Enhancing the Performance of Perceptual Audio Coders by Using Temporal Noise Shaping (TNS), 101 st AES Conv, 1996. ,
Exploiting Both Time and Frequency Structure in a System That Uses an Analysis/Synthesis Filterbank with High Frequency Resolution, 103 rd AES Conv, 1997. ,
MPEG Surround ? The ISO/MPEG standard for efficient and compatible multi-channel audio coding, J. Audio Eng. Soc, vol.56, issue.11, pp.932-955, 2008. ,
A Method for the Construction of Minimum Redundancy Codes, Proceedings of the IRE, pp.1098-1101, 1952. ,
Coding of Moving Pictures and Associated Audio for Digital Storage Media at up to About 1.5Mbit/s, 1992. ,
Coding of audio-visual objects, 2003. ,
Coding of audio-visual objects", MPEG-4, ISO/IEC 14496-3 Fourth Edition, 2009. ,
1534-1 03] ITU-R BS.1534-1, "Method for the subjective assessment of intermediate quality level of coding systems, 2003. ,
Low-complexity coding at 24 and 32 kbit/s for hands-free operation in systems with low frame loss, Annex C -14 kHz mode at 24, 32, and 48 kbit/s, 722.1 Annex C, 2005. ,
Transform-Domain Weighted Interleave Vector Quantization (TwinVQ), 101 st AES Conv, 1996. ,
Digital coding of waveforms. Principles and applications to speech and video, Signal Processing, vol.9, issue.2, 1984. ,
DOI : 10.1016/0165-1684(85)90053-2
Sum-difference stereo transform coding, [Proceedings] ICASSP-92: 1992 IEEE International Conference on Acoustics, Speech, and Signal Processing, pp.569-572, 1992. ,
DOI : 10.1109/ICASSP.1992.225993
An 8-bit/s speech coder based on conjugate structure CELP, IEEE International Conference on Acoustics Speech and Signal Processing ,
DOI : 10.1109/ICASSP.1993.319379
Cosine-modulated FIR filter banks satisfying perfect reconstruction, IEEE Transactions on Signal Processing, vol.40, issue.4, pp.770-783, 1992. ,
DOI : 10.1109/78.127951
An Algorithm for Vector Quantizer Design, IEEE Transactions on Communications, vol.28, issue.1, pp.84-94, 1980. ,
DOI : 10.1109/TCOM.1980.1094577
Least Squares Quantization in PCM's, 1957. ,
Lapped transforms for efficient transform/subband coding, IEEE Transactions on Acoustics, Speech, and Signal Processing, vol.38, issue.6, pp.969-978, 1990. ,
DOI : 10.1109/29.56057
Extended lapped transforms: fast algorithms and applications, ICASSP, vol.3, pp.14-171797, 1991. ,
DOI : 10.1109/icassp.1991.150693
Extended lapped transforms: properties, applications, and fast algorithms, IEEE Transactions on Signal Processing, vol.40, issue.11, pp.2703-2714, 1992. ,
DOI : 10.1109/78.165657
Signal Processing with Lapped Transforms, 1992. ,
An Introduction to the Psychology of Hearing, 2003. ,
Techniques de compression des signaux, 1995. ,
Report on the MPEG- 4 Audio Version 2 Verification Test, 1999. ,
A phase vocoder driven bandwidth extension method with novel transient handling for audio codecs, 126th AES Convention, 2009. ,
Unified Speech and Audio Coding Scheme for High Quality at Low Bit Rates, International Conference on Acoustics, Speech and Signal Processing, 2009. ,
Efficient vector quantization of LPC parameters at 24 bits/frame, Proc. IEEE Intern. Conf. on Acoustics, Speech and Signal Processing, pp.661-664, 1991. ,
Description of the France Telecom proposal for the Call for Evidence, 2001. ,
Analysis/Synthesis filter bank design based on time domain aliasing cancellation, IEEE Transactions on Acoustics, Speech, and Signal Processing, vol.34, issue.5, p.34, 1986. ,
DOI : 10.1109/TASSP.1986.1164954
Subband/Transform coding using filter bank designs based on time domain aliasing cancellation, ICASSP '87. IEEE International Conference on Acoustics, Speech, and Signal Processing, 1987. ,
DOI : 10.1109/ICASSP.1987.1169405
ITU-T G.729.1: AN 8-32 Kbit/S Scalable Coder Interoperable with G.729 for Wideband Telephony and Voice Over IP, 2007 IEEE International Conference on Acoustics, Speech and Signal Processing, ICASSP '07, 2007. ,
DOI : 10.1109/ICASSP.2007.366966
URL : https://hal.archives-ouvertes.fr/inria-00512646
Polyphase quadrature filters--A new subband coding technique, ICASSP '83. IEEE International Conference on Acoustics, Speech, and Signal Processing, pp.1280-1283, 1983. ,
DOI : 10.1109/ICASSP.1983.1172005
Product code vector quantizers for speech waveform coding, 1982. ,
Data compression: the complete reference, 2000. ,
Modified Discrete Cosine Transform ? Its Implications for Audio Coding and Error Concealment, Journal of Audio Eng. Soc, vol.51, issue.12, 2003. ,
MPEG-4 Enhanced Low Delay AAC ? A New Standard for High Quality Communication, 2008. ,
Code-excited linear prediction(CELP): High-quality speech at very low bit rates, ICASSP '85. IEEE International Conference on Acoustics, Speech, and Signal Processing, pp.937-940, 1985. ,
DOI : 10.1109/ICASSP.1985.1168147
Modulated Filter Banks with Arbitrary System Delay: Efficient Implementations and the Time- Varying Case, IEEE Transactions on Signal Processing, vol.48, issue.3, 2000. ,
A Mathematical Theory of Communication, Bell System Technical Journal, vol.27, issue.3, pp.379-423, 1948. ,
DOI : 10.1002/j.1538-7305.1948.tb01338.x
A low power SBR algorithm for the MPEG-4 audio standard and its DSP implementation, AES 116 th Convention, 2004. ,
The modulated lapped transform, its time-varying forms, and its applications to audio coding standards, IEEE Transactions on Speech and Audio Processing, vol.5, issue.4, 1997. ,
DOI : 10.1109/89.593311
A comparative study of LPC parameter representations and quantisation schemes for wideband speech coding, Digital Signal Processing, vol.17, issue.1, pp.114-137, 2007. ,
DOI : 10.1016/j.dsp.2005.10.002
Multirate Systems and Filter Banks, 1993. ,
Arithmetic coding for data compression, Communications of the ACM, vol.30, issue.6, 1987. ,
DOI : 10.1145/214762.214771
Psychoacoustics -Facts and Models, 2007. ,
