On unsupervised segmentation of remotely sensed imagery using nonlinear regression, International Journal of Remote Sensing, vol.46, issue.7, pp.1407-1415, 1996. ,
DOI : 10.1109/78.212743
Les influences maritimes sur le climat du Maroc atlantique central. Une analyse par télédétection spatiale, 1993. ,
Produits opérationnels d'océanographie spatiale pour le suivi et l'analyse du phénomène d'upwelling marocain, pp.49-62, 2005. ,
Fronts and eddies as key structures in the habitat of marine fish larvae: opportunity, adaptive response and competitive advantage, Scientia Marina, vol.70, issue.S2, pp.105-122, 2006. ,
DOI : 10.3989/scimar.2006.70s2105
Computer Vision, pp.186-188, 1982. ,
An algorithm for oceanic front detection in chlorophyll and SST satellite imagery, Journal of Marine Systems, vol.78, issue.3, pp.319-326, 2009. ,
DOI : 10.1016/j.jmarsys.2008.11.018
Fuzzy algorithms for pattern recognition, Defense Technical Information Center, 1983. ,
Pattern Recognition with Fuzzy Objective Function Algorithms, 1981. ,
DOI : 10.1007/978-1-4757-0450-1
A computational approach to edge detection. Pattern Analysis and Machine Intelligence, IEEE Transactions, issue.6, pp.8679-698, 1986. ,
Etude par teledetection des temperatures et turbidites des eaux au large de la Loire Atlantique. Ecole normale superieure, 1981. ,
The Temperature of Turbulent Flows, Journal de Physique II, vol.6, issue.1, pp.105-114, 1996. ,
DOI : 10.1051/jp2:1996172
URL : https://hal.archives-ouvertes.fr/jpa-00248278
Edge Detection Algorithm for SST Images, Journal of Atmospheric and Oceanic Technology, vol.9, issue.1, pp.67-80, 1992. ,
DOI : 10.1175/1520-0426(1992)009<0067:EDAFSI>2.0.CO;2
Comparative study of two recent edge-detection algorithms designed to process sea-surface temperature fields. Geoscience and Remote Sensing, IEEE Transactions on, vol.29, issue.1, pp.175-177, 1991. ,
Adaptive image region-growing, IEEE Transactions on Image Processing, vol.3, issue.6, pp.868-872, 1994. ,
DOI : 10.1109/83.336259
Satellite remote sensing for an ecosystem approach to fisheries management, ICES Journal of Marine Science, vol.68, issue.4, pp.651-666, 2011. ,
DOI : 10.1093/icesjms/fsq195
URL : https://hal.archives-ouvertes.fr/ird-00576217
A split-window algorithm for land surface temperature from advanced very high resolution radiometer data: Validation and algorithm comparison, Journal of Geophysical Research: Atmospheres, vol.27, issue.C8, pp.16697-16713, 1997. ,
DOI : 10.1029/97JD00929
A cluster separation measure. Pattern Analysis and Machine Intelligence, IEEE Transactions, issue.2, pp.1224-227, 1979. ,
Coastal upwelling and associated retention indices derived from satellite SST. Application to Octopus vulgaris recruitment, Oceanologica Acta, vol.23, issue.4, pp.391-408, 2000. ,
DOI : 10.1016/S0399-1784(00)01113-0
Phytoplankton blooms : The basics (PDF). NOAA FKNMS, 2012. ,
Pattern Classification and Scene Analysis, 1973. ,
A Fuzzy Relative of the ISODATA Process and Its Use in Detecting Compact Well-Separated Clusters, Journal of Cybernetics, vol.3, issue.3, pp.32-57, 1973. ,
DOI : 10.1080/01969727308546046
On the influence of the earth's rotation on ocean currents. Arkiv for matematik, astronomi och fysik, pp.131-141, 1905. ,
Cluster analysis of multivariate data : Efficiency versus interpretability of classification, Biometrics, vol.21, issue.3, pp.768-769, 1965. ,
On the singularity structure of fully developed turbulence, Turbulence and Predictability in Geophysical Fluid Dynamics and ClimateDynamics, pp.84-88, 1985. ,
A new method of choosing the number of clusters for the fuzzy c-means method, Proceedings Fifth Fuzzy Systems Symp, pp.247-250, 1989. ,
Comparison of neural models for document clustering, Soft Computing Applications to Intelligent Information Retrieval on the Internet, pp.287-305, 2003. ,
DOI : 10.1016/j.ijar.2003.07.012
Les satellites de l'environnement : description sommaire de la série, NOAA-A.1. Initiations-Documentations Techniques : Télédétection. ORSTOM, 1981. ,
Fuzzy clustering with a fuzzy covariance matrix, 1978 IEEE Conference on Decision and Control including the 17th Symposium on Adaptive Processes, pp.761-766, 1978. ,
DOI : 10.1109/CDC.1978.268028
Statistical and structural approaches to texture, Proceedings of the IEEE, pp.786-804, 1979. ,
DOI : 10.1109/PROC.1979.11328
Use Of Texture Operators In Segmentation, Optical Engineering, vol.25, issue.11, pp.25251200-251200, 1986. ,
DOI : 10.1117/12.7973982
Classification and Clustering, Journal of Marketing Research, vol.18, issue.4, 1975. ,
DOI : 10.2307/3151350
Characteristics of maximum-value composite images from temporal AVHRR data, International Journal of Remote Sensing, vol.7, issue.11, pp.1417-1434, 1986. ,
DOI : 10.1016/0034-4257(83)90053-6
Edge detection applied to satellite imagery of the oceans, IEEE Transactions on Geoscience and Remote Sensing, vol.27, issue.1, pp.46-56, 1989. ,
DOI : 10.1109/36.20274
Fuzzy Cluster Analysis-Methods for Classification : Data Analysis and Image Recognition, 1999. ,
Fundamentals of Digital Image Processing, 1989. ,
Feature definition in pattern recognition with small sample size, Pattern Recognition, vol.10, issue.2, pp.85-97, 1978. ,
DOI : 10.1016/0031-3203(78)90016-X
Data clustering: a review, ACM Computing Surveys, vol.31, issue.3, pp.264-323, 1999. ,
DOI : 10.1145/331499.331504
Marine Ecology and Fisheries, 2001. ,
DOI : 10.1002/9781119968535.ch21
Cluster validity index for fuzzy clustering, Electronics Letters, vol.34, issue.22, pp.2176-2177, 1998. ,
DOI : 10.1049/el:19981523
Page x, Biological Oceanography : An Introduction, 1997. ,
Towards a robust fuzzy clustering. Fuzzy Sets and Systems, pp.215-233, 2003. ,
A fast algorithm for multilevel thresholding, Journal of Information Science and Engineering, vol.17, pp.713-727, 2001. ,
Improving cooccurrence matrix feature discrimination, Proc. of DICTA'95, 3rd International Conference on Digital Image Computing : Techniques and Applications, pp.643-648, 1995. ,
Some methods for classification and analysis of multivariate observations, Proceedings of the Fifth Berkeley Symposium on Mathematical Statistics and Probability, pp.281-297, 1967. ,
Edges, transitions and criticality, Pattern Recognition, vol.47, issue.6, pp.2104-2115, 2014. ,
DOI : 10.1016/j.patcog.2013.12.013
URL : https://hal.archives-ouvertes.fr/hal-00924137
Reconstructing an image from its edge representation, Digital Signal Processing, vol.23, issue.6, pp.1867-1876, 2013. ,
DOI : 10.1016/j.dsp.2013.06.013
URL : https://hal.archives-ouvertes.fr/hal-00850398
Dynamics of Marine Ecosystems : Biological- PhysicalInteractions in the Oceans Second Edition, 1996. ,
DOI : 10.1002/9781118687901
Automatic tool for the precise detection of upwelling and filaments in remote sensing imagery. Geoscience and Remote Sensing, IEEE Transactions on, issue.7, pp.431605-1616, 2005. ,
Random Sets and Integal Geometry, 1975. ,
Interpretation of dynamical processes in the upwelling area off northwest Africa using simulated and remotely sensed data, 1995 International Geoscience and Remote Sensing Symposium, IGARSS '95. Quantitative Remote Sensing for Science and Applications, pp.1101-1103, 1995. ,
DOI : 10.1109/IGARSS.1995.521150
Segmentation of Upwelling Regions in Sea Surface Temperature Images via Unsupervised Fuzzy Clustering, Intelligent Data Engineering and Automated Learning -IDEAL 2009, pp.543-553, 2009. ,
DOI : 10.1016/j.fss.2007.03.004
Automated computational delimitation of SST upwelling areas using fuzzy clustering, Computers & Geosciences, vol.43, pp.207-216, 2012. ,
DOI : 10.1016/j.cageo.2011.10.025
Mesoscale frontal structures in the Canary Upwelling System: New front and filament detection algorithms applied to spatial and temporal patterns, Remote Sensing of Environment, vol.123, issue.0, pp.123339-346, 2012. ,
DOI : 10.1016/j.rse.2012.03.028
Common turbulent signature in sea surface temperature and chlorophyll maps, Geophysical Research Letters, vol.36, issue.3, p.23602, 2007. ,
DOI : 10.1029/2007GL030823
Seasonal and interannual variability of coastal upwelling along northwest Africa and Portugal from 1981 to 1991, Journal of Geophysical Research, vol.34, issue.11, pp.9914197-14207, 1994. ,
DOI : 10.1029/94JC00814
Interannual variability of upwelling indices along the northwest african coast, pp.176-179, 1992. ,
Gradient-based edge detection and feature classification of sea-surface images of the Southern California Bight, Remote Sensing of Environment, vol.112, issue.5, pp.2397-2415, 2008. ,
DOI : 10.1016/j.rse.2007.11.010
A Threshold Selection Method from Gray-Level Histograms, IEEE Transactions on Systems, Man, and Cybernetics, vol.9, issue.1, pp.62-66, 1979. ,
DOI : 10.1109/TSMC.1979.4310076
Dictionnaire de télédétection aérospatiale, p.236, 1982. ,
Scale-space and edge detection using anisotropic diffusion. Pattern Analysis and Machine Intelligence, IEEE Transactions on, vol.12, issue.7, pp.629-639, 1990. ,
On optimal wavelet bases fro the realization of microcanonical cascade processes, International Journal of Wavelets, Multiresolution and Information Processing, issue.01, pp.935-61, 2011. ,
Singularity analysis of digital signals through the evaluation of their unpredictable point manifold, International Journal of Computer Mathematics, vol.1, issue.8, pp.901693-1707, 2013. ,
DOI : 10.5194/os-5-447-2009
URL : https://hal.archives-ouvertes.fr/hal-00688715
Image Analysis and Mathematical Morphology, 1982. ,
Waveletbased feature extraction from oceanographic images. Geoscience and Remote Sensing, IEEE Transactions on, vol.36, issue.3, pp.767-778, 1998. ,
Identification of upwelling areas on sea surface temperature images using fuzzy clustering, Remote Sensing of Environment, vol.112, issue.6, pp.2817-2823, 2008. ,
DOI : 10.1016/j.rse.2008.01.014
Scientific Basis and Initial Evaluation of the CLAVR-1 Global Clear/Cloud Classification Algorithm for the Advanced Very High Resolution Radiometer, Journal of Atmospheric and Oceanic Technology, vol.16, issue.6, p.16656, 1999. ,
DOI : 10.1175/1520-0426(1999)016<0656:SBAIEO>2.0.CO;2
On Detectability of Moroccan Coastal Upwelling in Sea Surface Temperature Satellite Images, Advances in Visual Computing, pp.386-395, 2014. ,
DOI : 10.1007/978-3-319-14364-4_37
URL : https://hal.archives-ouvertes.fr/hal-01078678
Detection of Moroccan coastal upwelling in SST images using the Expectation-Maximization, 2015 Intelligent Systems and Computer Vision (ISCV), 2015. ,
DOI : 10.1109/ISACV.2015.7106195
URL : https://hal.archives-ouvertes.fr/hal-01120901
Upwelling detection in sst images using fuzzy clustering with adaptive cluster merging, ISIVC 2014 International Symposium on signal, Image, Video and Communications (ISIVC), 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-01078670
A simple tool for automatic extraction of Moroccan coastal upwelling from Sea Surface Temperature images, 2014 9th International Conference on Intelligent Systems: Theories and Applications (SITA-14), pp.1-4, 2014. ,
DOI : 10.1109/SITA.2014.6847308
URL : https://hal.archives-ouvertes.fr/hal-00973756
An efficient tool for automatic delimitation of moroccan coastal upwelling using sst images. Geoscience and Remote Sensing Letters, pp.875-879, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01078655
A simple and efficient approach for coarse segmentation of Moroccan coastal upwelling, Signal Processing Conference (EUSIPCO), 2013 Proceedings of the 21st European, pp.1-5, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00850445
Detection of Moroccan coastal upwelling fronts in SST images using the microcanonical multiscale formalism, Pattern Recognition Letters, vol.55, issue.0, pp.5528-5561, 2015. ,
DOI : 10.1016/j.patrec.2014.12.006
URL : https://hal.archives-ouvertes.fr/hal-01120898
Method and system for the singularity analysis of digital signals. patent registered under number pct, p.70195, 2008. ,
Microcanonical multifractal formalism???a geometrical approach to multifractal systems: Part I. Singularity analysis, Journal of Physics A: Mathematical and Theoretical, vol.41, issue.1, pp.15501-015536, 2008. ,
DOI : 10.1088/1751-8113/41/1/015501
URL : https://hal.archives-ouvertes.fr/hal-00937370
A nonlinear laplace operator as edge detector in noisy images, Computer Vision, Graphics, and Image Processing, vol.45, issue.2, pp.45167-195, 1989. ,
DOI : 10.1016/0734-189X(89)90131-X
Utilisation du satellite NOAA-5 à la connaissance de la thermique océanique . Etude de ses variations saisonnières en Mer Ligure et de ses variations spatiales en Méditerranée, 1980. ,
On fuzzy cluster validity indices. Fuzzy Sets and Systems, Theme : Data Analysis, pp.2095-2117, 2007. ,
Upwelling-labels. https://commons.wikimedia.org/wiki/File: Upwelling-labels-en.svg. File : Upwelling-labels-en, 2011. ,
The seasonal upwelling cycle along the eastern boundary of the North Atlantic, Journal of Marine Research, vol.34, issue.2, pp.131-141, 1976. ,
A cluster validity index for fuzzy clustering, Pattern Recognition Letters, vol.26, issue.9, pp.1275-1291, 2005. ,
DOI : 10.1016/j.patrec.2004.11.022
A validity measure for fuzzy clustering. Pattern Analysis and Machine Intelligence, IEEE Transactions on, vol.13, issue.8, pp.841-847, 1991. ,
A comparative study of cluster validation indices applied to genotyping data, Chemometrics and Intelligent Laboratory Systems, vol.78, issue.1-2, pp.30-40, 2005. ,
DOI : 10.1016/j.chemolab.2004.12.003
Motion analysis in oceanographic satellite images using multiscale methods and the energy cascade, Pattern Recognition, vol.43, issue.10, pp.433591-3604, 2010. ,
DOI : 10.1016/j.patcog.2010.04.011
URL : https://hal.archives-ouvertes.fr/inria-00423748
Observing submesoscale activity in the bay of biscay with satellite-derived sst and chlorophyll concentration, EGU General Assembly Conference Abstracts, p.6952, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-00942221
A new cluster-validity for fuzzy clustering, Pattern Recognition, vol.32, issue.7, pp.1089-1097, 1999. ,
DOI : 10.1016/S0031-3203(98)00157-5
Using an Autonomous Underwater Vehicle to Track a Coastal Upwelling Front, IEEE Journal of Oceanic Engineering, vol.37, issue.3, pp.338-347, 2012. ,
DOI : 10.1109/JOE.2012.2197272
