An adaptive covariance inflation error correction algorithm for ensemble filters, Tellus A, vol.56, issue.2, pp.210-224, 2007. ,
DOI : 10.1175/1520-0493(2002)130<1913:EDAWPO>2.0.CO;2
A Monte Carlo Implementation of the Nonlinear Filtering Problem to Produce Ensemble Assimilations and Forecasts, Monthly Weather Review, vol.127, issue.12, pp.2741-2758, 1999. ,
DOI : 10.1175/1520-0493(1999)127<2741:AMCIOT>2.0.CO;2
Optic Acceleration, [1988 Proceedings] Second International Conference on Computer Vision, pp.364-373, 1988. ,
DOI : 10.1109/CCV.1988.590013
Tracking Closed Curves with Non-linear Stochastic Filters, Conference on Space-Scale and Variational Methods, 2009. ,
DOI : 10.1007/3-540-48236-9_13
URL : https://hal.archives-ouvertes.fr/tel-00763157
A Database and Evaluation Methodology for Optical Flow, International Journal of Computer Vision, vol.27, issue.3, pp.1-31, 2011. ,
DOI : 10.1007/s11263-010-0390-2
Contributions aux méthodes variationnelles pour le calcul du flot optique : prise en compte des informations spatiales et temporelles. Habilitation à diriger des recherches, 2010. ,
Solving ill-posed Image Processing problems using Data Assimilation, Numerical Algorithms, vol.14, issue.7, pp.219-252, 2011. ,
DOI : 10.1007/s11075-010-9383-z
Non-linear observation equation for motion estimation, 2012 19th IEEE International Conference on Image Processing, pp.1521-1524, 2012. ,
DOI : 10.1109/ICIP.2012.6467161
Image-based modelling of ocean surface circulation from satellite acquisitions, International Conference on Computer Vision Theory and Applications (VISAPP), 2014. ,
A generalized optical flow constraint and its physical interpretation, Proceedings IEEE Conference on Computer Vision and Pattern Recognition. CVPR 2000 (Cat. No.PR00662), pp.2487-2492, 2000. ,
DOI : 10.1109/CVPR.2000.854890
Morphing active contours, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.22, issue.7, pp.733-737, 2000. ,
DOI : 10.1109/34.865191
Weighted ensemble transform Kalman filter for image assimilation, Tellus A, vol.140, issue.0, 2012. ,
DOI : 10.1175/2009MWR2835.1
URL : https://hal.archives-ouvertes.fr/hal-00793804
The Robust Estimation of Multiple Motions: Parametric and Piecewise-Smooth Flow Fields, Computer Vision and Image Understanding, vol.63, issue.1, pp.75-104, 1996. ,
DOI : 10.1006/cviu.1996.0006
High Accuracy Optical Flow Estimation Based on a Theory for Warping, European Conference on Computer Vision (ECCV), pp.25-36, 2004. ,
DOI : 10.1007/978-3-540-24673-2_3
A Naturalistic Open Source Movie for Optical Flow Evaluation, European Conference on Computer Vision (ECCV), Part IV, pp.611-625, 2012. ,
DOI : 10.1007/978-3-642-33783-3_44
A Limited Memory Algorithm for Bound Constrained Optimization, SIAM Journal on Scientific Computing, vol.16, issue.5, pp.1190-1208, 1995. ,
DOI : 10.1137/0916069
A computational approach to edge detection, IEEE Trans. Pattern Anal. Mach. Intell, vol.8, issue.6, pp.679-698, 1986. ,
Numerical study of slightly viscous flow, Journal of Fluid Mechanics, vol.23, issue.04, pp.785-796, 1973. ,
DOI : 10.1017/S0022112073002016
Dense estimation of fluid flows, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.24, issue.3, pp.365-380, 2002. ,
DOI : 10.1109/34.990137
URL : https://hal.archives-ouvertes.fr/hal-00329724
Vortex methods : Theory and practice, 2000. ,
DOI : 10.1017/CBO9780511526442
A Low Dimensional Fluid Motion Estimator, International Journal of Computer Vision, vol.21, issue.3, pp.329-349, 2007. ,
DOI : 10.1007/s11263-007-0037-0
URL : https://hal.archives-ouvertes.fr/inserm-00140892
Variational assimilation of POD loworder dynamical systems, Journal of Turbulence, vol.8, issue.9, pp.1-22, 2007. ,
URL : https://hal.archives-ouvertes.fr/hal-00596160
Low???dimensional models for complex geometry flows: Application to grooved channels and circular cylinders, Physics of Fluids A: Fluid Dynamics, vol.3, issue.10, pp.2337-2354, 1991. ,
DOI : 10.1063/1.857881
Wavelets to reconstruct turbulence multifractals from experimental image sequences, 7th Int. Symp. on Turbulence and Shear Flow Phenomena, 2011. ,
Wavelets and optical flow motion estimation, Numerical Mathematics : Theory, Methods and Applications, 2012. ,
Using Canny's criteria to derive a recursively implemented optimal edge detector, International Journal of Computer Vision, vol.1, issue.2, pp.167-187, 1987. ,
DOI : 10.1007/BF00123164
Motion estimation by data assimilation in dynamic reduced order models, 2013. ,
Assimilation d'images dans un modèle réduit pour l'estimation du mouvement, Groupe d'Etudes du Traitement du Signal et des Images (GRETSI), 2011. ,
Coupling reduced models for optimal motion estimation, International Conference on Pattern Recognition (ICPR), pp.2651-2654, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00803622
The Ensemble Kalman Filter: theoretical formulation and practical implementation, Ocean Dynamics, vol.53, issue.4, pp.343-367, 2003. ,
DOI : 10.1007/s10236-003-0036-9
Distance-Dependent Filtering of Background Error Covariance Estimates in an Ensemble Kalman Filter, Monthly Weather Review, vol.129, issue.11, pp.2776-2790, 2001. ,
DOI : 10.1175/1520-0493(2001)129<2776:DDFOBE>2.0.CO;2
Tapenade 2.1 user's guide, 2004. ,
The Tapenade automatic differentiation tool, ACM Transactions on Mathematical Software, vol.39, issue.3, p.2013 ,
DOI : 10.1145/2450153.2450158
Learning reduced models for motion estimation on ocean satellite images, Hydrodynamic modeling of the Black Sea Dynamics, 2011. ,
URL : https://hal.archives-ouvertes.fr/hal-00646272
Recovering Missing Data on Satellite Images, Scandinavian Conference on Image Analysis (SCIA), pp.697-707, 2011. ,
DOI : 10.1137/1.9780898717921
URL : https://hal.archives-ouvertes.fr/inria-00612328
Divergence-Free Motion Estimation, European Conference on Computer Vision (ECCV), pp.15-27, 2012. ,
DOI : 10.1007/978-3-642-33765-9_2
URL : https://hal.archives-ouvertes.fr/hal-00742021
Learning reduced models for motion estimation on long temporal image sequences, 2012 IEEE International Geoscience and Remote Sensing Symposium, 2012. ,
DOI : 10.1109/IGARSS.2012.6351591
URL : https://hal.archives-ouvertes.fr/hal-00730515
Monitoring surface currents from uncertain image observations, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00739091
Error estimation for reduced-order models of dynamical systems, SIAM Journal on Numerical Analysis, vol.43, issue.41, pp.693-1714, 2005. ,
Determining optical flow, Artificial Intelligence, vol.17, issue.1-3, pp.185-203, 1981. ,
DOI : 10.1016/0004-3702(81)90024-2
Data Assimilation Using an Ensemble Kalman Filter Technique, Monthly Weather Review, vol.126, issue.3, pp.796-811, 1998. ,
DOI : 10.1175/1520-0493(1998)126<0796:DAUAEK>2.0.CO;2
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.3.1706
Estimating motion of constant acceleration from image sequences, [1992] Proceedings. 11th IAPR International Conference on Pattern Recognition, pp.655-659, 1993. ,
DOI : 10.1109/ICPR.1992.201646
An Efficient Horizontal Advection Scheme for the Modeling of Global Transport of Constituents, Monthly Weather Review, vol.123, issue.12, pp.554-557, 1995. ,
DOI : 10.1175/1520-0493(1995)123<3554:AEHASF>2.0.CO;2
Estimating Apparent Motion on Satellite Acquisitions with a Physical Dynamic Model, 2010 20th International Conference on Pattern Recognition, pp.41-44, 2010. ,
DOI : 10.1109/ICPR.2010.19
URL : https://hal.archives-ouvertes.fr/inria-00538317
Optimal Orthogonal Basis and Image Assimilation: Motion Modeling, 2013 IEEE International Conference on Computer Vision, 2013. ,
DOI : 10.1109/ICCV.2013.416
URL : https://hal.archives-ouvertes.fr/hal-00871330
Surface circulation from satellite images : Reduced model of the black sea, Proceedings of Integrated system of the Black and Azov seas' monitoring international conference, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00878071
Motion estimation on ocean satellite images by data assimilation in a wavelets reduced model, General Assembly of the European Geophysical Society (EGS), 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00828048
A multiscale vector spline method for estimating the fluids motion on satellite images, European Conference on Computer Vision (ECCV), number Part IV, pp.665-676, 2008. ,
URL : https://hal.archives-ouvertes.fr/inria-00264727
Fast and stable vector spline method for fluid flow estimation, International Conference on Image Processing (ICIP), pp.505-508, 2007. ,
Divergence-free wavelets and high order regularization, International Journal of Computer Vision, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00646104
Effective construction of divergence-free wavelets on the square, Journal of Computational and Applied Mathematics, vol.240, pp.74-86, 2012. ,
DOI : 10.1016/j.cam.2012.07.029
URL : https://hal.archives-ouvertes.fr/hal-00727038
A New Approach to Linear Filtering and Prediction Problems, Journal of Basic Engineering, vol.82, issue.1, pp.35-45, 1960. ,
DOI : 10.1115/1.3662552
Variational algorithms for analysis and assimilation of meteorological observations : theoretical aspects, Tellus, pp.97-110, 1986. ,
Continuous tracking of structures from an image sequence, International Conference on Computer Vision Theory and Applications (VISAPP), pp.386-389, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00798176
Assimilation de données pour estimer le mouvement et suivre un objet, Journées francophones des jeunes chercheurs en vision par ordinateur (ORASIS), 2013. ,
Object's tracking by advection of a distance map, 2013 IEEE International Conference on Image Processing, pp.3612-3616, 2013. ,
DOI : 10.1109/ICIP.2013.6738745
Continuous tracking of structures from an image sequence, 2013. ,
Numerical Methods for Conservative Laws, Lectures in Mathematics. ETH Zürich, 1992. ,
Optimal Control of Systems Governed by Partial Differential Equations, 1971. ,
DOI : 10.1007/978-3-642-65024-6
Probability Theory, 1978. ,
The structure of inhomogeneous turbulence Atmospheric Turbulence and Radio Wave Propagation, pp.166-178, 1967. ,
Segmenting video into classes of algorithmsuitability, Conference on Computer Vision and Pattern Recognition (CVPR), pp.1054-1061, 2010. ,
Ensemble forecast of analyses: Coupling data assimilation and sequential aggregation, Journal of Geophysical Research: Atmospheres, vol.113, issue.D22, 2010. ,
DOI : 10.1029/2008JD009991
URL : https://hal.archives-ouvertes.fr/inria-00547903
An Investigation of Smoothness Constraints for the Estimation of Displacement Vector Fields from Image Sequences, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.8, issue.5, pp.8565-593, 1986. ,
DOI : 10.1109/TPAMI.1986.4767833
Regularisation and scale space, 1994. ,
The upper layer circulation of the Black Sea: Its variability as inferred from hydrographic and satellite observations, Journal of Geophysical Research, vol.13, issue.2, pp.569-581, 1992. ,
DOI : 10.1029/92JC00812
Impacts of localisation in the EnKF and EnOI: experiments with a small model, Ocean Dynamics, vol.130, issue.1, pp.32-45, 2007. ,
DOI : 10.1007/s10236-006-0088-8
Image Assimilation for Motion Estimation of Atmospheric Layers with Shallow-Water Model, Asian Conference on Computer Vision, pp.864-874, 2007. ,
DOI : 10.1007/978-3-540-76386-4_82
URL : https://hal.archives-ouvertes.fr/hal-00596194
Variational optimal control technique for the tracking of deformable objects, 2007 IEEE 11th International Conference on Computer Vision, 2007. ,
DOI : 10.1109/ICCV.2007.4408944
URL : https://hal.archives-ouvertes.fr/hal-00596203
A Variational Technique for Time Consistent Tracking of Curves and Motion, Journal of Mathematical Imaging and Vision, vol.28, issue.1, 2008. ,
DOI : 10.1007/s10851-008-0069-2
URL : https://hal.archives-ouvertes.fr/hal-00596154
Assimilation de données images : application au suivi de courbes et de champs de vecteurs, Thèse, Université Rennes 1, 2007. ,
New Families of Fourier Eigenfunctions for Steerable Filtering, IEEE Transactions on Image Processing, vol.21, issue.6, 2012. ,
DOI : 10.1109/TIP.2011.2179060
Robust tracking of position and velocity with Kalman snakes, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.21, issue.6, pp.564-569, 1999. ,
DOI : 10.1109/34.771328
Particle Image Velocimetry : A Practical Guide. Experimental Fluid Mechanics, 2007. ,
DOI : 10.1007/978-3-662-03637-2
Low-dimensional description of free-shear-flow coherent structures and their dynamical behaviour, Journal of Fluid Mechanics, vol.37, issue.-1, pp.1-29, 1994. ,
DOI : 10.1017/S0022112088001818
Tracking Deforming Objects Using Particle Filtering for Geometric Active Contours, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.29, issue.8, pp.291470-1475, 2007. ,
DOI : 10.1109/TPAMI.2007.1081
Investigations of boundary layer transition via Galerkin projections on empirical eigenfunctions, Physics of Fluids, vol.8, issue.1, pp.175-188, 1996. ,
DOI : 10.1063/1.868825
A semi-Lagrangian discontinuous Galerkin method for scalar advection by incompressible flows, Journal of Computational Physics, vol.216, issue.1, pp.195-215, 2006. ,
DOI : 10.1016/j.jcp.2005.11.030
A deterministic formulation of the ensemble Kalman filter : An alternative to ensemble square root filters. Tellus, 2008. ,
Level Set Methods and Fast Marching Methods : Evolving Interfaces in Computational Geometry, Fluid Mechanics, Computer Vision, and Materials Science, 1999. ,
Regularization of discontinuous flow fields, [1989] Proceedings. Workshop on Visual Motion, pp.81-86, 1989. ,
DOI : 10.1109/WVM.1989.47097
Velocity and acceleration estimation in video sequences by the local polynomial periodogram, International Symposium on Signal Processing and Its Applications, 2003. ,
Secrets of optical flow estimation and their principles, 2010 IEEE Computer Society Conference on Computer Vision and Pattern Recognition, pp.2432-2439, 2010. ,
DOI : 10.1109/CVPR.2010.5539939
An Efficient, Interface-Preserving Level Set Redistancing Algorithm and Its Application to Interfacial Incompressible Fluid Flow, SIAM Journal on Scientific Computing, vol.20, issue.4, 1999. ,
DOI : 10.1137/S1064827596298245
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.35.5063
Motion estimation and vector splines, Proceedings of IEEE Conference on Computer Vision and Pattern Recognition CVPR-94, pp.939-942, 1994. ,
DOI : 10.1109/CVPR.1994.323929
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.57.4768
Motion estimation with quadtree splines, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.18, issue.12, pp.1199-1210, 1996. ,
DOI : 10.1109/34.546257
Regularization of incorrectly posed problems, Sov. Math. Dokl, vol.4, pp.1624-1627, 1963. ,
Assimilation of image sequences in numerical models, Tellus A, vol.105, issue.C8, pp.30-47, 2010. ,
DOI : 10.1111/j.1600-0870.2009.00416.x
URL : https://hal.archives-ouvertes.fr/inria-00332815
Atmospheric and oceanic fluid dynamics, p.745, 2006. ,
DOI : 10.1017/CBO9780511790447
View-Consistent 3D Scene Flow Estimation over Multiple Frames, European Conference on Computer Vision (ECCV), Lecture Notes on Computer Sciences, 2014. ,
DOI : 10.1007/978-3-319-10593-2_18
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.673.1987
Modeling temporal coherence for optical flow, 2011 International Conference on Computer Vision, 2011. ,
DOI : 10.1109/ICCV.2011.6126359
Structure- and motion-adaptive regularization for high accuracy optic flow, 2009 IEEE 12th International Conference on Computer Vision, pp.1663-1668, 2009. ,
DOI : 10.1109/ICCV.2009.5459375
Motion estimation with non-local total variation regularization, 2010 IEEE Computer Society Conference on Computer Vision and Pattern Recognition, 2010. ,
DOI : 10.1109/CVPR.2010.5539945
Physically based fluid flow recovery from image sequences, Proceedings of IEEE Computer Society Conference on Computer Vision and Pattern Recognition, pp.969-975, 1997. ,
DOI : 10.1109/CVPR.1997.609445
Image registration using wavelet-based motion model, International Journal of Computer Vision, vol.38, issue.2, pp.129-152, 1023. ,
DOI : 10.1023/A:1008101718719
Object tracking, ACM Computing Surveys, vol.38, issue.4, p.13, 2006. ,
DOI : 10.1145/1177352.1177355
Algorithm 778: L-BFGS-B: Fortran subroutines for large-scale bound-constrained optimization, ACM Transactions on Mathematical Software, vol.23, issue.4, pp.550-560, 1997. ,
DOI : 10.1145/279232.279236
