Conception et implémentation d'un langage de programmation concurrente modulaire - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2015
Design and implementation of a modular concurrent programming language
Johan Grande
  • Fonction : Auteur
  • PersonId : 776215
  • IdRef : 188938567
Shared-memory concurrency is a classic concurrency model which, among other things, makes it possible to take advantage of multicore processors that are now widespread in personal computers. Concurrent programs are prone to deadlocks which are notoriously hard to predict and debug. Programs using mutexes, a very popular synchronization mechanism, are no exception. In this thesis we studied deadlock avoidance methods with the aim of making programming with mutexes easier. We first studied a method that uses a static analysis by means of a type and effect system, then a variation on this method in a dynamically typed language. We developed more the second method. It mixes deadlock prevention and avoidance to provide an easy-to-use and expressive deadlock-free locking function. We implemented it as a Hop (dialect of Scheme) library. This lead us to develop a starvation-free algorithm to simultaneously acquire an arbitrary number of mutexes, and to identify the concept of asymptotic deadlock. While doing so, we also developped an optimization of exceptions(finally blocks). Our performance tests seem to show that using our library has negligible impact on theperformance of real-life applications. Most of our work could be applied to other structured programming languages such as Java.
La programmation concurrente à mémoire partagée est un modèle classique de concurrence qui permet notamment de tirer parti des processeurs multicoeurs aujourd'hui très répandus dans les ordinateurs personnels. Les programmes concurrents sont sujets au problème des interblocages, notoirement difficiles à prévoir et à éliminer, en particulier dans le cas de l'utilisation du mécanisme de synchronisation très populaire que sont les mutex. Dans cette thèse nous avons travaillé à rendre plus aisée la programmation avec des mutex en étudiant des méthodes d'évitement des interblocages. Nous avons d'abord étudié une méthode utilisant une analyse statique par un système de types et d'effets, puis une variante de cette méthode dans un langage à typage dynamique. La seconde méthode est celle que nous avons le plus développée. Elle combine prévention et évitement des interblocages pour fournir une fonction de verrouillage sans interblocages expressive et utilisable. Nous l'avons implémentée sous forme d'une bibliothèque Hop (dialecte de Scheme). Ce faisant, nous avons développé un algorithme sans famine pour l'acquisition simultanée d'un nombre arbitraire de mutex, et identifié le concept d'interblocage asymptotique. Nous avons également été amenés à proposer une optimisation des exceptions (blocs finally). Nos tests de performances semblent indiquer un impact négligeable de l'utilisation de notre bibliothèque sur des applications concurrentes réelles. La majeure partie de notre recherche pourrait être appliquée à d'autres langages de programmation structurée tels que Java.
2015NICE4067.pdf (1.2 Mo) Télécharger le fichier
tel-01246636 , version 1 (18-12-2015)
tel-01246636 , version 2 (07-01-2016)
  • HAL Id : tel-01246636 , version 2
Johan Grande. Conception et implémentation d'un langage de programmation concurrente modulaire. Autre [cs.OH]. Université Nice Sophia Antipolis, 2015. Français. ⟨NNT : 2015NICE4067⟩. ⟨tel-01246636v2⟩
531 Consultations
1034 Téléchargements
