Magnetic and structural properties of size-selected FeCo nanoparticle assemblies - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2015
Propriétés magnétiques et structurales d’assemblées de nanoparticules de FeCo triées en taille
Over the past few decades, use of nanostructures has become widely popular in the different field of science. Nanoparticles, in particular, are situated between the molecular level and bulk matter size. This size range gave rise to a wide variety physical phenomena that are still not quite understood. Magnetic nanoparticles are at their hype due to their applications in medical field, as a catalyst in a wide number of chemical reactions, in addition to their use for information storage devices and spintronics. In this work, we are interested in studying the intrinsic magnetic properties (magnetic moments and anisotropy) of FeCo nanoparticles. Thus, in order to completely understand their properties, mass-selected FeCo nanoparticles were prepared using the MS-LECBD (Mass Selected Low Energy Cluster Beam Deposition) technique in the sizes range of 2-6 nm and in − situ embedded in a matrix in order to separate them, to avoid coalescence during the annealing and to protect during transfer in air. From a first time, the structural properties (size, morphology, composition, crystallographic structure) of these nanopar- ticles were investigated in order to directly correlate the modification of the magnetic properties to the structure and chemical ordering of the nanoparticles after high temperature treatment. In addition to the bimetallic FeCo nanoparticles, reference Fe and Co systems were also fabricated and studied using the same techniques. The structural properties were investigated using high resolution transmission electron microscopy (HRTEM), anomalous x-ray diffraction (AXD) and extended x-ray absorption fine structure (EXAFS) where a phase transition from a disordered A2 phase to a chemically ordered CsCl B2 phase was observed and further validated from the magnetic findings using SQUID magnetometry and x-ray magnetic circular dichroism (XMCD)
Dans ce travail, nous nous sommes intéressés aux propriétés magnétiques intrinsèques (moments et anisotropie magnétiques) de nanoparticules bimétalliques fer-cobalt. Pour cela, des agrégats FeCo dans la gamme de taille 2-6 nm ont été préparés en utilisant la technique MS-LECBD (Mass Selected Low Energy Cluster Beam Deposition) et enrobés en matrice in − situ afin de les séparer, d'éviter leur coalescence pendant les recuits et de les protéger à leur sortie à l'air. Dans un premier temps, les propriétés structurales (dispersion de taille, morphologie, composition, structure cristallographique) ont été étudiées en vue de corréler directement les modifications des caractéristiques magnétiques des nanoparticules, à leur structure et à l'ordre chimique obtenu après traitement thermique haute température. D'autre part, pour mettre en évidence les effets d'alliages à cette échelle, des références d'agrégats purs de fer et de cobalt ont été fabriquées et étudiées en utilisant les mêmes techniques. Par microscopie électronique en transmission à haute résolution, diffraction anomale et absorption de rayons X (high resolution transmission electron microscopy (HRTEM), anomalous x-ray diffraction (AXD) and extended x-ray absorption fine structure (EXAFS), nous avons mis en évidence un changement structural depuis une phase A2 chimiquement désordonnée vers une phase B2 type CsCl chimiquement ordonnée. Cette transition a été validée par nos résultats obtenus par magnétomètrie SQUID et dichroïsme magnétique circulaire (x-ray magnetic circular dichroism (XMCD))
TH2015KhadraGhassan.pdf (41.51 Mo) Télécharger le fichier
tel-01262653 , version 1 (27-01-2016)
tel-01262653 , version 2 (26-05-2016)
  • HAL Id : tel-01262653 , version 2
Ghassan Khadra. Magnetic and structural properties of size-selected FeCo nanoparticle assemblies. Physics [physics]. Université Claude Bernard - Lyon I, 2015. English. ⟨NNT : 2015LYO10145⟩. ⟨tel-01262653v2⟩
418 Consultations
421 Téléchargements
