Abstract : This thesis focuses on machine learning for data classification. To reduce the labelling cost, active learning allows to query the class label of only some important instances from a human labeller. We propose a new uncertainty measure that characterizes the importance of data and improves the performance of active learning compared to the existing uncertainty measures. This measure determines the smallest instance weight to associate with new data, so that the classifier changes its prediction concerning this data. We then consider a setting where the data arrives continuously from an infinite length stream. We propose an adaptive uncertainty threshold that is suitable for active learning in the streaming setting and achieves a compromise between the number of classification errors and the number of required labels. The existing stream-based active learning methods are initialized with some labelled instances that cover all possible classes. However, in many applications, the evolving nature of the stream implies that new classes can appear at any time. We propose an effective method of active detection of novel classes in a multi-class data stream. This method incrementally maintains a feature space area which is covered by the known classes, and detects those instances that are self-similar and external to that area as novel classes. Finally, it is often difficult to get a completely reliable labelling because the human labeller is subject to labelling errors that reduce the performance of the learned classifier. This problem was solved by introducing a measure that reflects the degree of disagreement between the manually given class and the predicted class, and a new informativeness measure that expresses the necessity for a mislabelled instance to be re-labeled by an alternative labeller.
Résumé : Cette thèse traite de l'apprentissage automatique pour la classification de données. Afin de réduire le coût de l'étiquetage, l'apprentissage actif permet de formuler des requêtes pour demander à un opérateur d'étiqueter seulement quelques données choisies selon un critère d'importance. Nous proposons une nouvelle mesure d'incertitude qui permet de caractériser l'importance des données et qui améliore les performances de l'apprentissage actif par rapport aux mesures existantes. Cette mesure détermine le plus petit poids nécessaire à associer à une nouvelle donnée pour que le classifieur change sa prédiction concernant cette donnée. Nous intégrons ensuite le fait que les données à traiter arrivent en continu dans un flux de longueur infinie. Nous proposons alors un seuil d'incertitude adaptatif qui convient pour un apprentissage actif à partir d'un flux de données et qui réalise un compromis entre le nombre d'erreurs de classification et le nombre d'étiquettes de classes demandées. Les méthodes existantes d'apprentissage actif à partir de flux de données, sont initialisées avec quelques données étiquetées qui couvrent toutes les classes possibles. Cependant, dans de nombreuses applications, la nature évolutive du flux fait que de nouvelles classes peuvent apparaître à tout moment. Nous proposons une méthode efficace de détection active de nouvelles classes dans un flux de données multi-classes. Cette méthode détermine de façon incrémentale une zone couverte par les classes connues, et détecte les données qui sont extérieures à cette zone et proches entre elles, comme étant de nouvelles classes. Enfin, il est souvent difficile d'obtenir un étiquetage totalement fiable car l'opérateur humain est sujet à des erreurs d'étiquetage qui réduisent les performances du classifieur appris. Cette problématique a été résolue par l'introduction d'une mesure qui reflète le degré de désaccord entre la classe donnée manuellement et la classe prédite et une nouvelle mesure d'"informativité" permettant d'exprimer la nécessité pour une donnée mal étiquetée d'être ré-étiquetée par un opérateur alternatif.
