Hickey 96], l'information qui est fournie à l'opérateur peut être de mauvaise qualité ou insuffisante pour déterminer la véritable étiquette d'une instance donnée ,
An adaptive streaming active learning strategy based on instance weighting, 2015. ,
Online unsupervised neural-gas learning method for infnite data streams Advances in Intelligent and Soft Computing, Pattern Recognition Applications and Methods, pp.57-70, 2015. ,
Stream-based active learning in the presence of label noise, International Conference on Pattern Recognition Applications and Methods -ICPRAM, Lisbon (Portugal), pp.1-10 ,
Classification de flux de documents évolutifs avec apprentissage de classes inconnues, pp.25-46, 2014. ,
Efficient active novel class detection for data stream classification, IEEE International Conference on Pattern Recognition -ICPR, Stockholm (Sweden), pp.2826-2831, 2014. ,
Abdel Belaïd and Vincent Poulain d'Andecy. Multipage administrative document stream segmentation, IEEE International Conference on Pattern Recognition -ICPR, Stockholm (Sweden), pp.966-971, 2014. ,
Classification active de flux de documents avec identification des nouvelles classes, Colloque International Francophone sur l'Ecrit et le Document -CIFED, pp.75-89 ,
A stream-based semi-supervised active learning approach for document classification, IEEE International Conference on Document Analysis and Recognition -ICDAR, pp.611-615, 2013. ,
Document image and zone classification through incremental learning An adaptive streaming active learning strategy based on instance weighting, IEEE International Conference on Image Processing -ICIP, 2015. ,
Classi???cation de ???ux de documents ??volutifs avec apprentissage de classes inconnues, Document num??rique, vol.17, issue.3, pp.25-46, 2014. ,
DOI : 10.3166/dn.17.3.31-51
Online unsupervised neural-gas learning method for infnite data streams Advances in Intelligent and Soft Computing, Pattern Recognition Applications and Methods, Bouguelia, vol.15, issue.318, pp.57-70, 2015. ,
Stream-based Active Learning in the Presence of Label Noise, Proceedings of the International Conference on Pattern Recognition Applications and Methods, pp.1-10, 2015. ,
DOI : 10.5220/0005178900250034
URL : https://hal.archives-ouvertes.fr/hal-01116114
Efficient Active Novel Class Detection for Data Stream Classification, 2014 22nd International Conference on Pattern Recognition, pp.2826-2831, 2014. ,
DOI : 10.1109/ICPR.2014.487
URL : https://hal.archives-ouvertes.fr/hal-01065043
Andecy Multipage administrative document stream segmentation, IEEE International Conference on Pattern Recognition -ICPR, pp.966-971, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-00980698
A Stream-Based Semi-supervised Active Learning Approach for Document Classification, 2013 12th International Conference on Document Analysis and Recognition, pp.611-615, 2013. ,
DOI : 10.1109/ICDAR.2013.126
URL : https://hal.archives-ouvertes.fr/hal-00855184
Document image and zone classification through incremental learning, 2013 IEEE International Conference on Image Processing, pp.4230-4234, 2013. ,
DOI : 10.1109/ICIP.2013.6738871
URL : https://hal.archives-ouvertes.fr/hal-00865765
An adaptive incremental clustering method based on the growing neural gas algorithm, International Conference on Pattern Recognition Applications and Methods -ICPRAM, pp.42-49, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00794354
Machine learning in automated text categorization, ACM Computing Surveys, vol.34, issue.1, pp.1-47, 2002. ,
DOI : 10.1145/505282.505283
Machine learning: a review of classification and combining techniques, Artificial Intelligence Review, vol.19, issue.2, pp.159-190, 2006. ,
DOI : 10.1007/978-3-540-24581-0_37
Semi-supervised text classification using EM, Semi- Supervised Learning, pp.33-56, 2006. ,
Multi-view HAC for semi-supervised document image classification. Document Analysis Systems VI, pp.191-200, 2004. ,
URL : https://hal.archives-ouvertes.fr/hal-00637062
Semi-supervised Document Classification with a Mislabeling Error Model, European Conference on Information Retrieval, pp.191-200, 2008. ,
DOI : 10.1007/978-3-540-78646-7_34
URL : https://hal.archives-ouvertes.fr/hal-01301551
Scikit-learn : Machine Learning in Python, Journal of Machine Learning Research, pp.2825-2830, 2011. ,
URL : https://hal.archives-ouvertes.fr/hal-00650905
Query learning can work poorly when a human oracle is used, IEEE International Joint Conference on Neural Networks, pp.335-340, 1992. ,
Improving generalization with active learning, Machine Learning, pp.201-221, 1994. ,
DOI : 10.1007/BF00993277
URL : https://link.springer.com/content/pdf/10.1007%2FBF00993277.pdf
A sequential algorithm for training text classifiers, SIGIR Conference on Research and Development in Information Retrieval, pp.3-12, 1994. ,
Active hidden Markov models for information extraction, International Conference on Advances in Intelligent Data Analysis, pp.309-318, 2001. ,
A mathematical theory of communication, Bell System Technical Journal, pp.623-656, 1948. ,
Heterogeneous Uncertainty Sampling for Supervised Learning, International Conference on Machine Learning, pp.148-156, 1994. ,
DOI : 10.1016/B978-1-55860-335-6.50026-X
Selective Sampling for Nearest Neighbor Classifiers, Machine Learning, pp.125-152, 2004. ,
DOI : 10.1023/B:MACH.0000011805.60520.fe
Support vector machine active learning with applications to text classification, International Conference on Machine Learning, pp.999-1006, 2000. ,
Multi-class Ensemble-Based Active Learning, European Conference on Machine Learning, pp.687-694, 2006. ,
DOI : 10.1007/11871842_68
Active learning for logistic regression: an evaluation, Machine Learning, pp.235-265, 2007. ,
DOI : 10.1007/b98874
An analysis of active learning strategies for sequence labeling tasks, Conference on Empirical Methods in Natural Language Processing, pp.1069-1078, 2008. ,
Employing EM in pool-based active learning for text classification, International Conference on Machine Learning, pp.287-294, 1998. ,
Query learning strategies using boosting and bagging, International Conference on Machine Learning, pp.1-9, 1998. ,
Active Learning for Probability Estimation Using Jensen-Shannon Divergence, European Conference on Machine Learning, pp.268-279, 2005. ,
DOI : 10.1007/11564096_28
Toward optimal active learning through sampling estimation of error reduction, International Conference on Machine Learning, pp.441-448, 2001. ,
Optimistic active learning using mutual information, International Joint Conference on Artificial Intelligence, pp.823-829, 2007. ,
Combining active learning and semisupervised learning using Gaussian fields and harmonic functions, ICML Workshop on the Continuum from Labeled to Unlabeled Data, pp.58-65, 2003. ,
Hierarchical sampling for active learning, Proceedings of the 25th international conference on Machine learning, ICML '08, pp.208-215, 2008. ,
DOI : 10.1145/1390156.1390183
Two faces of active learning. Theoretical computer science, pp.1767-1781, 2011. ,
Multiple-instance active learning, Advances in Neural Information Processing Systems, pp.1289-1296, 2008. ,
A weighted support vector machine for data classification, International Journal of Pattern Recognition and Artificial Intelligence, pp.961-976, 2007. ,
Instance weighting for domain adaptation in NLP, Annual Meeting of the Association for Computational Linguistics, pp.254-271, 2007. ,
The Distance-Weighted k-Nearest-Neighbor Rule, IEEE Transactions on Systems, Man, and Cybernetics, vol.6, issue.4, pp.325-327, 1976. ,
DOI : 10.1109/TSMC.1976.5408784
Instance selection and instance weighting for crossdomain sentiment classification via PU learning, International joint conference on Artificial Intelligence, pp.2176-2182, 2013. ,
Selective sampling with redundant views, Proceedings of the National Conference on Artificial Intelligence, pp.621-626, 2000. ,
neural-gas" network learns topologies, pp.397-402, 1991. ,
Hasegawa An enhanced self-organizing incremental neural network for online unsupervised learning, IEEE International Joint Conference Neural Networks, pp.893-903, 2007. ,
Chaudhuri Incremental classification of invoice documents, IEEE International Conference on Pattern Recognition, pp.1-4, 2008. ,
Fast Kernel Classifiers with Online and Active Learning, Journal of Machine Learning Research, pp.1579-1619, 2005. ,
URL : https://hal.archives-ouvertes.fr/hal-00752361
Jiang Survey of improving k-nearest-neighbor for classification . Fuzzy Systems and Knowledge Discovery, pp.679-683, 2007. ,
Tibshirani Additive Logistic Regression : a Statistical View of Boosting, Annals of Statistics, pp.337-407, 1998. ,
Domingos Naive Bayes models for probability estimation, International Conference on Machine Learning, pp.529-536, 2005. ,
Survey of classification methods in data streams. Data Streams, pp.39-59, 2007. ,
Data streams : models and algorithms, 2007. ,
Active learning with evolving streaming data, European Conference on Machine Learning and Principles and Practice of Knowledge Discovery in Databases, pp.597-612, 2011. ,
Estimating the Support of a High-Dimensional Distribution, Neural Computation, vol.6, issue.1, pp.1443-1471, 2001. ,
DOI : 10.1214/aos/1069362732
Nearest-neighbor-based active learning for rare category detection, Neural Information Processing Systems, pp.633-640, 2007. ,
D-Confidence: an active learning strategy to reduce label disclosure complexity in the presence of imbalanced class distributions, Journal of the Brazilian Computer Society, vol.27, issue.5, pp.311-330, 2012. ,
DOI : 10.1007/978-1-4757-3359-4
Classification and Novel Class Detection in Concept-Drifting Data Streams under Time Constraints, IEEE Transactions on Knowledge and Data Engineering, vol.23, issue.6, pp.859-874, 2011. ,
DOI : 10.1109/TKDE.2010.61
Thuraisingham Classification and novel class detection in data streams with active mining Advances in Knowledge Discovery and Data Mining, pp.311-324, 2010. ,
Can shared-neighbor distances defeat the curse of dimensionality ?. Scientific and Statistical Database Management, pp.482-500, 2010. ,
Fang Unsupervised distributed novelty detection on scientific simulation data, Journal of Computational Information Systems, pp.1533-1540, 2011. ,
Kumar Finding topics in collections of documents : A shared nearest neighbor approach, pp.83-103, 2004. ,
Franti Outlier Detection Using k-Nearest Neighbour Graph, IEEE International Conference on Pattern Recognition, pp.430-433, 2004. ,
DOI : 10.1109/icpr.2004.1334558
URL : http://cs.joensuu.fi/~villeh/icpr2004.pdf
Sander LOF : identifying density-based local outliers, ACM Special Interest Group on Management of Data, vol.29, issue.2, pp.93-104, 2000. ,
DOI : 10.1007/978-3-540-48247-5_28
URL : http://www.cs.ualberta.ca/~joerg/papers/PKDD99-Outlier-final.pdf
Cheung Enhancing effectiveness of outlier detections for low density patterns Advances in Knowledge Discovery and Data Mining, pp.535-548, 2002. ,
Zhou Finding centric local outliers in categorical/numerical spaces, Knowledge and Information Systems, pp.309-338, 2006. ,
Xie Robust support vector machine with bullet hole image classification, IEEE Transactions on Systems, Man, and Cybernetics, pp.440-448, 2002. ,
Vemuri Robust anomaly detection using support vector machines, International Conference on Machine Learning, pp.282-289, 2003. ,
Li A New Online Learning With Kernels Methods In novelty detection, Proceedings of the 37th Annual Conference on IEEE Industrial Electronics Society (IECON), pp.2311-2316, 2011. ,
Platt Support Vector Method for Novelty Detection, Neural Information Processing Systems, pp.582-588, 1999. ,
Duin Support vector domain description. Pattern recognition letters, pp.1191-1199, 1999. ,
DOI : 10.1016/s0167-8655(99)00087-2
Learning User's Confidence for Active Learning, IEEE Transactions on Geoscience and Remote Sensing, vol.51, issue.2, pp.872-880, 2013. ,
DOI : 10.1109/TGRS.2012.2203605
Get another label? improving data quality and data mining using multiple, noisy labelers, Proceeding of the 14th ACM SIGKDD international conference on Knowledge discovery and data mining, KDD 08, pp.614-622, 2008. ,
DOI : 10.1145/1401890.1401965
URL : http://archive.nyu.edu/bitstream/2451/25882/4/kdd2008.pdf
Repeated labeling using multiple noisy labelers, International conference on Knowledge Discovery and Data Mining, pp.402-441, 2014. ,
DOI : 10.1109/TKDE.2005.176
URL : http://archive.nyu.edu/bitstream/2451/29799/2/CeDER-10-03.pdf
Silhouettes: A graphical aid to the interpretation and validation of cluster analysis, Journal of Computational and Applied Mathematics, vol.20, pp.53-65, 1987. ,
DOI : 10.1016/0377-0427(87)90125-7
A survey of multi-view machine learning, Neural Computing and Applications, pp.2031-2038, 2013. ,
DOI : 10.1016/j.patcog.2010.04.004
Noise elimination in inductive concept learning: A case study in medical diagnosis, pp.199-212, 1996. ,
DOI : 10.1007/3-540-61863-5_47
Noise modelling and evaluating learning from examples, Artificial Intelligence, vol.82, issue.1-2, pp.157-179, 1996. ,
DOI : 10.1016/0004-3702(94)00094-8
Bayesian Estimation of Disease Prevalence and the Parameters of Diagnostic Tests in the Absence of a Gold Standard, American Journal of Epidemiology, vol.141, issue.3, pp.263-272, 1995. ,
DOI : 10.1093/oxfordjournals.aje.a117428
Class Noise vs. Attribute Noise: A Quantitative Study, Artificial Intelligence Review, vol.3, issue.4, pp.177-210, 2004. ,
DOI : 10.1080/07421222.1996.11518099
Efficiency of discriminant analysis when initial samples are classified stochastically, Pattern Recognition, vol.23, issue.5, pp.529-537, 1990. ,
DOI : 10.1016/0031-3203(90)90073-T
Scholkopf Estimating a kernel Fisher discriminant in the presence of label noise, International Conference on Machine Learning, pp.306-313, 2001. ,
Feng Partially supervised learning using an EMboosting algorithm, Biometrics, vol.60, issue.1, pp.199-206, 2004. ,
Detecting potential labeling errors in microarrays by data perturbation, Bioinformatics, vol.98, issue.20, pp.2114-2121, 2006. ,
DOI : 10.1073/pnas.201162998
Analyzing the presence of noise in multi-class problems: alleviating its influence with the One-vs-One decomposition, Knowledge and Information Systems, vol.22, issue.2, pp.179-206, 2014. ,
DOI : 10.1007/s10462-004-0751-8
Laird Learning from noisy examples, Machine Learning, pp.343-370, 1988. ,
DOI : 10.1007/bf00116829
Baldi Inferring ground truth from subjective labelling of venus images, Advances in Neural Information Processing Systems, pp.1085-1092, 1994. ,
Ng Cheap and fast But is it good ? Evaluating nonexpert annotations for natural language tasks, Conference on Empirical Methods in Natural Language Processing, pp.254-263, 2008. ,
Wang Quality management on Amazon mechanical turk, ACM Conference on Knowledge Discovery and Data Mining, workshop on human computation, pp.64-67, 2010. ,
DOI : 10.1145/1837885.1837906
URL : http://pages.stern.nyu.edu/%7Epanos/publications/hcomp2010.pdf
Learning from crowds, Journal of Machine Learning Research, vol.11, pp.1297-1322, 2010. ,
Leung A survey of crowdsourcing systems, IEEE International Conference on Social Computing, pp.766-773, 2011. ,
Robust Boosting Algorithm Against Mislabeling in Multiclass Problems, Neural Computation, vol.8, issue.6, pp.1596-1630, 2008. ,
DOI : 10.1162/089976604322860695
Laskov Support Vector Machines Under Adversarial Label Noise, Journal of Machine Learning Research, issue.11, pp.97-112, 2011. ,
Eckert Adversarial label flips attack on support vector machines, European Conference on Artificial Intelligence, pp.870-875, 2012. ,
Beigman Some empirical evidence for annotation noise in a benchmarked dataset, Annual Conference of the North American Chapter of the Association for Computational Linguistics, pp.438-446, 2010. ,
Friedl Identifying mislabeled training data, Journal of Artificial Intelligence Research, pp.131-167, 1999. ,
Analysis of new techniques to obtain quality training sets, Pattern Recognition Letters, vol.24, issue.7, pp.1015-1022, 2003. ,
DOI : 10.1016/S0167-8655(02)00225-8
Gasca Decontamination of training samples for supervised pattern recognition methods Advances in Pattern Recognition, pp.621-630, 2000. ,
Zighed Identifying and handling mislabelled instances, Journal of Intelligent Information Systems, vol.22, issue.1, pp.89-109, 2004. ,
DOI : 10.1023/A:1025832930864
Chen Identifying and correcting mislabeled training instances, Future Generation Communication and Networking, vol.1, pp.244-250, 2007. ,
DOI : 10.1109/fgcn.2007.146
Huang Support vector machine for outlier detection in breast cancer survivability prediction. Advanced Web and NetworkTechnologies, pp.99-109, 2008. ,
Data Cleaning for Classification Using Misclassification Analysis, Journal of Advanced Computational Intelligence and Intelligent Informatics, vol.14, issue.3, pp.297-302, 2010. ,
DOI : 10.20965/jaciii.2010.p0297
Lorena Use of classification algorithms in noise detection and elimination, Hybrid Artificial Intelligence Systems, pp.417-424, 2009. ,
Vapnik Discovering informative patterns and data cleaning Advances in Knowledge Discovery and Data Mining, pp.181-203, 1996. ,
Friedl Improving automated land cover mapping by identifying and eliminating mislabeled observations from training data, Geoscience and Remote Sensing Symposium, pp.27-31, 1996. ,
Distinguishing mislabeled data from correctly labeled data in classifier design, 16th IEEE International Conference on Tools with Artificial Intelligence, pp.668-672, 2004. ,
DOI : 10.1109/ICTAI.2004.52
Martinez Reduction techniques for instance-based learning algorithms, Machine Learning, pp.257-286, 2000. ,
Tarassenko Semi-supervised learning of probabilistic models for ECG segmentation, Annual International Conference of Engineering in Medicine and Biology Society, pp.434-437, 2004. ,
Shriberg Automatic labeling inconsistencies detection and correction for sentence unit segmentation in conversational speech, Machine Learning for Multimodal Interaction, pp.144-155, 2008. ,
Folleco An empirical study of the classification performance of learners on imbalanced and noisy software quality data, IEEE International Conference on Information Reuse and Integration, pp.651-658, 2007. ,
Vapnik Computer aided cleaning of large databases for character recognition, International Conference on Pattern Recognition Methodology and Systems, pp.330-333, 1992. ,
Quiles Semi-supervised learning from imperfect data through particle cooperation and competition, International Joint Conference on Neural Networks, pp.1-8, 2010. ,
Identifying mislabeled training data with the aid of unlabeled data, Applied Intelligence, vol.2, issue.2, pp.345-358, 2011. ,
DOI : 10.1162/089976601300014493
Enhancing data analysis with noise removal, IEEE Transactions on Knowledge and Data Engineering, vol.18, issue.3, pp.304-319, 2006. ,
DOI : 10.1109/TKDE.2006.46
Dunker Using one-class SVM outliers detection for verification of collaboratively tagged image training sets, IEEE Transactions on Multimedia and Expo, vol.18, issue.3, pp.682-685, 2009. ,
Lewis The subjective nature of outlier rejection procedures, Applied Statistics, pp.228-237, 1976. ,
Wu Analyzing outliers cautiously, IEEE Transactions on Knowledge and Data Engineering, vol.14, issue.2, pp.432-437, 2002. ,
