Targeting Tissue-Specific Enzymatic Cascades of Local Angiotensin System in Human Atheroma - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2015
Ciblage Tissu-Spécifique des Cascades Enzymatiques de l’Angiotensinogène dans l’Athérome Humain
Ali Nehme
Atherosclerosis remains and continues to be the leading cause of death and disability in the world. The implication of Renin-angiotensin-aldosterone system (RAAS) in the development of the disease is well experimentally and clinically documented. However, due to the complexity of the system, these studies remain dispersed and give no clear global view of the association between the system and the disease. In this regard, we studied the functional organization of a set of 37 genes encoding classical and newly discovered RAAS participants, including substrate, enzymes and receptors. This set was called extended RAAS (extRAAS). Using statistical analysis of human carotid atheroma transcriptome involving gene clustering, we revealed special features of extRAAS expression associated with atheromatous remodeling. An important feature of this pattern was the coordination of 2 clusters of genes that are known to favor atheroma formation. The first cluster constitutes genes that encode for angiotensin peptidases, including ACE, CTSG, CTSD and RNPEP. Whereas the second encode for receptors (AGTR1, MR, GR and LNPEP). We hypothesized that the local pattern of extRAAS gene expression plays a key role in the development of atherosclerosis by orienting the metabolism of active peptides
L'Athérosclérose est la principale cause de décès et d'invalidité dans le monde. L'implication du système rénine-angiotensine-aldostérone (RAAS) dans le développement de la maladie est expérimentalement et cliniquement bien documentée. Toutefois, en raison de la complexité du système, ces études ne donnent pas de vision claire sur l'association entre le système et la maladie. À cet égard, nous avons étudié l'organisation fonctionnelle d'un ensemble de 37 gènes codant pour les composants classiques et nouvellement découverts du RAAS, y compris les substrats, les enzymes et les récepteurs. Cet ensemble a été appelé RAAS étendu (extRAAS). En utilisant une analyse statistique des données du transcriptome de l'athérome carotidien humain, nous avons révélé des caractéristiques spéciales de l'expression de l'extRAAS associées au remodelage athéromateux. Une caractéristique importante de ce modèle est la coordination de 2 groupes de gènes qui sont connus pour favoriser la formation de l'athérome. Le premier groupe est constitué de gènes codant pour les peptidases de l'angiotensine, y compris ACE, CTSG, CTSD et RNPEP. Le deuxième groupe est constitué des gènes codant pour les récepteurs AGTR1, MR, GR et LNPEP
TH2015NehmeAli.pdf (15 Mo) Télécharger le fichier
tel-01271915 , version 1 (09-02-2016)
  • HAL Id : tel-01271915 , version 1
Ali Nehme. Targeting Tissue-Specific Enzymatic Cascades of Local Angiotensin System in Human Atheroma. Quantitative Methods [q-bio.QM]. Université Claude Bernard - Lyon I; École doctorale des Sciences et de Technologie (Beyrouth), 2015. English. ⟨NNT : 2015LYO10267⟩. ⟨tel-01271915⟩
282 Consultations
120 Téléchargements
