Time-accurate anisotropic mesh adaptation for three-dimensional moving mesh problems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2015
Adaptation de maillage anisotrope dépendant du temps pour des problèmes tridimensionnels en maillage mobile
Time dependent simulations are still a challenge for industry, notably due to problems raised by moving boundaries, both in terms of CPU cost and accuracy. This thesis presents contributions to several aspects of simulations with moving meshes. A moving-mesh algorithm based on a large deformation time step and connectivity changes (swaps) is studied. An elasticity method and an Inverse Distance Weighted interpolation method are compared on many 3D examples, demonstrating the efficiency of the algorithm in handling large geometry displacement without remeshing. This algorithm is coupled with an Arbitrary-Lagrangian-Eulerian (ALE) solver, whose schemes and implementation in 3D are described in details. A linear interpolation scheme is used to handle swaps. Validation test cases showed that the use of swaps does not impact notably the accuracy of the solution, while several other complex 3D examples demonstrate the capabilities of the approach both with imposed motion and Fluid-Structure Interaction problems. Metric-based mesh adaptation has proved its efficiency in improving the accuracy of steady simulation at a reasonable cost. We consider the extension of these methods to unsteady problems, updating the previous fixed-point algorithm thanks to a new space-time error analysis based on the continuous mesh model. An efficient p-thread parallelization enables running 3D unsteady adaptative simulations with a new level of accuracy. This algorithm is extended to moving mesh problems, notably by correcting the optimal unsteady metric. Finally several 3D examples of adaptative moving mesh simulations are exhibited, that prove our concept by improving notably the accuracy of the solution for a reasonable time cost.
Les simulations dépendant du temps sont toujours un challenge dans l'industrie, notamment à cause des problèmes posés par les géométries mobiles en termes de CPU et de précision. Cette thèse présente des contributions à certains aspects des simulations en géométrie mobile. Un algorithme de bouger de maillage fondé sur une déformation de maillage sur un grand pas de temps et des changements de connectivité (swaps) est étudié. Une méthode d'élasticité et une méthode d'interpolation directe sont comparées en 3D, démontrant l'efficacité de l'algorithme. Cet algorithme est couplé à un solver ALE, dont les schémas et l'implémentation en 3D sont décrits en détail. Une interpolation linéaire est utilisée pou traiter les swaps. Des cas de validation montrent que les swaps n'influent pas notablement sur la précision de la solution. Plusieurs examples complexes en 3D démontrent la puissance de cette approche, pour des mouvement imposés ou pour des problèmes d'Interaction Fluide-Structure. L'adaptation de maillage anisotrope a démontré son efficacité pour améliorer la précision des calculs stationnaires pour un coût raisonnable. On considère l'extension de ces méthodes aux problèmes instationnaires, en mettant à jour l'algorithme de point fixe précédent grâce à une ananlyse de l'erreur espace-temps fondée sur le modèle de maillage continu. Une parallélisation efficace permet de réaliser des simulations adaptatives instationnaires avec une précision inégalée. Cet algorithme est étendu au cas des géométries mobiles en corrigeant la métrique optimale instationnaire. Finalement, plusieurs exemples 3D de simulations adaptatives en géométries mobiles démontrent l'efficacité de l'approche.
2015PA066476.pdf (15.73 Mo) Télécharger le fichier
tel-01284113 , version 1 (07-03-2016)
tel-01284113 , version 2 (29-03-2016)
  • HAL Id : tel-01284113 , version 2
Nicolas Barral. Time-accurate anisotropic mesh adaptation for three-dimensional moving mesh problems. General Mathematics [math.GM]. Université Pierre et Marie Curie - Paris VI, 2015. English. ⟨NNT : 2015PA066476⟩. ⟨tel-01284113v2⟩
346 Consultations
405 Téléchargements
