Etude de la construction par réseaux neuromimétiques de représentations interprétables - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2000
Artificial neural networks arrangements leading to knowledge extraction
Laurent Bougrain
Artificial neural networks constitute good tools for certain types of computational modeling (being potentially efficient, easy to adapt and fast). However, they are often considered difficult to interpret, and are sometimes treated as black boxes. However, whilst this complexity implies that it is difficult to understand the internal organization that develops through learning, it usually encapsulates one of the key factors for obtaining good results. First, to yield a better understanding of how artificial neural networks behave and to validate their use as knowledge discovery tools, we have examined various theoretical works in order to demonstrate the common principles underlying both certain classical artificial neural network, and statistical methods for regression and data analysis. Second, in light of these studies, we have explained the specificities of some more complex artificial neural networks, such as dynamical and modular networks, in order to exploit their respective advantages in constructing a revised model for knowledge extraction, adjusted to the complexity of the phenomena we want to model. The artificial neural networks we have combined (and the subsequent model we developed) can, starting from task data, enhance the understanding of the phenomena modeled through analyzing and organizing the information for the task. We demonstrate this in a practical prediction task for telecommunication, where the general domain knowledge alone is insufficient to model the phenomena satisfactorily. This leads us to conclude that the possibility for practical application of our work is broad, and that our methods can combine with those already existing in the data mining and the cognitive sciences.
Les réseaux de neurones artificiels sont de bons outils de modélisation (efficaces, facilement adaptables et rapides) mais ils ont la réputation d'être difficiles à interpréter et sont généralement comparés à des boîtes noires dont il n'est pas facile de comprendre l'organisation interne, pourtant responsable de leurs bonnes performances. Pour obtenir une meilleure compréhension du fonctionnement des réseaux connexionnistes et une validation de leur utilisation en tant qu'outils d'acquisition de connaissances, nous avons, dans un premier temps, réuni divers travaux théoriques pour montrer les points communs existant entre certains réseaux de neurones classiques et des méthodes statistiques de régression et d'analyses de données. Dans un deuxième temps et à la lumière de ce qui précède, nous avons expliqué les particularités de réseaux connexionnistes plus complexes, tels que des réseaux dynamiques ou modulaires, afin d'exploiter leurs avantages respectifs en concevant un nouveau modèle d'extraction de connaissances adapté à la complexité du phénomène à modéliser. Les réseaux connexionnistes que nous avons réunis et interprétés et le modèle que nous avons développé peuvent, à partir des données, enrichir la compréhension du phénomène en analysant et en organisant les informations par rapport à la tâche à accomplir comme nous l'illustrons à travers une application de prédiction dans le domaine des télécommunications où la connaissance du domaine ne suffit pas à modéliser correctement le phénomène. Les possibilités d'application de notre travail sont donc larges et s'inscrivent dans le cadre de la fouille de données et dans le domaine des sciences cognitives.
bougrain-these.pdf (122.31 Mo) Télécharger le fichier
tel-01746779 , version 2 (18-03-2016)
tel-01746779 , version 1 (29-03-2018)
  • HAL Id : tel-01746779 , version 2
Laurent Bougrain. Etude de la construction par réseaux neuromimétiques de représentations interprétables : Application à la prédiction dans le domaine des télécommunications. Réseau de neurones [cs.NE]. Université Henri Poincaré - Nancy 1, 2000. Français. ⟨NNT : 2000NAN10241⟩. ⟨tel-01746779v2⟩
564 Consultations
203 Téléchargements
