soit S, une vari et e dii erentiable de dimension n. Soit p un point de S, S p l'espace tangent t a S en p. Soit ~ v un vecteur tangent t a S en p ,
1 { Deux cliques d'ordre 2 e t une clique d'ordre 1 ,
C-band repeat-pass interferometric SAR observations of the forest, IEEE Transactions on Geoscience and Remote Sensing, vol.35, issue.1, 1997. ,
DOI : 10.1109/36.551931
Syst emes dii erentiels -etude graphique, CE- DIC, 1983. ,
Manifolds, tensor analysis and applications, 1988. ,
Phase statics and decorrelation in SAR interferograms, Proceedings of IGARSS'93, 1993. ,
Analyse Num erique, 1991. ,
Contours actifs g eodesiques et a mod eles contraints pourle suivi des orages dans un contexte multisenseur : radar, interferometre VHF, satellite IR, GRETSI'97, p.1997 ,
A numerical model for large deformation on meteorological images, International Conference o n Analysis and Optimisation of Systems, Images, Wavelets and PDE's, 1996. ,
URL : https://hal.archives-ouvertes.fr/inria-00532686
Three-dimensional object recognition, Surveys, vol.17, issue.1, pp.75-145, 1985. ,
Fourier fringe analysis: the two dimensional phase unwrapping problem, Applied Optics, vol.30, pp.3227-3632, 1991. ,
Disparity analysis of images, Univ. of Minnesota, 1979. ,
A computational approach to edge detection. Pattern Analysis and Machine Intelligence, p.1986 ,
Tracking points on deformable objects using curvature information, Proceedings of the Second European Conference on Computer Vision 1992, pp.458-466, 1992. ,
DOI : 10.1007/3-540-55426-2_51
URL : https://hal.archives-ouvertes.fr/inria-00074965
Moment-preserving pattern matching, Pattern Recognition, vol.23, pp.461-474, 1990. ,
Model-based recognition in robot vision, Surveys, vol.18, issue.1, pp.67-108, 1986. ,
On the Partial Difference Equations of Mathematical Physics, IBM Journal of Research and Development, vol.11, issue.2, pp.215-235, 1967. ,
DOI : 10.1147/rd.112.0215
A subgraph isomorphism algorithm using resolution, Pattern Recognition, vol.13, pp.371-379, 1981. ,
Curves matching using geodesic path, SCIA'97, 1997. ,
Tracking meteorological structures through curves matching us ing geodesic paths, 1997. ,
Curves matching using geodesic paths, Proceedings. 1998 IEEE Computer Society Conference on Computer Vision and Pattern Recognition (Cat. No.98CB36231), 1998. ,
DOI : 10.1109/CVPR.1998.698686
URL : https://hal.archives-ouvertes.fr/inria-00532724
Global minimum for active contour models: A minimal path appro ach, Proceedings of the conference on Computer Vision and Pattern Recognition, pp.666-673, 1996. ,
Geodesic active contours, Proceedings of IEEE International Conference on Computer Vision, pp.61-79, 1997. ,
DOI : 10.1109/ICCV.1995.466871
Measurement of land subsidence by means of diierential SAR interferometry ,
Potentiel d'application de l'interf erom etrie SAR dii erentielle a l a d etection de mouvements de terrain ,
Potential application of diierential SAR interferometry for monitoring the impact of underground mining, The First Workshop on SAR Interferometry, T okyo, Japan Earth Environment Observation Committe, National Space Agency of Japan, 1994. ,
Geometric lter for reducing speckle, Optical engineering, vol.25, pp.651-654, 1986. ,
Euclidean distance mapping, Computer Vision, Graphics, and Image Processing, vol.14, pp.227-248, 1980. ,
Interf erom etrie radar et d eroulement de phase Rapport de recherche, R R No 2344, Carmo. Diierential Geometry of Curves and Surfaces, 1976. ,
Etude statistique d'images radar de la surface de la mer, 1993. ,
Optimal edge detection using recursive ltering, International Journal of Computer Vision, pp.167-187, 1987. ,
D eroulement de phase en interf erom etrie radar rapport de stage, Ecole Sup erieure en Sciences Informatiques, 1993. ,
G en eration de mod eles num eriques de terrain par interf erom etrie ROS, 1997. ,
The curve shortening ow, Wave motion: Theory, modeling and Computation, 1987. ,
D etection du glissement de terrain de Saint- Etienne de Tin ee par interf erom etrie SAR et mod elisation, C.R. Acad. Sci, pp.809-816, 1995. ,
Improving consistency and reducing ambiguity in stochastic labeling: An optimization approach, PAMI, vol.3, issue.4, pp.412-424, 1981. ,
Interferometric SAR phase unwrapping using Green's formulation, IEEE Transactions on Geoscience and Remote Sensing, vol.34, issue.3, pp.720-727, 1996. ,
DOI : 10.1109/36.499751
Estimation of an earthquake focal mechanism from a satellite radar interferogram: Application to the December 4, 1992 Landers aftershock, Geophysical Research Letters, vol.99, issue.9, pp.1037-1040, 1995. ,
DOI : 10.1029/94GL03212
A model for radar images and its application to adaptative digital ltering of multiplicative noise, IEEE Trans. on Pattern Analysis and Machine Intelligence, vol.4, pp.157-166, 1982. ,
Smoothing and matching of 3-d space curves, International Journal of Computer Vision, vol.79, issue.3, pp.79-104, 1994. ,
DOI : 10.1007/BF01420985
Warping and Morphing og Graphical Objects, 1999. ,
Satellite radar interferometry for monitoring ice sheet motion: Application to an antartic ice stream, Science, vol.262, pp.1525-1529, 1993. ,
Stochastic relaxation, Gibbs distributions and the Bayesian restoration of images, IEEE Trans. Pattern Anal. Machine Intell, vol.6, issue.6, pp.721-741, 1984. ,
A t wo-stage cross correlation approach to template matching, PAMI, vol.7, issue.2, pp.374-378, 1984. ,
Mapping small elevation changes over large areas: Differential radar interferometry, Journal of Geophysical Research, vol.91, issue.B5, pp.9183-9191, 1989. ,
DOI : 10.1029/JB094iB07p09183
Auscultation par imagerie num erique de quelques versants instables, 1992. ,
Two-Dimensional Phase Unwrapping. Theory, Algorithms and Software, 1998. ,
Direct phase estimation from phase diierence using fast elliptic partial diierential equation solvers. Optic letters, pp.1107-1109, 1989. ,
Robust two dimensional weighted and unweighted phase unwrapping that use fast transforms and iterative methods, Journal of the Optical Society of America, vol.11, pp.107-1117 ,
Satellite radar interferometry: Two-dimensional phase unwrapping, Radio Science, vol.23, issue.4, pp.713-720, 1988. ,
Segmentation of echocardiographic images with markov random elds, Third european Conference on Computer Vision, 1994. ,
An unwrapping method for interferometric SAR images, International Conference on Acoustics, Speech, and Signal Processing, pp.2853-2858, 1997. ,
Surveillance op erationnelle des glaces au moyen du SAR d'ERS-1. Observation de la terre { Bulletin trimestriel, pp.6-8, 1994. ,
D etection d'eeets phasim etriques SAR li es a des changements d' etat de surface, ORASIS'97, 1997. ,
Cropland detection with SAR interferometry: A segmentation model, International Conference on Acoustics, Speech, and Signal Processing, pp.2853-2858, 1998. ,
A model for detecting phasimetric SAR eeects coming from rainy e v ents, Proceedings of International Conference o n I m a g e Processing, ICIP'98, 1998. ,
Segmentation of temporal eeects on phasimetric SAR images, Proceedings of International Conference on Pattern Recognition, ICPR'98, pp.1390-1392, 1998. ,
Segmentation d'image d'interf erom etrie radar, Journ ees ORASIS'96, 1996. ,
Applying principal components analysis to image time series: eeects on scene segmentation and spatial structures, Proceedings of IGARSS'96, pp.448-450, 1996. ,
Image processing for multitemporal SAR images, Proceedings of European Symposium on Remote Sensing , volume SAR Image Analysis, Modelling, and Techniques ,
URL : https://hal.archives-ouvertes.fr/inria-00532723
Determining optical flow, Artificial Intelligence, vol.17, issue.1-3, pp.185-203, 1981. ,
DOI : 10.1016/0004-3702(81)90024-2
Application de l'interf erom etrie du SAR d'ERS-1 dans l'Antartique, pp.1-4, 1994. ,
Matrix formulation of the reconstruction phases values from phases diierences, Journal of the Optical Society of America, vol.69, pp.393-399, 1979. ,
Mise en correspondance de surfaces par chemins g eod esiques ,
On the foundation of relaxation labeling process, IEEE Trans. Pattern Anal. Machine Intell, vol.6, issue.6, pp.267-280, 1983. ,
Finding shortest paths on surfaces using level sets propagation, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.17, issue.6, pp.635-640, 1995. ,
DOI : 10.1109/34.387512
Tracking level sets by l e v el sets: A method for solving the shape from shading problem, CVIU, vol.62, issue.1, pp.47-58, 1995. ,
A hierarchical Markov random eld model and multi-temperature annealing for parallel image classiication, pp.1993-94, 1938. ,
Potential of ERS- 1 SAR for agricultural statics, 1996. ,
Adaptative restauration of images with speckle, IEEE Trans. on Acoustics, Speech and Signal Processing, pp.373-383, 1987. ,
Skeletonization via distance maps and level sets, CVIU, vol.62, issue.3, pp.382-391 ,
Shape from shading: Level set propagation and viscosity solutions, IJCV, vol.16, issue.2, pp.107-133, 1995. ,
Snakes: Active contour models, International Journal of Computer Vision, vol.5, issue.6035, pp.312-313, 1988. ,
DOI : 10.1007/BF00133570
Etimating the derivative of modulo-mapped phases, Proceedings of International Conference on Acoustics, Speech, and Signal Processing, 1997. ,
Mod elisation markovienne pour le d eroulement de phases interf erom etriques SAR, 1996. ,
SAR interferometry: a markovian approach to phase unwrapping with a discontinuity model, IGARSS'96, 1996. ,
Speckle analysis and smoothing of synthetic aperture radar images, Computer Graphics and Image Processing, vol.17, issue.1, pp.24-32, 1981. ,
DOI : 10.1016/S0146-664X(81)80005-6
Matching of Curvilinear Structures: Application to the Identification of Cortical Sulci on 3D magnetic resonance brain image, Proccedings of Pattern Recognition in Practice, 1994. ,
DOI : 10.1016/B978-0-444-81892-8.50021-3
URL : https://hal.archives-ouvertes.fr/hal-00981832
Feature-based volume metamorphosis, Proceedings of the 22nd annual conference on Computer graphics and interactive techniques , SIGGRAPH '95, pp.449-464, 1995. ,
DOI : 10.1145/218380.218502
Methodological advancements in using ERS SAR data for crop area estimation, Proceedings of the 3rd ERS Symposium on Spaceborne Radar Imagery, 1997. ,
Phase unwrapping for interferometric SAR using helmholtz equation eigenfunctions and the rst green's identity, Journal of the Optical Society of America ,
Implementing a stable integral method for interferometric phase unwrapping, Proceedings of EUSAR'98, pp.253-256, 1998. ,
Textural segmentation of SAR images using rst order statistical parameters, IGARSS'87 Symposium, pp.1463-1468, 1987. ,
New approaches in interferometric SAR data processing, IEEE Transactions on Geoscience and Remote Sensing, vol.30, issue.3, 1992. ,
DOI : 10.1109/36.142934
Two new practical methods for phase unwrapping, International Geoscience and Remote Sensing Symposium, 1995. ,
Une m ethode stable de d eveloppement de la phase en interf erom etrie ROS, 1996. ,
Filtrage, Topologie et mise en correspondance d'images m edicales multidimensionnelles, 1992. ,
Coseismic deformation eld of the M=6.7 Northridge, California earthquake of january 17, 1994 recorded by two radar satellites using interferometry, Geophysical Research Letters ,
D e a t i o n o f m o u n t Etna monitored by spaceborne radar interferometry, Nature { International Weekly Journal of Science, vol.375, pp.567-570, 1995. ,
Discrimination of geophysical phenomena in satellite radar interferograms, Geophysical Research Letters, vol.22, issue.12, pp.1537-1540, 1995. ,
Satellite radar interfeometric map of the coseismic deformation eld of the M=6.1 Eureka Valley, California earthquake of may 17, Geophysical Research Letters, issue.12, pp.221541-1544, 1993. ,
Radar interferometric mapping of deformation in the year after the Landers earthquake, Nature, vol.369, issue.6477, pp.227-230, 1994. ,
DOI : 10.1038/369227a0
Relation between the eruption of various volcanoes and the deformation of the ground surface around them. Bulletin of the earthquake research institute, pp.99-134, 1958. ,
Radar interfometry: limits and potential, IEEE Transactions on Geoscience and Remote Sensing, pp.31-455, 1993. ,
From Optics to Radar, Spot and ERS Applications, chapter Evaluation des changements de phase de surface sur de grandes zones, 1993. ,
The displacement eld of the Landers earthquake mapped by radar interferometry, Nature { International Weekly Journal of Science, vol.364, pp.138-142, 1993. ,
Fronts propagating with curvature dependent speed: Algorithms based on Hamilton{Jacobi formulations, J. of Comput. Physics, vol.79, pp.12-49, 1988. ,
Geodesic active regions for motion estimation and tracking, ICCV99, p.688, 1999. ,
URL : https://hal.archives-ouvertes.fr/inria-00073043
Diierent spot dem applications for studies in SAR interferometry, XVII ISPRS Congress, Commission IV, v ol. XXIX:87{ 93, 1991. ,
Seismic vibration for SAR focusing: Interferometrical applications, Geoscience R emote Sensing, 1990. ,
Phase unwrapping by means of multigrid techniques for interferometric sar, IEEE Trans. on Geoscience and Remote Sensing, vol.34, issue.3, pp.728-738, 1996. ,
Laboratory experiments for the interpretation of phase shift in SAR interferograms, Proceedings of Fringe'96, 1996. ,
Analyse d'une s equence d'interf erogrammes dii erentiels obtenus a partir de donn ees ERS-1 sur le site de Naizin en Bretagne, Symposium International de Toulouse, 1995. ,
Remote Sensing Digital Image Analysis. springer-verlag, 1994. ,
Optimal subpixel matching of contour chains and segments, Proceedings of IEEE International Conference on Computer Vision, pp.402-407, 1995. ,
DOI : 10.1109/ICCV.1995.466911
Level Set Methods: Evolving Interfaces in Geometry, Fluid Mechanics, Computer Vision and Materials Sciences, 1996. ,
A physically based approach to 2D shape blending, Computer Graphics, Siggraph'92 Conference proceedings, pp.25-34, 1992. ,
Structural descriptions and inexact matching, PAMI, vol.3, issue.5, pp.504-519, 1981. ,
Implementing continuous-scale morphology via curve evolution, Pattern Recognition, vol.26, issue.9, pp.1363-1372, 1993. ,
DOI : 10.1016/0031-3203(93)90142-J
Structural indexing: EEcient two dimensional object recognition1198{1204, December1992. BIBLIOGRAPHIE Spa95] U. Spagnolini. 2-D phase unwrapping and instantaneous frequency estimation, PAMI IEEE Trans. on Geoscience and Remote Sensing, vol.14, issue.333, pp.579-589, 1995. ,
A comprehensive introduction to diierential geometry, 1971. ,
Crystal growth and dendritic solidiication, Journal of Computational Physics, vol.98, pp.231-253, 1992. ,
Fast parallel surface interpolation with applications to digital cartography, 1989. ,
Multiresolution algorithms in computational vision, IU84, pp.225-262, 1984. ,
Matching of 3D curves using semi diierential invariants, IEEE Proceedings of the International Conference on Computer Visio n, pp.390-395, 1995. ,
Extremal points: deenition and application to 3D image registration, IEEE Proceedings of Computer Vision and Pattern Recognition, pp.587-592, 1994. ,
Elementary Topics In Diierential Geometry, 1979. ,
Imagerie interf erentielle en radar a ouverture synth etique, 1996. ,
Least-squares phase estimation from the phase diierence, Journal of the Optical Society of America, vol.5, issue.3, pp.416-425, 1988. ,
Reconnaissances des formes et analyse de sc ene en imagerie radar a ouverture synth etique, 1997. ,
Spatiotemporal integration in the detection of coherent motion, Vision Research, vol.24, issue.1, pp.47-53, 1984. ,
Image Analysis, Random Fields and Dynamic Monte Carlo Methods, 1995. ,
Farmland monitoring with SAR interferometry, IGARSS'95, 1995. ,
Land-surface analysis using ERS-1 SAR interferometry, ESA bulletin, vol.81, pp.30-37, 1995. ,
Epipolar Geometry in Stereo, Motion, and Object Recognition: A Uniied Approach, 1996. ,
Estimation of displacements from two 3-D frames obtained from stereo, PAMI, issue.12, pp.141141-1156, 1992. ,
Estimation of displacements from two 3D frames obtained from stereo, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.14, issue.12, pp.1141-1156, 1992. ,
On the derivation of coseismic displacement elds using diierential radar interferometry: the Landers earthquake, Journal of Geophysical Research, vol.99, issue.B10, pp.19-617, 1994. ,
Decorrelation in interferometric radar echoes, IEEE Trans. on Geoscience and Remote Sensing, vol.3, issue.0, 1992. ,
