Space-time codes based on quaternion algebras of small volume, 2012. ,
A simple transmit diversity technique for wireless communications. Selected Areas in Communications, IEEE Journal on, vol.16, issue.8, pp.1451-1458, 1998. ,
Generalization of Gabidulin codes over fields of rational functions, 21st International Symposium on Mathematical Theory of Networks and Systems, p.2014, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-01094843
Skew-cyclic codes. Applicable Algebra in Engineering, Communication and Computing, vol.18, issue.4, pp.379-389, 2007. ,
URL : https://hal.archives-ouvertes.fr/hal-00023483
On a class of error correcting binary group codes, Information and Control, vol.3, issue.1, pp.68-79, 1960. ,
DOI : 10.1016/S0019-9958(60)90287-4
Linear codes using skew polynomials with automorphisms and derivations. Designs, codes and cryptography, pp.405-431, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-00597127
Self-dual skew codes and factorization of skew polynomials, Journal of Symbolic Computation, vol.60, pp.47-61, 2014. ,
DOI : 10.1016/j.jsc.2013.10.003
URL : https://hal.archives-ouvertes.fr/hal-00719506
Error correction for algebraic block codes, US Patent, vol.4633, p.470, 1986. ,
Some algorithms for skew polynomials over finite fields. arXiv preprint, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00765577
Codes correcteurs sur des anneaux de öre multivariés, 2008. ,
Codes correcteurs avec les polynômes tordus, 2010. ,
Skew codes of prescribed distance or rank. Designs, Codes and Cryptography, pp.267-284, 2009. ,
URL : https://hal.archives-ouvertes.fr/hal-00267034
A course in computational algebraic number theory, 1993. ,
DOI : 10.1007/978-3-662-02945-9
Galois theory, 2011. ,
Bilinear forms over a finite field, with applications to coding theory, Journal of Combinatorial Theory, Series A, vol.25, issue.3, pp.226-241, 1978. ,
DOI : 10.1016/0097-3165(78)90015-8
A New Algorithm for Decoding Reed-Solomon Codes, Communications, Information and Network Security, pp.55-68, 2003. ,
DOI : 10.1007/978-1-4757-3789-9_5
Highly resilient correctors for polynomials, Information Processing Letters, vol.43, issue.4, pp.169-174, 1992. ,
DOI : 10.1016/0020-0190(92)90195-2
Error detecting and error correcting codes, Bell System technical journal, vol.29, issue.2, pp.147-160, 1950. ,
Network coding : an introduction, 2008. ,
DOI : 10.1017/CBO9780511754623
Maximal orders in the design of dense space-time lattice codes. Information Theory, IEEE Transactions on, vol.54, issue.10, pp.4493-4510, 2008. ,
Codes correcteurs d'erreurs. Chiffres (paris), pp.147-156116, 1959. ,
On the sphere-decoding algorithm I. Expected complexity, IEEE Transactions on Signal Processing, vol.53, issue.8, pp.2806-2818, 2005. ,
DOI : 10.1109/TSP.2005.850352
On defining generalized rank weights. arXiv preprint, 2015. ,
Coding for errors and erasures in random network coding. Information Theory, IEEE Transactions on, vol.54, issue.8, pp.3579-3591, 2008. ,
An algebraic approach to network coding, IEEE/ACM Transactions on Networking, vol.11, issue.5, pp.782-795, 2003. ,
DOI : 10.1109/TNET.2003.818197
List-decoding Gabidulin codes via interpolation and the euclidean algorithm, Information Theory and its Applications (ISITA), p.2014 ,
A unified construction of space-time codes with optimal ratediversity tradeoff. Information Theory, IEEE Transactions on, vol.51, issue.5, pp.1709-1730, 2005. ,
A Welch???Berlekamp Like Algorithm for Decoding Gabidulin Codes, Coding and Cryptography, pp.36-45, 2006. ,
DOI : 10.1007/11779360_4
URL : https://hal.archives-ouvertes.fr/hal-00459611
On transform-domain error and erasure correction by Gabidulin codes. Designs, Codes and Cryptography, pp.571-586, 2014. ,
Algebraic number theory, 1999. ,
DOI : 10.1007/978-3-662-03983-0
Cyclic Division Algebras: A Tool for Space-Time Coding, Foundations and Trends?? in Communications and Information Theory, vol.4, issue.1, 2007. ,
DOI : 10.1561/0100000016
Self-Repairing Codes for distributed storage — A projective geometric construction, 2011 IEEE Information Theory Workshop ,
DOI : 10.1109/ITW.2011.6089443
Perfect Space–Time Block Codes, IEEE Transactions on Information Theory, vol.52, issue.9, pp.3885-3902, 2006. ,
DOI : 10.1109/TIT.2006.880010
On the existence of generalized rank weights, 2012. ,
Codes correcteurs : théorie et applications, 1989. ,
Maximum-rank array codes and their application to crisscross error correction. Information Theory, IEEE Transactions on, vol.37, issue.2, pp.328-336, 1991. ,
Polynomial codes over certain finite fields, Journal of the society for industrial and applied mathematics, vol.8, issue.2, pp.300-304, 1960. ,
Théorie algébrique des nombres, 1971. ,
A Mathematical Theory of Communication, Bell System Technical Journal, vol.27, issue.3, pp.379-423, 1948. ,
DOI : 10.1002/j.1538-7305.1948.tb01338.x
Maximum distance n-ary codes. Information Theory, IEEE Transactions on, vol.10, issue.2, pp.116-118, 1964. ,
A rank-metric approach to error control in random network coding. Information Theory, IEEE Transactions on, vol.54, issue.9, pp.3951-3967, 2008. ,
Full-diversity, high-rate space-time block codes from division algebras. Information Theory, IEEE Transactions on, issue.10, pp.492596-2616, 2003. ,
Galois theory, 2015. ,
DOI : 10.1007/978-94-009-0839-0
Algebraic function fields and codes, 2009. ,
Capacity of Multi-antenna Gaussian Channels, European transactions on telecommunications, pp.585-595, 1999. ,
DOI : 10.1002/ett.4460100604
Space-time codes for high data rate wireless communication: performance criterion and code construction, IEEE Transactions on Information Theory, vol.44, issue.2, pp.744-765, 1998. ,
DOI : 10.1109/18.661517
Fast decoding of Gabidulin codes, WCC 2011-Workshop on coding and cryptography, pp.433-442, 2011. ,
DOI : 10.1007/s10623-012-9659-5
URL : https://hal.archives-ouvertes.fr/inria-00614474
Bounds on List Decoding of Rank-Metric Codes, IEEE Transactions on Information Theory, vol.59, issue.11, pp.7268-7277, 2013. ,
DOI : 10.1109/TIT.2013.2274653
URL : https://hal.archives-ouvertes.fr/hal-00904783
Decoding of Block and Convolutional Codes in Rank Metric, 2013. ,
URL : https://hal.archives-ouvertes.fr/tel-01056746
