Influence de la température sur l'activité micro-sismique dans un réservoir fracturé lors d'injections de longue durée. Application aux données du site de Rosemanowes (UK). Première approche d'un site potentiel dans le rift d'Assal (Djibouti) - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2013
Influence of temperature change on the micro-seismic activity in a fractured reservoir during long term injection. Application to the Rosemanowes geothermal project (UK). Preliminary consideration toward a new project in the Assal rift (Djibouti)
Ahmed Kayad Moussa
  • Fonction : Auteur
  • PersonId : 777888
  • IdRef : 192951122
The general framework of our research deals with the development of geothermal energy for electricity production using the heat stored in geological formations at depths ranging in 3 to 5 km, Generally the environment is poorly permeable and fractured. Our main objective is to study the phenomenon of induced micro-earthquakes in relation to the cooling of the rock. The work is based on field experiences including long duration tests, conducted on the Rosemanowes site (Cornwall, UK). For this, we proceeded to the development of a calculation tool, FRACAS, able to simulate this phenomenon by introducing a dual thermal approach to better simulate the cooling of the reservoir due to long term fluid injections, which might be responsible for new failure mechanisms due to the induced tractions. In this context, we introduced a new algorithm to describe shear in stabilities, a mechanism of "stick-slip" type with the consideration of static/dynamic friction coefficients. The possibility of inducing micro-seismicity is then studied using the in situ data base, with two 3D models offering different geometric approaches, a deterministic model and a stochastic model whose geometrical and physical properties were obtained from observations and previous work on this Rosemanowes site. The Thermo-Hydro-Mechanical (THM) simulation using the deterministic model has allowed us to calibrate the transient heat transfer in the reservoir formed by the drilling system RH12/RH15 and to give an estimate of tensile stress of thermal origin. To better study the effect induced by the contraction of the rock during time, we use the stochastic 3D model whose main objective is to simulate a more realistic spatial migration of shear ruptures. With this model we found a delayed onset of shear activity and discuss the effect of pressure step tests. The results suggest a way to mitigate the potential impact of shear ruptures due to cooling.
Le cadre général de la thèse concerne la valorisation sous forme de production d'énergie électrique de la chaleur présente à quelques kilomètres de profondeur (3 à 5 km), en général dans des milieux peu perméables et fracturés. Notre objectif principal est d'étudier le phénomène des microséismes induits relativement au refroidissement, en nous basant sur une expérience de terrain de longue durée, menée sur le site de Rosemanowes (Cornwall, UK). Pour cela nous avons procédé à la mise en place d'un outil de calcul, FRACAS, capable de simuler ce phénomène en introduisant une approche à double milieu thermique pour mieux simuler le refroidissement du réservoir dû à l'injection de fluide à long terme, responsable des nouveaux mécanismes de ruptures dus à la traction de la roche. Dans ce contexte nous avons introduit un nouvel algorithme pour prendre en compte les manifestations d'instabilités, un mécanisme de « stick-slip » avec prise en compte d'une friction statique et d'une friction dynamique. La possibilité d'induire des microséismes est ensuite étudiée à partir des données issues d'un site particulier, avec deux modèles 3D proposant des approches géométriques différentes, un modèle déterministe et un modèle stochastique, dont les propriétés géométriques et physiques ont été tirées des observations et travaux antérieurs effectués sur ce site de Rosemanowes. La simulation thermo-hydro-mécanique (THM) du modèle déterministe nous a permis de modéliser les échanges thermiques en régime transitoire dans le réservoir formé par le système de forages RH12/RH15 et d'estimer un ordre de grandeur des tractions d'origine thermique. Pour mieux étudier l'effet induit par la contraction des blocs de roche dans le temps nous utilisons le modèle 3D stochastique dont l'objectif principal est de simuler de façon plus réaliste la progression dans l'espace les ruptures en cisaillement. Avec ce modèle nous avons constaté l'apparition différée d'une activité et l'effet d'un cycle de pulses de pression, ce qui suggère un moyen d'atténuer les fortes magnitudes potentielles des ruptures en cisaillement dues au refroidissement.
2013ENMP0084_archivage.pdf (5.56 Mo) Télécharger le fichier
tel-01310481 , version 1 (02-05-2016)
  • HAL Id : tel-01310481 , version 1
Ahmed Kayad Moussa. Influence de la température sur l'activité micro-sismique dans un réservoir fracturé lors d'injections de longue durée. Application aux données du site de Rosemanowes (UK). Première approche d'un site potentiel dans le rift d'Assal (Djibouti). Sciences de la Terre. Ecole Nationale Supérieure des Mines de Paris, 2013. Français. ⟨NNT : 2013ENMP0084⟩. ⟨tel-01310481⟩
327 Consultations
805 Téléchargements
