Separated représentations for th multiscale simulation of the mechanical behavior and damages of composite materials. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2015
Représentations séparées pour la simulation multi-échelle du comportement mécanique et de l’endommagement des matériaux composites.
Separated representations for the multiscale simulation of the mechanicalbehavior and damages of composite materials.Abstract: The development of efficient simulations for composite structures is very challengingdue to the multiscale nature and the complex damage process of this materials. When usingstandard 3D discretization techniques with advanced models for large structures, the computationalcosts are generally prohibitive.In this thesis, a new strategy based on a separated represenation of the solution is explored todevelop a computationally efficient and reliable numerical framework for the analysis of damagesin laminated composites subjected to quasi-static and dynamic loading. The PGD (Proper GeneralizedDecomposition) is used to build the solution.To treat damage, and especially delamination, a cohesive zone model has been implemented inthe PGD solver. A novel multiscale approach is also proposed to compute the mechanical behaviorof composites with periodic microstructure. The idea is to separate two scales: the scaleof periodic pattern and the macroscopic scale. The PGD results have been compared with theresults obtained with the classcial finite element method. A close agreement is found between thetwo approach and the PGD has significantly reduced the model complexity.
Représentations séparées pour la simulation multi-échelle du comportementmécanique et de l’endommagement des matériaux composites.Résumé: Le développement de méthodes numériques performantes pour simuler les structurescomposites est un défi en raison de la nature multi-échelle et de la complexité des mécanismed’endommagement de ce type de matériaux. Les techniques classiques de discrétisationvolumique conduisent à des coûts de calcul importants et sont restreintes en pratique à despetites structures.Dans cette thèse, un nouvelle stratégie basée sur une représentation séparée de la solution estexplorée. L’objectif est de proposer un cadre numérique efficace et fiable pour analyser les endommagementsdans les composites stratifiés sous chargements statiques et dynamiques. Ladécomposition propre généralisée (PGD) est utilisée pour construire la solution.Pour traiter l’endommagement, et plus particulière le délaminage, un modèle de zone cohésivea été implémenté dans la PGD. Une approches multi-échelle innovante est également proposéepour simuler le comportement mécanique des composites à microstructure périodique. L’idéeprincipale est de séparer deux échelles : l’échelle du motif périodique (microstructure) et l’échellemacroscopique. Les résultats de la PGD sont très proches des résultats obtenus par la méthodeéléments fini classique. Finalement, la PGD permet de réduire significativement la complexitédes modèles tout en gardant une précision satisfaisante.
METOUI.pdf (5.12 Mo) Télécharger le fichier
tel-01311101 , version 1 (03-05-2016)
  • HAL Id : tel-01311101 , version 1
Sondes Metoui. Separated représentations for th multiscale simulation of the mechanical behavior and damages of composite materials.. Mechanics of materials [physics.class-ph]. Ecole nationale supérieure d'arts et métiers - ENSAM, 2015. English. ⟨NNT : 2015ENAM0049⟩. ⟨tel-01311101⟩
435 Consultations
578 Téléchargements
