Contributions to Multidisciplinary Design Optimization under uncertainty, application to launch vehicle design - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2015
Contributions à l'optimisation multidisciplinaire sous incertitude, application à la conception de lanceurs
Launch vehicle design is a Multidisciplinary Design Optimization problem whose objective is to find the launch vehicle architecture providing the optimal performance while ensuring the required reliability. In order to obtain an optimal solution, the early design phases are essential for the design process and are characterized by the presence of uncertainty due to the involved physical phenomena and the lack of knowledge on the used models. This thesis is focused on methodologies for multidisciplinary analysis and optimization under uncertainty for launch vehicle design. Three complementary topics are tackled. First, two new formulations have been developed in order to ensure adequate interdisciplinary coupling handling. Then, two new reliability techniques have been proposed in order to take into account the various natures of uncertainty, involving surrogate models and efficient sampling methods. Eventually, a new approach of constraint handling for optimization algorithm ”Covariance Matrix Adaptation - Evolutionary Strategy” has been developed to ensure the feasibility of the optimal solution. All the proposed methods have been compared to existing techniques in literature on analysis and design test cases of launch vehicles. The results illustrate that the proposed approaches allow the improvement of the efficiency of the design process and of the reliability of the found solution.
La conception de lanceurs est un problème d’optimisation multidisciplinaire dont l’objectif est de trouverl’architecture du lanceur qui garantit une performance optimale tout en assurant un niveau de fiabilité requis.En vue de l’obtention de la solution optimale, les phases d’avant-projet sont cruciales pour le processus deconception et se caractérisent par la présence d’incertitudes dues aux phénomènes physiques impliqués etaux méconnaissances existantes sur les modèles employés. Cette thèse s’intéresse aux méthodes d’analyse et d’optimisation multidisciplinaire en présence d’incertitudes afin d’améliorer le processus de conception de lanceurs. Trois sujets complémentaires sont abordés. Tout d’abord, deux nouvelles formulations du problème de conception ont été proposées afin d’améliorer la prise en compte des interactions disciplinaires. Ensuite, deux nouvelles méthodes d’analyse de fiabilité, permettant de tenir compte d’incertitudes de natures variées, ont été proposées, impliquant des techniques d’échantillonnage préférentiel et des modèles de substitution. Enfin, une nouvelle technique de gestion des contraintes pour l’algorithme d’optimisation ”Covariance Matrix Adaptation - Evolutionary Strategy” a été développée, visant à assurer la faisabilité de la solution optimale. Les approches développées ont été comparées aux techniques proposées dans la littérature sur des cas tests d’analyse et de conception de lanceurs. Les résultats montrent que les approches proposées permettent d’améliorer l’efficacité du processus d’optimisation et la fiabilité de la solution obtenue.
brevault-loic-diff.pdf (23.73 Mo) Télécharger le fichier
tel-01320231 , version 1 (23-05-2016)
  • HAL Id : tel-01320231 , version 1
Loïc Brevault. Contributions to Multidisciplinary Design Optimization under uncertainty, application to launch vehicle design. General Mathematics [math.GM]. Ecole Nationale Supérieure des Mines de Saint-Etienne, 2015. English. ⟨NNT : 2015EMSE0792⟩. ⟨tel-01320231⟩
315 Consultations
121 Téléchargements
