Simulation of low- and mid-frequency response of shocks with a frequency approach - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2016
Simulation de la réponse en basse et moyenne-fréquence de chocs par une approche en fréquence
Recently, aerospace and automotive industries are increasingly interested in virtual testing since it speeds-up the design process and reduces costs. This is particularly true in case of space industries where specimens are very costly because rockets are unique or produced in limited number. Ariane 5 (and 6 in the future) is a heavy lift launch rocket manufactured by CNES and Airbus DS. During launch the protective fairing is severed from the rocket by pyrotechnic charges once sufficient altitude is reached (typically above 100 km). Shock vibrations propagate throughout rocket shell structure to the payload which can be damaged. The HSS3+ ground full-scale test was developed by CNES and Airbus DS to investigate such eventuality. This thesis develops a software capable of simulating the HSS3+ test to characterize explosion loads and to reduce the number of future required real tests. The task is difficult since the interesting frequency band is wide (up to mid-frequency), the explosion loads are unknown, the geometry is complex, and the specimen is composed of sandwich composite shells. The software called Transient Analysis for PYROtechnic Shocks in Shells (TAPYROSS) is based on the Variational Theory of Complex Rays (VTCR) which is a Trefftz method specifically developed to analyze the mid-frequency band. Many theory and performance improvements are introduced to address this real industrial test case. At the end, comparisons between real data and simulations validate TAPYROSS and characterize explosion loads.
Récemment, les industries aérospatiale et automobile sont de plus en plus intéressées par les tests virtuels, car ils accélèrent le processus de conception et ils réduisent les coûts. C’est particulièrement vrai dans le cas des industries spatiales où les maquettes sont très coûteuses car les fusées sont uniques ou produites en nombre limité. Ariane 5 (et 6 dans l'avenir) est un lanceur qui est fabriqué par CNES et Airbus DS. Pendant le lancement, la coiffe est détachée par des charges pyrotechniques quand la fusée est à une hauteur suffisante (généralement au-dessus de 100 km). Les vibrations générées par les explosions se propagent dans les coques de la fusée jusqu'à la charge utile qui peut être endommagé. Le test au sol età pleine échelle HSS3+ a été effectué par CNES et Airbus DS pour enquêter sur cette éventualité. Cette thèse développe un logiciel capable de simuler le test HSS3+ pour caractériser les efforts produits par les charges pyrotechniques et pour réduire dans l'avenir le nombre de tests réels nécessaires. La tâche est difficile car la bande de fréquence considérée est très large (jusqu'à moyenne fréquence), les efforts des explosions sont inconnus, la géométrie est complexe et la maquette est composé des coques composites et sandwich. Le logiciel appelé Transient Analysis for PYROtechnic Shocks in Shells (TAPYROSS) est basée sur la Théorie variationnelle des Rayons Complexes (TVRC) qui est une méthode de Trefftz spécifiquement développé pour analyser la moyenne fréquence. De nombreuses améliorations de la théorie et des performances ont été introduits pour étudier ce cas réel de complexité industriel. Le dernier chapitre est dédié aux comparaisons entre les données réelles et les simulations pour valider TAPYROSS et caractériser les efforts des explosions.
75806_CATTABIANI_2016_archivage.pdf (27.68 Mo) Télécharger le fichier
tel-01321217 , version 1 (25-05-2016)
  • HAL Id : tel-01321217 , version 1
Alessandro Cattabiani. Simulation of low- and mid-frequency response of shocks with a frequency approach. Solid mechanics [physics.class-ph]. Université Paris Saclay (COmUE), 2016. English. ⟨NNT : 2016SACLN012⟩. ⟨tel-01321217⟩
663 Consultations
310 Téléchargements
