Flame front small scale wrinkling experimental characterisation of a turbulent premixed flame : pressure effects
Caractérisation expérimentale des plissements à petite échelle dans une flamme turbulente prémélangée : effets de la pression
The present work is an experimental study on the interactions between flame and turbulence. The pressure effect on the flame front wrinkling is characterised using laser diagnostics and hot wire anemometry. To begin with, the turbulence generated by a multi-grid system is characterised. It is shown that the present system produces a higher turbulence rate by 40% than for an equivalent mesh single-grid system. Moreover, the small turbulence scales sizes are experimentally found smaller with the multi-grid system. From those results, the interactions between premixed flames and turbulence were studied. By using the laser tomography diagnostic, the flame front of several gases premixes was observed. By changing the mixing conditions, the effect of parameters such as the Lewis number, the turbulence conditions and the small scale was observed. The low impact of the thermodiffusives instabilities in our conditions was demonstrated. However, the important effect of the turbulence conditions on the flame front characteristics was observed. Moreover, the present results showed the major impact of the Taylor micro scale on the flame front wrinkling for these study experimental conditions.
Le présent travail est une étude expérimentale sur l’interaction entre flamme et turbulence. L’effet de la pression sur le plissement de flammes turbulentes prémélangées est caractérisé à l’aide de diagnostics laser et fil chaud. Dans un premier temps, la caractérisation de la turbulence générée par un système multi-échelles a été réalisée. Il a été démontré que ce dispositif amplifie le taux de turbulence de 40% par rapport à un dispositif mono-grille de maille équivalente. De même, les petites échelles de turbulence sont trouvées expérimentalement plus petites et plus énergétiques pour le système multi-grilles. A partir de ces résultats, l’étude des interactions entre flamme prémélangée et turbulence a été effectuée. En utilisant le diagnostic par tomographie laser, le front de flamme de plusieurs prémélanges a été étudié. En modifiant les conditions de mélange, l’effet des paramètres comme le nombre de Lewis, les conditions de turbulence ou les petites échelles ont pu être observés. Le faible impact des instabilités thermodiffusives sur la courbure du front de flamme et sur la dynamique de la flamme a été démontré. En revanche, l’effet des conditions de turbulence a été démontré comme important sur les caractéristiques du front de flamme. De plus, les résultats obtenus ont montré l’impact majeur de l’échelle de Taylor sur le plissement du front de flamme pour les conditions expérimentales de la présente étude.
