Communication Sécurisée et Coopération dans les Réseaux sans Fil avec Interférences and of their Inverter - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2015
Secure Communication and Cooperation in Interference-Limited Wireless Networks
In this thesis, we conduct an information-theoretic study on two important aspects of wireless communications: the improvement of data throughput in interference-limited networks by means of cooperation between users and the strengthening of the security of transmissions with the help of feedback.In the first part of the thesis, we focus on the simplest model that encompasses interference and cooperation, the Interference Relay Channel (IRC). Our goal is to characterize within a fixed number of bits the capacity region of the Gaussian IRC, independent of any channel conditions. To do so, we derive a novel outer bound and two inner bounds. Specifically, the outer bound is obtained thanks to a nontrivial extension we propose of the injective semideterministic class of channels, originally derived by Telatar and Tse for the Interference Channel (IC).In the second part of the thesis, we investigate the Wiretap Channel with Generalized Feedback (WCGF) and our goal is to provide a general transmission strategy that encompasses the existing results for different feedback models found in the literature. To this end, we propose two different inner bounds on the capacity of the memoryless WCGF. We first derive an inner bound that is based on the use of joint source-channel coding, which introduces time dependencies between the feedback outputs and the channel inputs through different time blocks. We then introduce a second inner bound where the feedback link is used to generate a key that encrypts the message partially or completely.
Dans cette thèse, nous menons une étude dans le cadre de la théorie de l'information sur deux questions importantes de la communication sans fil : l'amélioration du débit de données dans les réseaux avec interférence grâce à la coopération entre utilisateurs et le renforcement de la sécurité des transmissions à l'aide d'un signal de rétroaction.Dans la première partie de la thèse, nous nous concentrons sur le modèle le plus simple qui intègre à la fois l'interférence et la coopération, le canal à relais et interférence ou IRC (Interference Relay Channel). Notre objectif est de caractériser dans un nombre fixe de bits la région de capacité du IRC gaussien. À cette fin, nous dérivons une nouvelle limite supérieure de la capacité et deux stratégies de transmission. La limite supérieure est notamment obtenue grâce à une extension non triviale que nous proposons, de la classe de canaux semi-déterministe et injective à l'origine dérivée par Telatar et Tse pour le canal à interférence.Dans la seconde partie, nous étudions le canal avec espion et rétroaction généralisée ou WCGF (Wiretap Channel with Generalized Feedback). Notre objectif est de développer une stratégie de transmission générale qui englobe les résultats existants pour les différents modèles de rétroaction trouvés dans la littérature. À cette fin, nous proposons deux stratégies de transmission différentes sur la capacité du WCGF sans mémoire. Nous dérivons d'abord une stratégie qui est basée sur le codage source-canal conjoint. Nous introduisons ensuite une seconde stratégie où le signal de rétroaction est utilisé pour générer une clé secrète qui permet de chiffrer le message partiellement ou totalement.
BASSI_German_manuscript_bassi.pdf (1.28 Mo) Télécharger le fichier
tel-01323027 , version 1 (30-05-2016)
  • HAL Id : tel-01323027 , version 1
German Bassi. Communication Sécurisée et Coopération dans les Réseaux sans Fil avec Interférences and of their Inverter. Autre. CentraleSupélec, 2015. Français. ⟨NNT : 2015CSUP0018⟩. ⟨tel-01323027⟩
321 Consultations
224 Téléchargements
