Role of external synchronizers (photoperiod and ambient temperature) in adaptation to extreme environmental conditions in two seasonal species : the camel (Camelus dromedarius) adapted to hot areas and European hamster (Cricetus cricetus) adapted to cold areas
Rôle des synchronisateurs externes (photopériode et température ambiante) dans l'adaptation aux conditions extrêmes de l'environnement chez deux espèces saisonnières : le dromadaire (Camelus dromaderius) adapté à la chaleur et le hamster d'Europe (Cricetus cricetus) adapté au froid
The functional integrity of living organisms, including human, depends on the biological rhythms. Disruption of these rhythms due to the living conditions of the modern world (shift work, jet lag ...) or natural circumstances (aging), leads various abnormalities (sleep disorders, obesity, diabetes ...). In order to understand pathophysiology of these abnormalities and adaptation in extreme environment, we need to design experiments on diurnal animals that cohabitate with human in specific biotopes. The aim of my thesis is to understand the neurophysiological mechanisms of adaptation to extreme environmental conditions in the camel (adapted to heat) and the European hamster (adapted to cold). Earlier we found that in addition to photoperiod, ambient temperature is a real synchronizer of the biological clock, at least in the absence of light-dark cycle. In the second part of my project, we investigated if seasonal variations of ambient temperature are capable to changes the rhythm of melatonin secretion and/or body temperature like photoperiod. Since heterothermy in camel challenged recently, we started our study by confirming the existence of adaptive heterothermy in camels. Our results demonstrate that dehydrated camels during exposure to daily heat show adaptive heterothermy. This mechanism is more complex because it is characterized by a daily alternation of two periods of poikilothermy and homeothermy. This adaptive heterothermy was also observed when camels are hydrated and food deprived. Based on our results, we can conclude that adaptive heterothermy in the Arabian camel is a combination of three factors interacting throughout the light-dark cycle: heat stress, water restriction, and level of food intake. Finally, we have demonstrated in European hamster that neurons of the arcuate nucleus are able to integrate photoperiodic signal, independent of melatonin. The existence of this particular mechanism of integration of photoperiod in other mammals including humans must be investigated. Our results promote to study the role of this new mechanism of integration of photoperiod in the control of biological rhythms in particular the circannual rhythms
L’intégrité fonctionnelle des organismes vivants, Homme y compris dépend des rythmes biologiques. La perturbation de ces rythmes due aux conditions de vie du monde moderne (travail posté, jet-lag,…) ou des circonstances naturelles (vieillissement), favorise l’installation de pathologies spécifiques (troubles du sommeil, l’obésité, le diabète,…). Afin de retarder l’apparition de ces troubles, la conception des projets expérimentaux sur des modèles d’animaux diurnes et des modèles d’animaux vivants dans des biotopes particuliers où l’Homme est présent (zone désertique) est nécessaire. Le but de ma thèse est d’essayer de comprendre les mécanismes neurophysiologiques d’adaptation aux conditions environnementales extrêmes chez le dromadaire (adapté à la chaleur) et le hamster d’Europe (adapté au froid). Une première partie révèle qu’en plus de la photopériode, la température ambiante est un véritable synchroniseur de l’horloge biologique du moins en absence du cycle lumière-obscurité. Dans une seconde partie, notre objectif était de vérifier si les variations saisonniers de la température ambiante sont capables comme les changements photopériodiques d’induire des modifications saisonnières sur le rythme de mélatonine et/ou de la température corporelle. Nous avons commencé par la vérification de l’existence de l’hétérothermie adaptative chez le dromadaire surtout que ce phénomène a été contesté récemment. Nos résultats démontrent que le dromadaire privé d’eau de boisson et placé sous des températures ambiantes élevées, adopte une régulation complexe de thermorégulation caractérisée par une alternance quotidienne de phase de poïkilothermie et d’homéothermie. Cet état d’hétérothermie a également été observé chez des dromadaires parfaitement hydratés, sujet d’une restriction alimentaire. Nos résultats concluent donc que l’hétérothermie adaptative chez le dromadaire est une combinaison de plusieurs facteurs qui interagissent le long du cycle lumière-obscurité, à savoir la température ambiante, la privation hydrique et la prise alimentaire. Finalement, nous avons démontré chez le hamster d’Europe que les neurones des noyaux arqués sont capables d’intégrer le signal photopériodique et cela indépendamment de la présence de la mélatonine. L’existence de ce mécanisme particulier d’intégration de la photopériode chez d’autres mammifères y compris l’Homme doit maintenant être recherchée. Nos résultats ouvrent la voie à la mise en évidence de son intérêt pratique dans le contrôle des rythmes biologiques en particulier dans celui des rythmes circannuels.
