Optimisation de la localité des données sur architectures manycœurs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2016
Data locality on manycore architectures
The continuous evolution of computer architectures has been an important driver of research in code optimization and compiler technologies. A trend in this evolution that can be traced back over decades is the growing ratio between the available computational power (IPS, FLOPS, ...) and the corresponding bandwidth between the various levels of the memory hierarchy (registers, cache, DRAM). As a result the reduction of the amount of memory communications that a given code requires has been an important topic in compiler research. A basic principle for such optimizations is the improvement of temporal data locality: grouping all references to a single data-point as close together as possible so that it is only required for a short duration and can be quickly moved to distant memory (DRAM) without any further memory communications.Yet another architectural evolution has been the advent of the multicore era and in the most recent years the first generation of manycore designs. These architectures have considerably raised the bar of the amount of parallelism that is available to programs and algorithms but this is again limited by the available bandwidth for communications between the cores. This brings some issues thatpreviously were the sole preoccupation of distributed computing to the world of compiling and code optimization techniques.In this document we present a first dive into a new optimization technique which has the promise of offering both a high-level model for data reuses and a large field of potential applications, a technique which we refer to as generalized tiling. It finds its source in the already well-known loop tiling technique which has been applied with success to improve data locality for both register and cache-memory in the case of nested loops. This new "flavor" of tiling has a much broader perspective and is not limited to the case of nested loops. It is build on a new representation, the memory-use graph, which is tightly linked to a new model for both memory usage and communication requirements and which can be used for all forms of iterate code.Generalized tiling expresses data locality as an optimization problem for which multiple solutions are proposed. With the abstraction introduced by the memory-use graph it is possible to solve this optimization problem in different environments. For experimental evaluations we show how this new technique can be applied in the contexts of loops, nested or not, as well as for computer programs expressed within a dataflow language. With the anticipation of using generalized tiling also to distributed computations over the cores of a manycore architecture we also provide some insight into the methods that can be used to model communications and their characteristics on such architectures.As a final point, and in order to show the full expressiveness of the memory-use graph and even more the underlying memory usage and communication model, we turn towards the topic of performance debugging and the analysis of execution traces. Our goal is to provide feedback on the evaluated code and its potential for further improvement of data locality. Such traces may contain information about memory communications during an execution and show strong similarities with the previously studied optimization problem. This brings us to a short introduction to the algorithmics of directed graphs and the formulation of some new heuristics for the well-studied topic of reachability and the much less known problem of convex partitioning.
L'évolution continue des architectures des processeurs a été un moteur important de la recherche en compilation. Une tendance dans cette évolution qui existe depuis l'avènement des ordinateurs modernes est le rapport grandissant entre la puissance de calcul disponible (IPS, FLOPS, ...) et la bande-passante correspondante qui est disponible entre les différents niveaux de la hiérarchie mémoire (registres, cache, mémoire vive). En conséquence la réduction du nombre de communications mémoire requis par un code donnée a constitué un sujet de recherche important. Un principe de base en la matière est l'amélioration de la localité temporelle des données: regrouper dans le temps l'ensemble des accès à une donnée précise pour qu'elle ne soit requise que pendant peu de temps et pour qu'elle puisse ensuite être transféré vers de la mémoire lointaine (mémoire vive) sans communications supplémentaires.Une toute autre évolution architecturale a été l'arrivée de l'ère des multicoeurs et au cours des dernières années les premières générations de processeurs manycoeurs. Ces architectures ont considérablement accru la quantité de parallélisme à la disposition des programmes et algorithmes mais ceci est à nouveau limité par la bande-passante disponible pour les communications entres coeurs. Ceci a amené dans le monde de la compilation et des techniques d'optimisation des problèmes qui étaient jusqu'à là uniquement connus en calcul distribué.Dans ce texte nous présentons les premiers travaux sur une nouvelle technique d'optimisation, le pavage généralisé qui a l'avantage d'utiliser un modèle abstrait pour la réutilisation des données et d'être en même temps utilisable dans un grand nombre de contextes. Cette technique trouve son origine dans le pavage de boucles, une techniques déjà bien connue et qui a été utilisée avec succès pour l'amélioration de la localité des données dans les boucles imbriquées que ce soit pour les registres ou pour le cache. Cette nouvelle variante du pavage suit une vision beaucoup plus large et ne se limite pas au cas des boucles imbriquées. Elle se base sur une nouvelle représentation, le graphe d'utilisation mémoire, qui est étroitement lié à un nouveau modèle de besoins en termes de mémoire et de communications et qui s'applique à toute forme de code exécuté itérativement. Le pavage généralisé exprime la localité des données comme un problème d'optimisation pour lequel plusieurs solutions sont proposées. L'abstraction faite par le graphe d'utilisation mémoire permet la résolution du problème d'optimisation dans différents contextes. Pour l'évaluation expérimentale nous montrons comment utiliser cette nouvelle technique dans le cadre des boucles, imbriquées ou non, ainsi que dans le cas des programmes exprimés dans un langage à flot-de-données. En anticipant le fait d'utiliser le pavage généralisé pour la distribution des calculs entre les cœurs d'une architecture manycoeurs nous donnons aussi des éléments de réponse pour modéliser les communications et leurs caractéristiques sur ce genre d'architectures. En guise de point final, et pour montrer l'étendue de l'expressivité du graphe d'utilisation mémoire et le modèle de besoins en mémoire et communications sous-jacent, nous aborderons le sujet du débogage de performances et l'analyse des traces d'exécution. Notre but est de fournir un retour sur le potentiel d'amélioration en termes de localité des données du code évalué. Ce genre de traces peut contenir des informations au sujet des communications mémoire durant l'exécution et a de grandes similitudes avec le problème d'optimisation précédemment étudié. Ceci nous amène à une brève introduction dans le monde de l'algorithmique des graphes dirigés et la mise-au-point de quelques nouvelles heuristiques pour le problème connu de joignabilité mais aussi pour celui bien moins étudié du partitionnement convexe.
VANAMSTEL_2016_archivage.pdf (3.57 Mo) Télécharger le fichier
tel-01358312 , version 1 (31-08-2016)
tel-01358312 , version 2 (14-04-2017)
  • HAL Id : tel-01358312 , version 2
Duco Van Amstel. Optimisation de la localité des données sur architectures manycœurs. Architectures Matérielles [cs.AR]. Université Grenoble Alpes, 2016. Français. ⟨NNT : 2016GREAM019⟩. ⟨tel-01358312v2⟩
555 Consultations
412 Téléchargements
