The CQL continuous query language: semantic foundations and query execution " . The International Journal on Very Large Data Bases. 152 -2006, Locality on Manycore Architectures Annexes Other references, pp.121-142 ,
Optimal Spilling for CISC Machines with Few Registers, Proceedings of the 22nd ACM SIGPLAN Conference on Programming Language Design and Implementation, pp.243-253, 2001. ,
Improvements to graph coloring register allocation, ACM Transactions on Programming Languages and Systems, vol.16, issue.3, pp.163-1994428 ,
DOI : 10.1145/177492.177575
Global Constraint Catalog, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00485396
LRU stack processing " . IBM Journal of Research and Development. 194 -1975. IBM Corp, pp.353-357 ,
Cycle-static Dataflow, International Conference on Acoustics, Speech, and Signal Processing, pp.3255-3258, 1995. ,
Algorithmic Issues on Heterogeneous Computing Platforms " . Parallel Processing Letters . 92 -1999, pp.197-213 ,
Speculative out-of-order event processing with software transaction memory, Proceedings of the 2nd International Conference on Distributed Event-based Systems. ACM, pp.265-275, 2008. ,
A Scalable Cross-Platform Infrastructure for Application Performance Tuning Using Hardware Counters, Proceedings of SuperComputing, 2000. ,
Brook for GPUs: stream computing on graphics hardware, ACM Transactions on Graphics. ACM, pp.777-786, 2004. ,
Computer and job-shop scheduling theory ,
Studying Optimal Spilling in the Light of SSA Architectures and Synthesis for Embedded Systems, Proceedings of the 14th International Conference on Compilers, pp.25-34, 2011. ,
Improving Register Allocation for Subscripted Variables, Proceedings of the ACM SIGPLAN 1990 Conference on Programming Language Design and Implementation, pp.53-65, 1990. ,
The priority-based coloring approach to register allocation, ACM Transactions on Programming Languages and Systems, vol.12, issue.4, pp.124-1990501 ,
DOI : 10.1145/88616.88621
Mapping stream programs onto heterogeneous multiprocessor systems, Proceedings of the 2009 international conference on Compilers, architecture, and synthesis for embedded systems, CASES '09, 2009. ,
DOI : 10.1145/1629395.1629406
An improved two-way partitioning algorithm with stable performance (VLSI), IEEE Transactions on Computer-Aided Design of Integrated Circuits and Systems. 1012 -1991, pp.1502-1511 ,
DOI : 10.1109/43.103500
Operator scheduling in a data stream manager, Proceedings of the 29th International Conference on Very Large Data Bases. VLDB Endowment, pp.838-849, 2003. ,
Register Allocation via Coloring " . Computer Languages. 61 -1981, pp.47-57 ,
Register Allocation & Spilling via Graph Coloring, Proceedings of the 1982 SIGPLAN Symposium on Compiler Construction, pp.98-105, 1982. ,
Reachability and Distance Queries via 2-hop Labels, Proceedings of the 13th Annual ACM- SIAM Symposium on Discrete Algorithms, pp.937-946, 2002. ,
Spidle: a DSL approach to specifying streaming applications " . Generative Programming and Component Engineering, pp.1-17, 2003. ,
A calculus for network delay. I. Network elements in isolation, IEEE Transactions on Information Theory, vol.37, issue.1, pp.371-1991114 ,
DOI : 10.1109/18.61109
Efficiently Computing Static Single Assignment Form and the Control Dependence Graph, ACM Transactions on Programming Languages and Systems, vol.134, pp.451-490, 1991. ,
The working set model for program behavior, Communications of the ACM, vol.115, pp.323-333, 1968. ,
First version of a data flow procedure language " . Programming Symposium, pp.362-376, 1974. ,
Code Generator Optimizations for the ST120 DSP-MCU Core, Proceedings of the 2000 International Conference on Compilers, Architecture, and Synthesis for Embedded Systems, pp.93-102, 2000. ,
An Efficient and Scalable Semiconductor Architecture for Parallel Automata Processing, Annexes Other references IEEE Transactions on Parallel and Distributed Systems. 2512 -2014, pp.3088-3098 ,
On Characterizing the Data Movement Complexity of Computational DAGs for Parallel Execution, Proceedings of the 26th ACM Symposium on Parallelism in Algorithms and Architectures, pp.296-306, 2014. ,
On Characterizing the Data Access Complexity of Programs, Proceedings of the 42th Annual ACM SIGPLAN-SIGACT Symposium on Principles of Programming Languages ,
On Using the Roofline Model with Lower Bounds on Data Movement, ACM Transactions on Architure and Code Optimization ACM. p, vol.67, pp.114-20151 ,
Orchestration by Approximation: Mapping Stream Programs Onto Multicore Architectures, Proceedings of the 16th International Conference on Architectural Support for Programming Languages and Operating Systems, pp.357-368, 2011. ,
Beyond Reuse Distance Analysis: Dynamic Analysis for Characterization of Data Locality Potential " . ACM Transactions on Architure and Code Optimization . 104 -2013, ACM. p, vol.53, pp.1-5329 ,
Iterated Register Coalescing, ACM Transactions on Programming Languages and Systems, pp.183-1996300 ,
Code scheduling and register allocation in large basic blocks, Proceedings of the 2nd International Conference on Supercomputing, pp.442-452, 1988. ,
The Turn Model for Adaptive Routing, Journal of the ACM, vol.133, pp.415-1994874 ,
A multilevel algorithm for partitioning graphs, Proceedings of the 1995 ACM/IEEE conference on Supercomputing (CDROM) , Supercomputing '95, p.92 ,
DOI : 10.1145/224170.224228
A Cartesian Parallel Nested Dissection Algorithm, SIAM Journal on Matrix Analysis and Applications, vol.16, issue.1, pp.161-1995 ,
DOI : 10.1137/S0895479892238270
The synchronous data flow programming language LUSTRE, Proceedings of the IEEE, pp.1305-1320, 1991. ,
A Catalog of Stream Processing Optimizations, pp.464-2014 ,
Supernode partitioning, Proceedings of the 15th ACM SIGPLAN-SIGACT symposium on Principles of programming languages , POPL '88, pp.319-329, 1988. ,
DOI : 10.1145/73560.73588
I/O complexity, Proceedings of the thirteenth annual ACM symposium on Theory of computing , STOC '81, pp.326-333, 1981. ,
DOI : 10.1145/800076.802486
Max-Min-Fair Best Effort Flow Control in Network-on-Chip Architectures, Annexes Other references Proceedings of the 8th International Conference on Computational Science, Part I, pp.436-445, 2008. ,
Optimal Regulation of Traffic Flows in Networks-on-chip, Proceedings of the Conference on Design, Automation and Test in Europe. European Design and Automation Association, pp.1621-1624, 2010. ,
Characterizing and Understanding PDES Behavior on Tilera Architecture, Proceedings of the 2012 ACM/IEEE/SCS 26th Workshop on Principles of Advanced and Distributed Simulation, pp.2012-53 ,
3HOP: A High-compression Indexing Scheme for Reachability Query, Proceedings of the 2009 ACM SIGMOD International Conference on Management of Data, pp.813-826, 2009. ,
Path-tree: An Efficient Reachability Indexing Scheme for Large Directed Graphs, ACM Transactions on Database Systems. ACM. p, vol.7, pp.361-20111 ,
SCARAB: Scaling Reachability Computation on Large Graphs, Proceedings of the 2012 ACM SIGMOD International Conference on Management of Data. ACM. 2012. p, pp.169-180 ,
Multi-level graph partitioning schemes, Proceedings of the 1995 International Conference for Parallel Processing, pp.113-122, 1995. ,
An Efficient Heuristic Procedure for Partitioning Graphs, Bell System Technical Journal, vol.49, issue.2, pp.291-307 ,
DOI : 10.1002/j.1538-7305.1970.tb01770.x
Orchestrating the Execution of Stream Programs on Multicore Platforms, Proceedings of the 29th ACM SIGPLAN Conference on Programming Language Design and Implementation, pp.114-124, 2008. ,
Rate control for communication networks: shadow prices, proportional fairness and stability " . Journal of the Operational Research Society. 493 -1998, Data Locality on Manycore Architectures Annexes [, pp.237-252 ,
LLVM: A compilation framework for lifelong program analysis & transformation, International Symposium on Code Generation and Optimization, 2004. CGO 2004. ,
DOI : 10.1109/CGO.2004.1281665
Network calculus: a theory of deterministic queuing systems for the internet, 2001. ,
Register Promotion in C Programs, Proceedings of the 18th ACM SIGPLAN Conference on Programming Language Design and Implementation, pp.308-319, 1997. ,
Static Scheduling of Synchronous Data Flow Programs for Digital Signal Processing, IEEE Transactions on Computers, vol.36, issue.1 ,
DOI : 10.1109/TC.1987.5009446
Register Promotion by Sparse Partial Redundancy Elimination of Loads and Stores, Proceedings of the 19th ACM SIGPLAN Conference on Programming Language Design and Implementation, pp.26-37, 1998. ,
Organizing matrices and matrix operations for paged memory systems, Communications of the ACM, vol.12, issue.3, pp.123-1969153 ,
DOI : 10.1145/362875.362879
Global optimization by suppression of partial redundancies, Communications of the ACM, vol.22, issue.2, pp.222-197996 ,
DOI : 10.1145/359060.359069
Vavasis - " A unified geometric approach to graph separators, Proceedings of the 32nd Annual Symposium on the Foundations of Computer Science, pp.538-547, 1991. ,
Graph Contraction for Physical Optimization Methods: A Quality-cost Tradeoff for Mapping Data on Parallel Computers, Annexes Other references Proceedings of the 7th International Conference on Supercomputing, pp.1-10, 1993. ,
Outstanding Research Problems in NoC Design: System, Microarchitecture, and Circuit Perspectives " . Transactions on Computer-Aided Design of Integrated Circuits and Systems, pp.281-20093 ,
Evaluation techniques for storage hierarchies " . IBM Systems journal. 92 -1970. IBM Corp, pp.78-117 ,
Reflections on the Memory Wall, Proceedings of the 1st Conference on Computing Frontiers, p.162, 2004. ,
Combining register allocation and instruction scheduling ,
Prediction-based flow control for network-on-chip traffic, Proceedings of the 43rd annual conference on Design automation , DAC '06, pp.839-844, 2006. ,
DOI : 10.1145/1146909.1147123
Partitioning Sparse Matrices with Eigenvectors of Graphs, SIAM Journal on Matrix Analysis and Applications . 113 -1990. SIAM. p, pp.430-452 ,
DOI : 10.1137/0611030
Program partitioning and synchronization on multiprocessor systems, 1986. ,
TIREX : A textual target-level intermediate representation for virtual execution environment, compiler information exchange and program analysis, p.72 ,
OpenStream, Proceedings of the 16th International Workshop on Software and Compilers for Embedded Systems, M-SCOPES '13, pp.2-2 ,
DOI : 10.1145/2463596.2486782
Handbook of Constraint Programming (Foundations of Artificial Intelligence, Data Locality on Manycore Architectures Annexes [, 2006. ,
Combined ILP and Register Tiling: Analytical Model and Optimization Framework, 18th International Workshop on Languages and Compilers for Parallel Computing, pp.244-258, 2005. ,
Another Trip to the Wall: How Much Will Stacked DRAM Benefit HPC, Proceedings of the 2015 International Symposium on Memory Systems. ACM. 2015. p, pp.31-36 ,
Decoupled Software Pipelining with the Synchronization Array, Proceedings of the 13th International Conference on Parallel Architectures and Compilation Techniques, pp.177-188, 2004. ,
A Filtering Algorithm for Constraints of Difference in CSPs American Association for Artificial Intelligence, Proceedings of the 1994 National Conference on Artificial Intelligence, pp.362-367, 1994. ,
A New Algorithm for Scalar Register Promotion Based on SSA Form, Proceedings of the 19th ACM SIGPLAN Conference on Programming Language Design and Implementation, pp.15-25, 1998. ,
JaCoP -Java Constraint Programming solver, 2013. ,
Pinned to the walls — Impact of packaging and application properties on the memory and power walls, IEEE/ACM International Symposium on Low Power Electronics and Design, pp.51-56, 2011. ,
DOI : 10.1109/ISLPED.2011.5993603
Missing the Memory Wall: The Case for Processor/Memory Integration, Annexes Other references Proceedings of the 23rd Annual International Symposium on Computer Architecture, pp.90-101, 1996. ,
The Architecture and Programming of the Ametek Series 2010 Multicomputer, Proceedings of the 3rd Conference on Hypercube Concurrent Computers and Applications: Architecture, Software, Computer Systems, and General Issues, pp.33-37, 1988. ,
Cache Aware Optimization of Stream Programs, Proceedings of the 2005 ACM SIG- PLAN/SIGBED Conference on Languages, Compilers, and Tools for Embedded Systems. ACM. 2005. p, pp.115-126 ,
StreamIt: A Language for Streaming Applications, Proceedings of the 11th International Conference on Compiler Construction, pp.179-196, 2002. ,
DOI : 10.1007/3-540-45937-5_14
Reachability Queries in Very Large Graphs: A Fast Refined Online Search Approach, Proceedings of the 17th Conference on Extending Database Technology. Open- Proceedings.org. 2014, pp.511-522 ,
SEDA: an architecture for wellconditioned , scalable internet services, ACM SIGOPS Operating Systems Review. ACM. p, vol.139, pp.355-2001230 ,
Hitting the memory wall, ACM SIGARCH Computer Architecture News, vol.23, issue.1, pp.20-24 ,
DOI : 10.1145/216585.216588
Exploiting mixed SIMD parallelism by reducing data reorganization overhead, Proceedings of the 2016 International Symposium on Code Generation and Optimization, CGO 2016, pp.59-69 ,
DOI : 10.1145/2854038.2854054
A hypergraph model for mapping repeated sparse matrix-vector product computations on multicomputers, Proceedings of the International Conference on High Performance Computing, 1995. ,
Decomposing irregularly sparse matrices for parallel matrix-vector multiplication " . Parallel Algorithms for Irregularly Structured Problems, pp.75-86, 1996. ,
