Theses
AUTOMATIC SEGMENTATION OF ANATOMICAL STRUCTURES USING DEFORMABLE MODELS AND BIO-INSPIRED/SOFT COMPUTING
Résumé : This PhD dissertation is focused on the development of algorithms for the automatic segmentation of anatomical structures in biomedical images, usually the hippocampus in histological images from the mouse brain. Such algorithms are based on computer vision techniques and artificial intelligence methods. More precisely, on the one hand, we take advantage of deformable models to segment the anatomical structure under consideration, using prior knowledge from different sources, and to embed the segmentation into an optimization framework. On the other hand, metaheuristics and classifiers can be used to perform the optimization of the target function defined by the shape model (as well as to automatically tune the system parameters), and to refine the results obtained by the segmentation process, respectively. Three new different methods, with their corresponding advantages and disadvantages, are described and tested. A broad theoretical discussion, together with an extensive introduction to the state of the art, has also been included to provide an overview necessary for understanding the developed methods.
Complete list of metadata
Cited literature [227 references]  Display  Hide  Download
https://hal.inria.fr/tel-01363683
Contributor : Pablo Mesejo Santiago Connect in order to contact the contributor
Submitted on : Sunday, September 11, 2016 - 9:25:00 AM
Last modification on : Thursday, September 2, 2021 - 10:14:47 AM
Identifiers
  • HAL Id : tel-01363683, version 1
Collections
Citation
Pablo Mesejo. AUTOMATIC SEGMENTATION OF ANATOMICAL STRUCTURES USING DEFORMABLE MODELS AND BIO-INSPIRED/SOFT COMPUTING. Artificial Intelligence [cs.AI]. University of Parma, 2014. English. ⟨tel-01363683⟩
Share
Metrics
Record views
93
Files downloads
176
