Hypersonic jets probed by cavity ring-down spectroscopy : application to laboratory astrophysics
Jets hypersoniques sondés par temps de déclin d’une cavité optique : application à l’astrophysique de laboratoire
A huge quantity of infrared spectra is collected by terrestrial and space telescopes from cool astrophysical objects (500-3000 K) like exoplanet (hot Jupiter) and brown dwarf atmospheres or circumstellar envelop of AGB stars. The main purpose of this thesis connected to experimental astrophysics is to provide high temperature data of key molecules by reproducing in the laboratory some aspects of such environments. A new setup built in Rennes couples a High Enthalpy Source to a highly sensitive Cavity Ring-Down Spectrometer. The gas studied, heated in the reservoir up to 2000 K, is expanded in a vacuum chamber through a circular nozzle and the resulting hypersonic jet can be probed at any location. Computational flow dynamics (CFD) calculations associated to a modeling of the infrared absorption lead to synthetic lines which are in very good agreement with the observed spectra. These numerical data were used to attribute the unusual double peak line shapes to the particular flow structure of axisymmetric hypersonic jets. Strong out-of-equilibrium conditions were evidenced in the isentropic core of the expansion. High vibrational temperature (1350 K) and rotational temperature lower than 10 K were recorded inside a jet of CO seeded in Ar. This degrees-of-freedom decoupling greatly simplifies the rotational structure of the recorded infrared spectra and unveils the presence of hot bands stemming from highly excited vibrational states which are significantly populated at high temperature. Our approach is therefore well suited for the study of rotationally cold hot bands of polyatomic molecules which are virtually missing in spectroscopic databases. A complementary approach consists in probing the shock layer formed upstream of an obstacle set perpendicularly to the hypersonic flow axis. Rotational temperature raises abruptly downstream the shock, revealing transitions associated with high J quantum numbers. These two methods were successfully applied to methane which plays an important role in numerous astrophysical environments. In addition to the acquisition of infrared spectroscopic data, the relaxation of internal degrees-of-freedom of CO seeded in different carrier gases (Ar and He) was studied by following the evolution of rotational and vibrational temperatures along the flow, in the isentropic core as well as in the peripheral viscous layers. These temperatures were compared to excitation temperatures calculated by an ab initio method in order to validate collision rates. These data will feed databases needed for the development of radiative transfer codes with a view to a better modeling of spectra observed from "hot" astrophysical environments.
Les télescopes terrestres et spatiaux recueillent une énorme quantité d'informations dans le domaine infrarouge en provenance d'objets astrophysiques ''chauds'' (500-3000 K) tels que les atmosphères d'exoplanètes (Jupiters chauds), de naines brunes et les enveloppes circumstellaires d'étoiles AGBs. Cette thèse s'inscrit dans une approche d'astrophysique de laboratoire s'attachant à reproduire in situ certains aspects des conditions extrêmes rencontrées au sein de ce type d'environnements afin notamment de produire des données haute température de molécules clefs. Le nouveau dispositif mis en place à Rennes couple une Source Haute Enthalpie à un spectromètre par temps de déclin d'une cavité optique (CRDS). Le gaz étudié, chauffé dans le réservoir à une température avoisinant 2000 K, est expulsé dans une chambre basse pression au travers d'un injecteur circulaire. Le jet libre hypersonique ainsi formé est sondé en tout point et avec une très haute sensibilité. La simulation de nos écoulements stationnaires (CFD) associée à la modélisation du spectromètre a abouti à des spectres synthétiques en très bon accord avec les spectres expérimentaux. Ces données numériques ont été utilisées pour expliquer l'origine des profils de raie atypiques et plus généralement pour comprendre la structure des jets hypersoniques axisymétriques. Le cœur isentropique de ces écoulements est caractérisé par de fortes conditions hors équilibre. Une température de vibration très élevée (1350 K) et une température de rotation très basse (10 K) ont été obtenues à partir d’un jet de CO et d’argon. Ce découplage des degrés de liberté internes permet de simplifier la structure rotationnelle des spectres enregistrés et facilite l’étude des états vibrationnels excités des molécules en révélant la structure des bandes chaudes, absentes des bases de données spectroscopiques pour la plupart des molécules polyatomiques. Une approche complémentaire consiste à sonder la couche de choc produite par l'ajout d'un obstacle sur le trajet de l'écoulement. La température rotationnelle est brutalement élevée donnant ainsi accès aux transitions rotationnelles de hautes valeurs du nombre quantique J. Ces deux méthodes ont été appliquées avec succès au méthane qui joue un rôle majeur dans de nombreux environnements astrophysiques chauds. Enfin, outre la production de données spectroscopiques, ce dispositif expérimental a permis de mettre en évidence la relaxation des degrés de liberté internes du CO dans différents gaz porteurs (He et Ar) en suivant l’évolution des températures de rotation et vibration le long de l'écoulement hypersonique, aussi bien dans le cœur isentropique qu'au sein des couches limites. Ces températures sont comparées aux températures d'excitation obtenues par des méthodes ab initio afin de valider des calculs de taux de collision. Les données obtenues alimenteront à terme des bases de données, matière première au développement de codes de transfert radiatif permettant d'interpréter les observations en provenance des milieux astrophysiques ''chauds''.
Astrophysique [astro-ph]
