Les lieux de l'interaction. Fréquentation du stade et intégration sociale à Neuchâtel - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2012
Place and interaction : stadium attendance and social integration, the case of Neuchâtel
In February 2007, Neuchâtel celebrates the inauguration of a brand new soccer stadium. For the club of Neuchâtel Xamax, which has been facing economical difficulties since a long time, this infrastructure represents a promising bright future. Everyone praises without restraint the comfort of the new arena, which is described as a friendly place, convenient to encounters, able to attract bigger crowds of people for long festive afternoons dedicated to the soccer entertainment. The analysis of the real social impact of the modernisation of this type of infrastructure is nonetheless very tricky. It implies not only a critical reflection on the attributes that can be considered as “socially virtuous” for the community, but also requires deciphering how the place works in its whole complexity. Following that, the research first requires the construction of a theoretical and methodological tool, which allows the study of the “integration potential” of this kind of space. Within the framework of the soccer stadium analysis, the use of this tool shows us that, in the case of Neuchâtel, this place plays a quite important social role. Based on various sources (questionnaire surveys, statistics relative to affluences, discourse analysis on a forum, etc.), the comparison of the situations that characterize the old and new infrastructure leads nevertheless to a nuanced assessment of the process of modernisation.
Au cours du mois de février 2007, Neuchâtel célèbre l’inauguration d’un stade de football flambant neuf. Pour le club de Neuchâtel Xamax, qui fait face à des difficultés économiques chroniques, cette infrastructure laisse miroiter un avenir prometteur. On vante alors sans retenue le plus grand confort de la nouvelle enceinte que l’on décrit comme un lieu convivial et propice à la rencontre, sensé attirer un public toujours plus nombreux pour de longs après‐midis festifs consacrés au spectacle du football. Analyser l’impact social réel de la modernisation de ce type d’infrastructure s’apparente toutefois à un exercice d’équilibriste. Il implique non seulement une réflexion critique sur des attributs qui peuvent être considérés comme « socialement vertueux » pour la collectivité, mais nécessite également de décrypter le fonctionnement du lieu dans toute sa complexité. Dès lors, cette recherche passe au préalable par la construction d’un outil théorique et méthodologique permettant d’organiser l’étude du « potentiel intégrateur » d’un tel type d’espace. Dans le cadre d’une analyse portant sur le stade de football, l’utilisation de cette grille de lecture nous montre alors que, à Neuchâtel, ce lieu joue un rôle social plutôt important. Fondée sur différentes sources (enquêtes par questionnaire, statistiques relatives aux affluences, analyse des discours sur un forum de discussion en ligne, etc.), la comparaison des situations qui caractérisent l’ancienne et la nouvelle infrastructure conduit néanmoins à tirer un bilan nuancé du processus de modernisation.
these_BESSON_Roger_2012.pdf (6.68 Mo) Télécharger le fichier
tel-01374281 , version 1 (30-09-2016)
  • HAL Id : tel-01374281 , version 1
Roger Besson. Les lieux de l'interaction. Fréquentation du stade et intégration sociale à Neuchâtel. Géographie. Université de Neuchâtel; Université de Franche-Comté, 2012. Français. ⟨NNT : ⟩. ⟨tel-01374281⟩
190 Consultations
245 Téléchargements
