Les histones déacétylases de type 2 dans le contrôle de la mort cellulaire induite par la cryptogéine, un éliciteur des réactions de défense chez le tabac - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2011
Type-2 histones deacetylases and cryptogein-induced cell death in tabacco
Cryptogein, which is secreted by the oomycete Phytophthora cryptogea, is a proteinaceous elicitor of plant defense reactions that activates a set of signaling events leading to the hypersensitive response and to systemic acquired resistance. Although the early cytosolic signaling events induced by cryptogein are well described, the only nuclear events characterized to date are the variations in free calcium concentrations and defense-related gene expression. The characterization of the activation of cytosolic protein kinases, including WIPK and SIPK, by phosphorylation in response to cryptogein highlights the key-role played by posttranslational modifications in cryptogein-induced signaling events in tobacco cells. In this context, purification/sequencing approaches revealed that two redundant isoforms of type-2 nuclear histone deacetylases, NtHD2a and NtHD2b, were rapidly phosphorylated in cryptogein-treated tobacco cells.This thesis work is part of a comprehensive study of the role of NtHD2a/b in the establishment of the cell death process in tobacco cells and of the hypersensitive response in planta, in response to cryptogein. By using a pharmacological approach and overexpression and RNA interference-based approaches, we confirmed the involvement of NtHD2a/b as negative regulators of elicitin-induced cell death and we achieved a better understanding of cell death signaling events. The molecular events that underly the cell death process appear particularly complex and seem to involve the modulation of defense-related gene expression, de novo protein synthesis and protein kinase activation such as WIPK and SIPK.The study of (de)/acetylation events in tobacco cells treated by cryptogein and invalidated in NtHD2a/b expression suggests a role for posttranslational modifications in cryptogein-induced cell death.
La cryptogéine, sécrétée par l’oomycète Phytophthora cryptogea, est un éliciteur protéique des réactions de défense qui active chez le tabac un ensemble d’événements de signalisation conduisant à la mise en place d’une mort cellulaire de type réponse hypersensible et d’une résistance systémique acquise. La caractérisation de la modulation de l’activité de kinases cytosoliques, dont SIPK et WIPK, par des événements de phosphorylation en réponse à la cryptogéine, traduit la place majeure que tiennent les modifications post-traductionnelles dans la cascade de signalisation induite dans les cellules de tabac en réponse à la cryptogéine. Il s’avère que la signalisation cellulaire induite par la cryptogéine, et impliquant ces protéines kinases, converge entre autre vers le noyau à travers la modulation de l’activité d’éléments nucléaires par phosphorylation. Dans ce contexte, d’importants travaux de purification/séquencage, visant à identifier les protéines nucléaires cibles de ces activités kinases, ont permis d’identifier deux isoformes redondantes d’histones désacétylases de type 2 nommés NtHD2a et NtHD2b qui sont rapidement phosphorylées en réponse à la cryptogéine dans les cellules de tabac.Ce travail de thèse s’inscrit dans l’étude du rôle de NtHD2a/b dans l’établissement du processus de mort cellulaire des cellules de tabac et de la RH in planta en réponse à la cryptogéine. Par des approches de pharmacologie ainsi que des approches de surexpression ou d’invalidation de l’expression de NtHD2a/b chez le tabac, nous avons d’une part confirmé l’implication de NtHD2a/b en tant que régulateurs négatifs de la mort cellulaire induite par la cryptogéine ou d’autres élicitines, et d’autre part mieux appréhendé les événements de la cascade de signalisation prépondérants dans l’établissement de cette mort cellulaire. Les mécanismes moléculaires sous-jacents à la mise en place de la mort cellulaire apparaissent complexes et semblent notamment impliquer la modulation de l’expression de gènes de défense, la synthèse de novo de protéines ainsi que l’activation de protéines kinases, dont notamment WIPK et SIPK.Des travaux relatifs à l’étude des événements de (dé)/acétylation dans les cellules de tabac traitées par la cryptogéine et invalidées dans l’expression de NtHD2a/b suggèrent le concours de modifications post-traductionnelles de protéines nucléaires telles que l’acétylation dans la mise en place de la mort cellulaire induite par la cryptogéine chez le tabac.
these_A_DUTARTRE_Agnes_2011.pdf (20.42 Mo) Télécharger le fichier
tel-01374560 , version 1 (30-09-2016)
  • HAL Id : tel-01374560 , version 1
Agnès Dutartre. Les histones déacétylases de type 2 dans le contrôle de la mort cellulaire induite par la cryptogéine, un éliciteur des réactions de défense chez le tabac. Biochimie, Biologie Moléculaire. Université de Bourgogne, 2011. Français. ⟨NNT : 2011DIJOS109⟩. ⟨tel-01374560⟩
184 Consultations
73 Téléchargements
