Some inverse problems with partial data - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2016
Quelques problèmes inverses avec des données partielles
The thesis consists of three parts. In Part I, we consider partially overdeterminedboundary-value problemS for Laplace PDE in a planar simply connected domain withLipschitz boundary. Assuming Dirichlet and Neumann data available on its part to be realvaluedfunctions of certain regularity, we develop a non-iterative method for solving thisill-posed Cauchy problem choosing as a regularizing parameter L2 bound of the solutionon complementary part of the boundary. The present complex-analytic approach alsonaturally allows imposing additional pointwise constraints on the solution which, onpractical side, can help incorporating outlying boundary measurements without changingthe boundary into a less regular one. Part II is concerned with spectral structure of atruncated Poisson operator arising in various physical applications. We deduce importantproperties of solutions, discuss connections with other problems and pursue differentreductions of the formulation for large and small values of asymptotic parameter yieldingsolutions by means of solving simpler integral equations and ODEs. In Part III, we dealwith a particular inverse problem arising in real physical experiments performed withSQUID microscope. The goal is to recover certain magnetization features of a sample frompartial measurements of one component of magnetic field above it. We develop newmethods based on Kelvin and Fourier transformations resulting in estimates of netmoment components.
La thèse se compose de 3 parties. Dans la partie I, nous considérons des problèmes à lafrontière pour une EDP de Laplace dans un domaine simplement connexe de bordLispschitz continu. Depuis des données Dirichlet et Neumann suffisamment régulièresdisponibles sur une partie de la frontière, nous développons une méthode non-itérative derésolution de ce problème de Cauchy, régularisé par une contrainte en norm L2 portantsur la solution sur la partie complémentaire du bord. Notre approche par les fonctionsanalytiques de la variable complexe permet d'imposer des contraintes ponctuellessupplémentaires possédant un intêret pratique pour incorporer des mesures corrompues.La partie II concerne la structure spectrale d'un opérateur de Poisson tronqué intervenantdans diverses applications physiques. Nous établissons d'importantes propriétés dessolutions, des connexions avec d'autres problèmes, ainsi que, pour des valeursasymptotiques d'un paramètre, des formulations sous forme d'autres équations intégralesou EDO solubles. Dans la partie III, nous traitons un problème inverse particulier issud'expériences pratiques effectuées avec un microscope SQUID. Depuis des mesurespartielles de la composante verticale du champ magnétique, le but est de retrouvercertaines propriétés de l'aimantation d'un échantillon de roche. Nous présentons denouvelles méthodes utilisant les transformations de Kelvin et de Fourier pour l'estimationdu moment magnétique.
main_file.pdf (1.9 Mo) Télécharger le fichier
tel-01400595 , version 1 (22-11-2016)
  • HAL Id : tel-01400595 , version 1
Dmitry Ponomarev. Some inverse problems with partial data. Other. Université Nice Sophia Antipolis, 2016. English. ⟨NNT : 2016NICE4027⟩. ⟨tel-01400595⟩
Collections
INRIA INRIA2
266 Consultations
221 Téléchargements
