Cryptanalysis of symmetric ciphers
Cryptanalyse de chiffrements symétriques
The main subject of this thesis is the security analysis of symmetric key ciphers. Specifically, we study several recently proposed block and stream ciphers and prove that the level of security stated by their designers is overestimated. The ciphers we study were all designed in order to meet the needs of one of the new applications of symmetric cryptography, which include symmetric ciphers for very constrained environments.
The first part of the thesis is dedicated to the analysis of block ciphers with techniques based on differential cryptanalysis. We start with the description of a truncated differential attack on the family of lightweight ciphers KLEIN. Next, we analyse two ciphers that were designed in such a way that they could be easily and effectively protected against side-channel attacks: Zorro and Picaro. We show that the design choices made by their designers lead to weak diffusion properties. We exploit these imperfections to devise a differential cryptanalysis of Zorro and a related key attack on Picaro.
The second part of this thesis deals with stream ciphers and gives an analysis of two innovative designs: Sprout and Flip. Sprout was designed in order to limit its hardware area size and to suit very constrained environments, while Flip reaches efficient performances when used in FHE schemes. In both cases, we find flaws that lead to attacks of the particular set of parameters proposed for these ciphers.
Les travaux réalisés dans cette thèse ont pour objet l'analyse de la sécurité de chiffrements à clef secrète. Plus précisément, nous y décrivons la cryptanalyse de plusieurs chiffrements par blocs et à flot ayant pour point commun d'avoir été conçus récemment pour répondre aux nouveaux enjeux de la cryptographie symétrique. Nous mettons en avant des attaques des versions complètes de cinq chiffrements, prouvant ainsi que ces primitives cryptographiques n'apportent pas la sécurité annoncée par leurs concepteurs.
La première partie de cette thèse est dédiée à l'analyse de chiffrements par blocs avec des techniques de cryptanalyse différentielle. Nous montrons comment mener une attaque par différentielles tronquées sur la famille de chiffrements à bas coût KLEIN en exploitant la faible diffusions de sa fonction de tour. Ensuite, nous nous intéressons à Zorro et à Picaro, deux chiffrements conçus de sorte à être faciles à protéger contre les attaques par canaux auxiliaires, et montrons que les choix de conception guidés par cette contrainte ont engendré des faiblesses dans leurs propriétés différentielles, pouvant ensuite être exploitées dans des attaques.
La seconde partie du manuscrit porte sur la cryptanalyse de chiffrements à flot. Nous y étudions Sprout et Flip, deux chiffrements aux structures innovantes visant respectivement à limiter la taille du circuit matériel nécessaire à l'implémentation et une bonne adaptation dans un schéma de FHE.
