Intercepting functions for memoization - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2016
Interception de fonctions pour la mémoïsation
Arjun Suresh
  • Fonction : Auteur
  • PersonId : 774541
  • IdRef : 19978390X
We have proposed mechanisms to implement function memoization at a software level as part of our effort to improve sequential code performance. We have analyzed the potential of function memoization on applications and its performance gain on current architectures. We have proposed three schemes - a simple load time approach which works for any dynamically linked function, a compile time approach using LLVM framework which can enable memoization for any program function and also a hardware proposal for doing memoization in hardware and its potential benefits. Demonstration of the link time approach with transcendental functions showed that memoization is applicable and gives good benefit even under modern architectures and compilers (with the restriction that it can be applied only for dynamically linked functions). Our compile time approach extends the scope of memoization and also increases the benefit due to memoization. This works for both user defined functions as well as library functions. It can handle certain kind of non pure functions like those functions with pointer arguments and global variable usage. Hardware memoization lowers the threshold for a function to be memoized and gives more performance gain on average.
Nous avons proposé des mécanismes pour mettre en œuvre la mémoïsation de fonction au niveau logiciel dans le cadre de nos efforts pour améliorer les performances du code séquentiel. Nous avons analysé le potentiel de la mémoïsation de fonction sur des applications et le gain de performance qu'elle apporte sur des architectures actuelles. Nous avons proposé trois approches - une approche simple qui s'applique au chargement et qui fonctionne pour toute fonction de bibliothèque liée dynamiquement, une approche à la compilation utilisant LLVM qui peut permettre la mémoïsation pour toute fonction du programme, ainsi qu'une proposition d'implémentation de la mémoïsation en matériel et ses avantages potentiels. Nous avons démontré avec les fonctions transcendantales que l'approche au chargement est applicable et donne un bon avantage, même avec des architectures et des compilateurs (avec la restriction qu'elle ne peut être appliquée que pour les fonctions liées dynamiquement) modernes. Notre approche à la compilation étend la portée de la mémoïsation et en augmente également les bénéfices. Cela fonctionne pour les fonctions définies par l’utilisateur ainsi que pour les fonctions de bibliothèque. Nous pouvons gérer certains types de fonctions non pures comme les fonctions avec des arguments de type pointeur et l'utilisation de variables globales. La mémoïsation en matériel abaisse encore le seuil de profitabilité de la mémoïsation et donne plus de gain de performance en moyenne.
SURESH_Arjun.pdf (1.01 Mo) Télécharger le fichier
tel-01410539 , version 1 (06-12-2016)
tel-01410539 , version 2 (11-05-2017)
  • HAL Id : tel-01410539 , version 2
Arjun Suresh. Intercepting functions for memoization. Programming Languages [cs.PL]. Université de Rennes, 2016. English. ⟨NNT : 2016REN1S106⟩. ⟨tel-01410539v2⟩
618 Consultations
1403 Téléchargements
